Like Tree21Likes
Old 08-20-2013, 09:54 AM   #4666
Pooh2's Avatar
Send a message via MSN to Pooh2
Originally Posted by peppernick View Post
Collari Lostallo. 1 gallon from new, Byron 25% , 11% lubrication, temped at 107 celcius ..... Steady racing pace ......
I'm happy to hear you admit it was you. My guess, BAD CLUTCH!
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 08-20-2013, 10:09 AM   #4667
wingracer's Avatar
Trader Rating: 23 (100%+)
Fuel.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-20-2013, 08:17 PM   #4668
nitrodude's Avatar
Bad fuel, perhaps old fuel. Ive never seen a rod split like that. Did you change the rod after break in? Also, the bearing looks like it was overheated with all the burnt fuel/oil on it. Something else that could be is that you might have a vibration somewhere on the car.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-22-2013, 11:02 PM   #4669
asw7576's Avatar
Wow
Old 09-03-2013, 09:41 AM   #4670
DDG
Do you guys know if it is possible that the Virtus could reach 9 min. and 30 sec. with a GT car? We run 45 min. race here and would like to pit only 5 times instead of 6.
DDG is offline   Reply With Quote
Old 09-03-2013, 12:59 PM   #4671
Flygio's Avatar
Sure, with a 1L tank
Serpent 977 - Fidelio Telemetry Software
Flygio is offline   Reply With Quote
Old 09-03-2013, 08:32 PM   #4672
No. Keep-On & Virtus get about 7:30 in a GT running hard. Use an off-road engine (BTT or Keep Off) to get run times in the 8-9 minute range. If you are running hard, 9+ minutes will be very hard to achieve. We have not seen anyone running up front at a big race pitting at more than 9 minutes.
desotoracing is offline   Reply With Quote
Old 09-03-2013, 10:06 PM   #4673
DDG
Thanks for the reply desoto.
Old 09-08-2013, 04:39 AM   #4674
Guys, weird problem I am having with my brand new Virtus 21. Idled 2 tanks on bench, and so far up to my 10th tank on the track, the engine dramatically richens itself. It would run well for about a lap, then it will just completely richen itself for a lap, then it will run well for a lap, then it would richen itself. It will just randonly bog down (too rich) then it goes better. And when I say it richens itself, the car will struggle to get going out of corners etc. leaning the top end obviously fixes the dramatically richness, but then the engine then runs too hot (130 c), it also idles high when I come into the pits, and blows little smoke......I don't want to run it this lean so early in its life, so I then keep richening it back and I'm back to my original problem.
I checked the needle settings, top end is only half a turn in from stock needle setting. Bottom end needle has not even been touched yet. Glow plug is very shinny, internals of engine are all excellent. It feels like it has broken in, can turn over by hand now.
Suggestions thanks?
implusepro is offline   Reply With Quote
Old 09-08-2013, 04:57 AM   #4675
blis's Avatar
Suggestions thanks?
Check tank seal, exhaust seals, fuel lines, carby (tight) and carby boot for air leaks.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 09-08-2013, 06:05 AM   #4676
wingracer's Avatar
+1 on Blis' advice. I have had those exact same symptoms from a bad seal between the pipe and manifold and a tiny (and I do mean tiny) crack in a tank. The only way I found that crack was I noticed the tiniest of wet spots on the back of the radio tray.
Team Shepherd USA
Old 09-09-2013, 02:30 AM   #4677
Flygio's Avatar
Throw away the stock glow plug, even if it looks good. Put a brand new c8tgh.
It's easy to find glow plugs....more "plug" than "glow" haha
Old 09-09-2013, 02:31 AM   #4678
Flygio's Avatar
Old 09-09-2013, 10:05 AM   #4679
Default Max Power
What pipe for Max Power RR3?
Thanks in advance.
triple7s is offline   Reply With Quote
Old 09-09-2013, 11:30 AM   #4680
Suggestions thanks?
Hello , the normal temperatur is 130-140 C for this engine with glow plug 8 Nova . If you drive Under this temp you are on breaking in level .
Skem61 is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
