Like Tree32Likes
Old 09-12-2014, 07:19 PM   #4891
Pit-racer's Avatar
Is it possible for two buttons with the code 28011 be different? A friend from California sent me a button but one is thinner than the other.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 09-13-2014, 01:37 AM   #4892
Roelof's Avatar
Send a message via ICQ to Roelof
Could be, then probably the number of dots on the buttonheads are different. But it is not real different it is just the tolerance.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 09-15-2014, 05:44 PM   #4893
Flyin Hawaiian1's Avatar
Nova ISON GT got it done once again at the at the ROAR Region 1 Onroad Championship in Port Jervis, NY over the weekend. Took home the TQ, 1st place and the Regional Championship title. Thank you Serpent America and Novarossi for equipped me with this awesome engine.
Andy Liu "Flyin' Hawaiian"
Flyin Hawaiian1 is offline   Reply With Quote
Old 09-25-2014, 04:28 AM   #4894
Whats the difference between the special bearing and a regular novarossi 11.9 bearing?
Im curious because, I have a modified flash crank I would like to put in a keep on. When I measured with calipers, they're the same. So whats the real difference?
JOE SI is offline   Reply With Quote
Old 10-04-2014, 09:43 AM   #4895
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
Default engine.
So I bought a used car and engine from an rctech member.
Did a little reading about this engine.. Likes to implode or so I've read. Hope mine engine is OK.
It's a novarossi max sl3 with novarossi efra 2652 pipe.
Couple of questions since I couldn't find a manual.
Which glow plugs are recommended?
What should the initial needle settings be so I can try to start and tune it?
How much nitro % fuel? My local hobby shop carries VP fuel so I thought about buying that.
What type of oil do I use for the air filter?
Anything else I should be aware of when firing her up?
lagcisco is offline   Reply With Quote
Old 10-04-2014, 12:00 PM   #4896
TeamCarnage's Avatar
Trader Rating: 22 (100%+)
I've got one of these. Mines got a little over 3 gals. on it. I changed the rod at 1.5 gals. Runs very well.
I run O'Donnell 77 plugs in my .12s. I would run a #6 Nova plug.
The idle gap should be around .5mm. The low speed out from bottom 2.5 turns and the High speed 4 turns.
If it was running before you bought it, I would try to start it. I'm not a big fan of twisting the screws all the way in.
Novarossi sells a bottle of oil with their filters. Otherwise,I have a quart of Golden Spectro I got at a motorcycle shop. I kind of like it better because it's blue and you can see how much your using and leaving on the filter.
I run VP Powermaster and use 16%.
I would personally tear the engine down for a thorough inspection.
Hope this helps, Good Luck
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is offline   Reply With Quote
Old 10-06-2014, 10:18 AM   #4897
Thanks Nick!
Went to 3 diff hobbyshops and none had Nova #6 in stock.. will try online shops now, hopefully she fires up without too much fuss.
Old 10-06-2014, 09:16 PM   #4898
nitrodude's Avatar
Thanks Nick!
http://www.serpentamerica.com/shop/home.php?cat=84
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 10-07-2014, 04:37 AM   #4899
rossland's Avatar
Hi guys need help here. Can the novarossi ISON 21 fit into serpent 966?
rossland is offline   Reply With Quote
Old 10-07-2014, 07:29 AM   #4900
Pooh2's Avatar
Send a message via MSN to Pooh2
Yes!
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 10-07-2014, 07:55 AM   #4901
rossland's Avatar
Originally Posted by Pooh2 View Post
Yes!
Thanks man
Old 10-24-2014, 10:32 AM   #4902
Is Nova coming with Virtus .21 replacement soon or factory modded at least ?
RGKL is offline   Reply With Quote
Old 10-24-2014, 10:39 AM   #4903
dan_vector's Avatar
Trader Rating: 26 (100%+)
Factory mod pre run is already available. The virtus is still fairly new and just rolled out to.12 and offroad engines so doubt it'll be succeeded anytime soon
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is online now   Reply With Quote
Old 10-28-2014, 03:07 AM   #4904
WildManDriving's Avatar
Trader Rating: 29 (100%+)
Long short because it's my first post in the IC on-road thread, I've just picked up my first IC on-roader (MTX6) with a background of EP on/off road and IC OFR.
Being a Nova fan but only planning to race club level I'll be buying the ISON .12 and was after pipe and header recommendations?
Thank in advance,
M.Ellis
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 10-28-2014, 03:07 AM   #4905
Thank in advance,
M.Ellis
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
