Like Tree9Likes
Old 04-23-2014, 10:37 AM   #4786
Hey guys how much liters of fuel does a .12 (PT, KEEP ON, Virtus) takes before you start loosing power?
speed6 is offline   Reply With Quote
Old 04-28-2014, 09:07 AM   #4787
I've run about 7 tanks through my ISON .21GT using VP Master Basher because I had a brand new gallon of it. Would I gain much from switching over to 25%?
Also the temps are not staying up once the car starts moving and even with the body on and doing a few blasts temps never go over 200-205. Runs well as far as I can tell. Probably running a little rich up top?
BuddyBaja is offline   Reply With Quote
Old 04-29-2014, 06:34 AM   #4788
At this point in the break in you can start to lean out the top end slightly each tank or so. This in turn will give you more heat and slightly more RPM. Heat is absolutely essential to a perfectly broken in Novarossi. You will also notice the motor will go rich as it starts to break in more and more. Keep at it you have a long way to go till she drops.
As far as the VP goes, I run the 25% VP Powermaster and I really like it. The race blend will render more power but you also are taking out a good percentage of oil. A lot of people I've talked to run the 25% VP with an ounce or two of Klotz Benol. I run the castor oil in the VP as well. Little castor oil adds a safety net. Id start with 2 oz if you are newer to tuning to add a little safety net in case we go a little too lean, or if you are comfortable with tuning try 1 oz.
TerribleTy is offline   Reply With Quote
Old 05-03-2014, 08:13 AM   #4789
HHH
HHH's Avatar
I just ran in and race tuned a Kangaroo .21 I bought in 2011. Everything was great, nice color on the piston, no scratches, I had excellent fuel (which is rare), etc.
When changing the conrod all went very smooth until I could not get the wrist pin out of the piston. I removed the clip covering the open end of the pin and could not push out the pin by pushing on the closed end. I got my heat gun out and tried heat with no luck. I then tried to take out the other side clip and half came out and half of the clip stayed in (clip broke). The pin is still stuck in the piston. I have changed many rods before and usually if the pin is stuck--with enough force it eventually comes out. I have never had a kangaroo before.
Any ideas why the wrist pin won't come out? Any solutions?
Sam
HHH is offline   Reply With Quote
Old 05-03-2014, 07:13 PM   #4790
Got about 5 more tanks through it. Leaning It out little by little because as you stated it started to go rich. I think the JP2 pipe is holding me back and wanted to know what you thought about the 41019c with the 9886. Right now I am more interested in speed and just having fun. Also it came with 8 mm insert installed. If I went bigger it would give me more power up top but with less tq correct?
Old 05-04-2014, 11:10 AM   #4791
Thumbs up
The 41019-c and 9886 combo is going to be the best for a GT. The JP-2 pipe isn't too bad but in my opinion and tests does not perform at the level the Novarossi pipes do. Increasing the restrictor size will give you more air which means more fuel. I usually run with a 7 to 6mm venturi as I am also looking for good run time. I would continue to break in with the 8mm as that will give you lots of oil keeping everything perfect for break in. After that I'd go with a 7 at max but you can play around and see what you like.
The ISON is a great little motor with tons of potential, you just have to put the break in time to unlock it.
Old 05-04-2014, 11:16 AM   #4792
Yeah I put another 6 tanks through it and it finally got into the 230 range. Running really nice and smooth. I'm going to go ahead and order the novarossi pipe combo and keep the 8 restrictor. I still can't even turn the engine by hand so I think I have a ways to go on the break in.
Old 05-05-2014, 04:06 AM   #4793
Yup sounds like your typical Novarossi. The better break in you do the more power and life you will get out of the motor. Its well worth it in the end. One day your temps will fall off and you'll have monster amounts of power. At that time you have witnessed the Novarossi coming to life. Eventually you'll be pretty close to a full race tune and that is okay, just remember to use the high speed needle to keep the rpms smooth. Too lean up top won't help you with all the work you've put in so far.
Enjoy sounds like you are getting close!
Old 05-05-2014, 09:09 AM   #4794
It has certainly taken some work. Lol. On full throttle I am still getting visible smoke (a whisp if you will haha) having the ambient temps finally come up has certainly helped. I guess I'm just afraid to continue leaning it out especially on the bottom end. It is running butter smooth though and idles for ever.
Old 05-05-2014, 10:52 AM   #4795
Man I guess I have a way to go. I just checked the needles. I'm 3.75 turns out on the HSN and 4.9 or so on the LSN.
Old 05-06-2014, 09:53 AM   #4796
What glow plugs would you guys recommend for the ISON GT? Strictly novarossi? Or is OS okay?
Old 05-06-2014, 12:11 PM   #4797
Thumbs up
Stick with Nova plugs. For racing I like the C8TGT, its a newer plug that is designed for the high stress environment of 8th OnRoad. I've been testing them for a while now and it runs very well. You can also go with the C8TGH which is the go to before the TGT came out.
Old 05-06-2014, 11:58 PM   #4798
PinoyCali's Avatar
Default Pipe/header
Hello All
What is the good pipe combo for nova flash rally .21 ?
PinoyCali is offline   Reply With Quote
Old 05-07-2014, 06:04 PM   #4799
Originally Posted by PinoyCali View Post
Hello All
Novarossi 41019-c and the Super Strong 9886, the go to pipe and header for most. I love it and live by it.
Old 05-07-2014, 10:19 PM   #4800
PinoyCali's Avatar
Thanks Ty.
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
