Old 10-20-2004, 09:08 PM   #526
Project D's Avatar
Default NS12S5
Any1 have the NS12S5?... how about it?...
Project D is offline   Reply With Quote
Old 10-22-2004, 11:24 AM   #527
Default Drake Novarossi
Hi all:
Seems like most of you are onroad racers. However, I am hoping you can help with an offroader question.
I have a Drake Edition Novarossi in my offroad truck. It's a side exhaust motor and the port timing is perfect for gas truck. However, since Trinity no longer imports Novarossi, the motor has disappeared.
Is this motor still manufactured by Novarossi but distributed under a different part number?
If not, does anyone have any contacts where I can purchase new motors, pistons, and sleeves for this motor?
Thanks!
toddzhere2 is offline   Reply With Quote
Old 10-22-2004, 05:04 PM   #528
Team-RTR's Avatar
hi guys, what is the performance of hte RR12L3 like compared to the NS12S3. which one is the faster motor, and which one lasts longer? thanks!
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 10-22-2004, 08:46 PM   #529
rcabj's Avatar
i did ask a LHS ...and he told me the main difference was :
RRL - more torque
NSR- more high speed
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 10-22-2004, 09:31 PM   #530
bcquick's Avatar
)l
bcquick is offline   Reply With Quote
Old 10-23-2004, 02:05 AM   #531
ziggy12345's Avatar
Originally posted by bcquick
RR has .20mm less stroke and .21mm bigger bore then the
ns or nsr
so its a short stroke motor compared to the ns.
they are both listed as same hp but 200 less rpm for the rr.
they should last equal amount of time as they are same material.
you probably wont feel a differance between the two in power band.
if they were real engines the short stroke would turn more rpm and make more hp at a higher rpm , and last longer ,as the short stroke long rod has a better rod ratio which means less side load against the sleeve, but according to novarossi theis is not the case
hope it helps (now iam confused) lol
The RR is a long stroke engine with a smaller bore. I have both engines and the RR has a massive amount of torque.
I got my best times with this engine. You have to gear up to get the top speed in the straight but this doesnt affect the low end power as it has it in spades
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-23-2004, 02:06 AM   #532
ziggy12345's Avatar
Small track RR12L3. Long track NSR.
The one you run in the best and run cooler will last the longest
Cheers
Sponsored by:
Norfolk and Chance
Old 10-23-2004, 02:21 AM   #533
Default Set up help
Hey Ziggy,
Where can I find some set up sheets for the fw05r
opposite lock is offline   Reply With Quote
Old 10-23-2004, 02:26 AM   #534
ziggy12345's Avatar
Default Re: Set up help
Originally posted by opposite lock
Hey Ziggy,
I just read through the forum and see what everybody is using
Gold springs on the rear with upright shocks
Black on the front laid down
35 weight oil in the shocks
Lots od droop on the back 2mm at the front
2 deg toe in at the back 0 at front
Hope this helps
Cheers
Sponsored by:
Norfolk and Chance
Old 10-23-2004, 02:29 AM   #535
Thanks Ziggy but I'm after some actual set up sheets
Old 10-23-2004, 07:02 AM   #536
bcquick's Avatar
ziggy is correct
RR long stroke small bore ns short stroke large bore,
rr more torque less rpm .
I read it backwards from there web site .
Old 10-25-2004, 11:53 AM   #537
Default Drake Edition Novarossi
AFM
If not, do you have any contacts where I can purchase new motors, pistons, and sleeves for this motor?
Thanks!
Old 10-25-2004, 01:00 PM   #538
afm
afm's Avatar
Default Re: Drake Edition Novarossi
Originally posted by toddzhere2
AFM
Thanks!
Well, you have a problem there, because that engine was an exclusive product for Trinity. The new distributor for Novarossi, I understand is Mugen Racing USA, but the engine they are offering for off-road trucks is this one
http://www.mugenracing.com/mtseries.htm
It is a long rod Mugen MT12 redesigned for off-road trucks, but it is a rear exhaust engine.
I would suggest you contact them.
AFM
afm is offline   Reply With Quote
Old 10-25-2004, 01:09 PM   #539
AFM
Thanks. Do you happen to know what trinity's part number was for that motor?
Old 10-25-2004, 01:16 PM   #540
afm
afm's Avatar
AFM
No, I sorry
AFM
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
