Like Tree8Likes
Old 12-11-2013, 03:26 AM   #4696
It is the 1st thing I would modify if I am in the need of a new bearing. The edge in the crakcase with the smaller inner ring of the bearing does not add any improvement than only bullying other bearing suppliers.
agreed
kyosho malaysia is offline   Reply With Quote
Old 12-11-2013, 04:54 AM   #4697
+1
I haven't seen one of these bearings, but are they recessed more/or in a way, that you couldn't take a "normal" bearing apart and machine the inner ring?
Maybe you get interference on the ball cage...
NitroVein is offline   Reply With Quote
Old 12-11-2013, 05:43 AM   #4698
Roelof's Avatar
Send a message via ICQ to Roelof
I would disassamble the engine and mount the crankcase in a lathe to get rid of the small edge making a normal 14.5x26 bearing possible.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is online now   Reply With Quote
Old 12-11-2013, 06:14 AM   #4699
Flygio's Avatar
... and call it normal! I bring this concept even further: by my opinion the only "normal" bearings are the 1" OD.....
Serpent 977 - Fidelio Telemetry Software
Flygio is offline   Reply With Quote
Old 12-11-2013, 08:21 AM   #4700
didn't feel any performance improvement with the patented bearing like what the nova web said
Old 12-14-2013, 06:13 PM   #4701
Hi, I just bought a new Flash 12 PTS. The original sealed plastic bag where the engine packed in is full with oil. Is it normal or front bearing has had leaking? Thank you.
ongsc27 is offline   Reply With Quote
Old 12-14-2013, 06:18 PM   #4702
blis's Avatar
If you are confident, pull the engine down, clean any excess factory residue, look for burrs etc and inspect everything is ok before you fire it up.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 12-14-2013, 07:10 PM   #4703
Is it possible that novarossi put in some oil to prevent from rust?
If oil leakage from front bearing, any engine performance affected?
Old 12-14-2013, 07:59 PM   #4704
Trader Rating: 23 (100%+)
There is always some oil on the inside of the bag and on the outside of the engine case that has leaked out of the engine during transit. When built NR put quite a bit of inhibiting oil inside to prevent corrosion and so it is only this that has leaked out. It shouldn't have any colour.
Air leaks on the front bearing can cause erratic running particularly at idle and initial acceleration but I doubt you've got an issue with the new engine. Just run it and see.
I always remove the rear cover and head and wash the engine out with the fuel I am going to use just prior to installing and firing up for the first time.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 12-14-2013, 09:08 PM   #4705
Does the oil always seep out from front bearing? Any problem of the bearing? Thank you...
Old 12-14-2013, 09:34 PM   #4706
Yeah I've had engines do that when sat. Not when running though. I think you'll be fine. The only real way to see if you've got a leaking bearing is to run the engine as the engine will suck air inside through the bearing not blow out so it'll drag air in not blow fuel out if that makes sense. Don't worry I'm confident you'll be all good.
Old 12-22-2013, 04:03 AM   #4707
hi guys whats the difference between the different manifolds and pipes that novarossi has? im referring to 0.12 engine pipes and manifolds for 200mm i.c. when you change the type of pipe and manifold, do you even feel the difference? fyi i use nova flash PTA .12
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 12-22-2013, 06:47 AM   #4708
Use the 2660 (51615) pipe with the short or medium (41615 or 41616) header
desotoracing is offline   Reply With Quote
Old 12-22-2013, 07:37 AM   #4709
Thanks Joaquin! I'm a big fan of ur racing team! Congrats on the GT win!
What's the difference from the other pipes and manifolds?
Old 12-22-2013, 07:42 AM   #4710
Oh ya I have a very impt question,to me at least,my pipe has a dent already due to some bumps,how will I know if the pipe is still good or not? And is the pressure line heat sink necessary?salvens 747 did not have one.others do have it
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
