Like Tree195Likes
Novarossi engines thread
Old 10-17-2017, 10:30 PM
  #5416
ralphierace13's Avatar
Originally Posted by BigC2007
I have seen longer fuel lines coming from the pipe to the Exhaust Gas Cooler compared to mine. ( picture below)
Would mine be consider short or should I make it longer ?
the cooler really don't help much in on road because of the onroad body not much airflow, also the way the modern gas tanks are made today u really don't even need a long fuel tube at all mine is direct to tank and works perfect I actually think like I said the way the tanks r today the short the better..
ralphierace13 is offline
Old 10-17-2017, 11:18 PM
  #5417
snuvet75's Avatar
Trader Rating: 16 (94%+)
Mine is almost identical to yours. Total length from pressure tab to tank is what matters from I know. Not for the cooling but for foam elimination. Correct me if I'm wrong. BTW, I like your shiny pipe.
snuvet75 is offline
Old 10-18-2017, 06:28 AM
  #5418
BigC2007's Avatar
Thanks guys for the replies and the pipe is shiny for now because its new so just wait it will look like burnt toast soon.
BigC2007 is offline
Old 10-19-2017, 02:42 AM
  #5419
Steve_K's Avatar
Two words... White Diamond.
Steve_K is offline
Old 10-20-2017, 09:09 AM
  #5420
dan_vector's Avatar
Trader Rating: 27 (100%+)
Just rub some high temp silicone grease onto the pipe before running. All the tire and fuel gunge just wipes straight off. No need for any other cleaners. Just use high temperature silicone grease!
finchy and BigC2007 like this.
dan_vector is offline
Old 10-20-2017, 10:48 AM
  #5421
BigC2007's Avatar
Again good info Dan thanks
BigC2007 is offline
Old 10-23-2017, 10:46 PM
  #5422
snuvet75's Avatar
That's what I use Steve!
snuvet75 is offline
Old 10-30-2017, 07:19 AM
  #5423
BigC2007's Avatar
Default Navarossi glow plug ?
Anyone know the differences between these #8's ?
C8TGFB
C8TGHB
C8TGTB
BigC2007 is offline
Old 11-04-2017, 10:27 PM
  #5424
dan_vector's Avatar
C8TGFB
C8TGHB
C8TGTB
C8TGFB - Slightly Cooler than HB plug so better hotter ambient conditions (a bit stronger element but a little less power). Lower consumption. Easier to tune.
C8TGHB - Similar to FB but a little hotter and develops a little more power overall. Higher fuel consumption. Weaker element so tune is critical the plug wont take a slightly lean tune.
C8TGTB - Somewhere in the middle of the above 2 in temperature. Strongest plug with the best runtime. Lowest power of all 3 plugs and easiest to tune. Longest lasting.
However, Novarossi have a new plug which I am currently using which seems to be better than all 3 of the above put together. The new plug is 'CT8' and is pretty good across the board. Easy to tune and lasts a really long time.
Old 11-05-2017, 06:30 AM
  #5425
BigC2007's Avatar
Thanks a ton Dan for the info and the new CT8 plug your running were can I find them ?
BigC2007 is offline
Old 11-05-2017, 09:40 AM
  #5426
dan_vector's Avatar
https://www.amainhobbies.com/novaros...nvrct8/p591139
Old 11-05-2017, 09:17 PM
  #5427
most guys including myself we use the os plugs in the nova those things take a beating !!!! and want more !!!
Old 11-06-2017, 05:42 AM
  #5428
dan_vector's Avatar
Not anymore Ralph, all the european and asia team drivers are back onto Novarossi plugs using the new CT range. No more issues.
Novarossi have also brought the price of plugs down as well (finally) making them also cheaper than O.S. plugs now.
BigC2007 likes this.
Old 11-07-2017, 02:30 PM
  #5429
I tried the ones recommended for my mito and was same shit for a month in the beginning of the summer went throu like 10 of them went to os used the same plug for the next 3 months lol!!! I swear !!
Old 11-07-2017, 03:52 PM
  #5430
what OS plug are you running in your mito 21?
is it novarossi ct8 = os rp8?
thanks.
implusepro is offline
