Like Tree195Likes
Novarossi engines thread
Old 11-21-2014, 03:01 PM
  #4906
blis's Avatar
Two things... An answer and a question!
1)A: When checking the number of turns on the bottom needle, its referring to the thread left on the needle, so pull open the throttle before you try.
2) Q: Whos got tips for keeping a carby fixed to a nova. I over tighten the carby screw on the block and may have snapped it. Any tips?
blis is offline
Old 11-21-2014, 06:49 PM
  #4907
Default Carbie
Harry.
Remove the locking blocks from the carbie and the side with no thread, remove half a mil from the very inside this will allow the 2 blocks to come closer together
fairgo is offline
Old 11-21-2014, 10:56 PM
  #4908
blis's Avatar
Originally Posted by fairgo
Harry.
Good idea.. will try that.
blis is offline
Old 12-10-2014, 09:46 PM
  #4909
Hello, would anyone be familiar with the ISON .21 7 port or the ISON .21GT rally motor from nova? I'm driving an IGT2 with an axial .32 and ofna 086 pipe now but I want to replace the motor with something that will give me more top speed.im not racing just looking to have good motor that's better than the current setup.
thanks for the help.
JRodIGT is offline
Old 12-11-2014, 03:15 AM
  #4910
Grinder's Avatar
Either of those engines will give you better top speed than that .32. The 086 pipe you have will also work on the Ison engines.
The Ison 7 port will have more power, and top speed than the Ison GT. The Ison gt will run cooler due to the large GT specific cooling head.
Grinder is offline
Old 12-11-2014, 07:01 AM
  #4911
Thanks Grinder!! I know what motor I am getting now. My LHS is trying to push an Rd concepts TM928 on me but that's not what I am after. Thanks again! !
JRodIGT is offline
Old 12-15-2014, 11:02 AM
  #4912
Why is it so hard to get a Novarossi motor in Canada?
JRodIGT is offline
Old 12-15-2014, 11:23 AM
  #4913
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 40 (100%+)
Would there be any problem trying to use the Nova ISON GT engine in on a 8th buggy offroad?
I assume the GT has more rpms because its for onroad.. but would it be ok to use offroad?
lagcisco is offline
Old 12-15-2014, 08:29 PM
  #4914
If i am correct there are two versions of that motor. A GT 5 port rally version and a 7 port on road version
JRodIGT is offline
Old 12-15-2014, 11:00 PM
  #4915
Roelof's Avatar
You can always use such an engine, probably you have to run a smaller pinion because onroad engines have less bottom torque. The main problem you will face is milage, for sure 8+ minutes can be difficult to reach.
Roelof is offline
Old 12-17-2014, 03:03 PM
  #4916
afm
afm's Avatar
Default IMPORTANT ANOUNCEMENT
NEW NOVA DISTRIBUTI¿ORFOR USA??? and Serpent America is out ???
http://www.novarossi.it/2012/index.p...ouncement.html
AFM
afm is offline
Old 12-22-2014, 03:46 PM
  #4917
Taylorm's Avatar
AFM
Anyone know what happened??
Taylorm is offline
Old 01-08-2015, 05:17 AM
  #4918
If anyone have a crankcase for Nova Flash .12 PT/PTS (09659N-11) that you might be interested in selling please let me know.
Sti2 is offline
Old 01-08-2015, 09:02 AM
  #4919
simple question: i bought my 2nd ISON .21,but the pinch(not break in yet) is worst than my first ISON(ran more than 2 gallon)
Do anyone facing this before
kyosho malaysia is offline
Old 02-12-2015, 10:54 AM
  #4920
Trader Rating: 2 (75%+)
I have a question about the .12 Virtus
I bought one when it 1st came out. I probably have have about 3 gallons but I'm going on my 2nd main bearing already. I haven't over heated the engine but for what ever reason the bearing is going bad.
I ran at the Airtronics race last weekend and blew 2 glow plugs in the main. After checking the conrod, we discovered it has a little play and needs to be replaced. We measured the pin on the crank and it was within specs just in case it was worn.
What would cause my bearing to go out so fast? 2 $100+ bearing in less than 1 year is a pretty steep price to pay. I decided to just order the complete rebuild kit. Anyone have any ideas what would cause this?
kingtito is offline
