Like Tree8Likes
Old 01-25-2014, 08:54 PM   #4741
Trader Rating: 23 (100%+)
Originally Posted by GPXJOE View Post
guys my nova flash pt has bubbles on top of the piston and in the combustion chamber on top of the piston. and the engine sound has a rattling noise that sounds as if there is something wrong with the engine. but the engine does not flameout and is running ok. what should i do?
change the bearings?how?
If it sounds like it is rattling then it'll be a bearing change. Whatever you do don't continue to run the engine! Take it apart and change the bearing.
How deep are the pits in the piston and head? You can try to polish these out with very very fine paper you won't get it all out but you may get it better. If the pits are deep then it'll be a piston and liner, rod and head button change as well and that will cost the same as a new engine!! So before you go much further I'd recommend stripping the engine and posting pictures of the piston, head and sleeve on here for us to advise.
For info pitting on the piston is usually caused by running the engine too lean or with too tight head clearance or a combo of both. Bad bearings don't usually present themselves like that unless you've been running it for a period with the bad bearing and it has started to break up.
Good luck and feel free to PM me if you want.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-27-2014, 03:28 PM   #4742
Thumbs up Live Range
Looks like there are 8 new members to the Novarossi line up.
http://www.novarossi.it/2012/index.p...e-engines.html
TerribleTy is offline   Reply With Quote
Old 01-28-2014, 04:14 PM   #4743
GREGORY!'s Avatar
This ia more interesting http://www.novarossi.it/2012/index.p...virtus-12.html
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 01-28-2014, 06:08 PM   #4744
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Originally Posted by GREGORY! View Post
+1
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 01-28-2014, 11:12 PM   #4745
Roelof's Avatar
Send a message via ICQ to Roelof
-1
The .21 Virtus has not shown any improvements promised in the advertisements. Again a special made bearing making the price of the engine and replacement bearings.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 01-29-2014, 03:09 AM   #4746
GREGORY!'s Avatar
-1
That's why we have your mill buddy!
Old 01-29-2014, 07:04 AM   #4747
guys I changed both bearings already, 50dollars. Fine. But theres bubbles on the piston sleeve. To make matters worse, to buy it Costs 200dollars. That's too high,it should be priced at best,half the price of the engine,and a new pair is not available in my local shop.what a pickle!
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 01-29-2014, 03:36 PM   #4748
DS Motorsport's Avatar
The issue you're having is caused by a too lean mixture.
The 'bubbles' are caused by pre-detonation, the mixture ignites too early causing too much heat at TDC. This melts the aluminium.
Also the metallic noise you hear is caused by this.
You can sand the top of the piston and the burnroom with 400 grit sandpaper and finish with 1000 grit.
Then richen both LSN and HSN needle and see if the issue disappears.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 02-01-2014, 12:18 AM   #4749
Not only lean mixture but too tight head clearance as well.
I wouldn't be surprised if the piston side is also damaged. After trying to blend out some of the damage you need to check the head clearance is ok but you need to be prepared that the engine will never perform at 100% now - a replacement piston/sleeve/head/rod will probably restore most of the performance.
Have a go at blending out the damage, run it in again for a couple tanks and see how you go.
Old 02-01-2014, 12:20 AM   #4750
I wander when the Virtus .12's will make it to the online shops? I wander if the offset carb design will fit in my 747. The .21 fits in my 977 ok but its quite a squeeze and I know others have had difficulty with the fit.... If it fits then it will be the engine I use at the WC this year.
Old 02-01-2014, 10:51 AM   #4751
aturbotony's Avatar
I also wondered about that! I had to twist my carb to get it to fit my mtx5. and that is with a Max Motor. It's a tight fit like it is..... Was just curious about that situation.
Tony Thompson / Mugen Seiki USA / RC America / Airtronics / Flashpoint Fuel / Novarossi USA /Jgo paints / DeSoto Racing/ Murnan Modified Motors / Zac Project Tires / My Wife and Kids /
aturbotony is offline   Reply With Quote
Old 02-01-2014, 01:11 PM   #4752
Trader Rating: 4 (83%+)
All new virtus engines come with a new carb with a shorter carb wich will fit all cars .
Shepherd Micro Racing @ Novarossi @ Matrix Tires @ VP Fuels @ Nugget Racing
Roniel_R is offline   Reply With Quote
Old 02-03-2014, 11:19 AM   #4753
Nice. I didn't notice the difference in the online pics but it makes sense. I haven't seen them available anywhere yet. I'm assuming a couple months before they arrive at amain etc.
Old 02-03-2014, 06:29 PM   #4754
The carb looks the same as the previous one that come on the Keep model but the barrel part is shorter,engines should be available mid Feb.
Old 02-03-2014, 10:27 PM   #4755
Thanks for the clarification. I think this will be the engine I take with me to the Worlds this year! I just hope its ok on runtime....
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
