Old 05-24-2013, 01:11 PM   #4636
Originally Posted by jarkko View Post
Maby someone can point me in the right direction to look for a reason for the strange behaviour of my sons Novarossi Flash .12 with 2660 pipe.
Towards the end of a nice training session (about 12 tanks of faultless operation) the engine started suddenly to go extremely rich 1-2 times per lap for a short period like 2-3 secs and then operating well again. No changes were made in any settings. Temps were normal about 125-128 celsius before disaster started and then temps dropped very much. For some reason the engine flooded on its own for short periods and then continued normal operation on its own. When the problem was on it sounded like a new engine during early breaking in and it would not take any higher rpm.
What could cause a normally functioning engine to start suddenly going extremely rich for short periods of time and return to normal? And this repeated very poor / running well / very poor...
Before the session we put in a new air filter and afterwards it looked like the carburator had somehow flooded up to air filter too.
Any similar experiences?
Air was about 20 celsius and weather was sunny and dry.
Check if the carburetor is well fixed in the crankcase....I had a similar condition in the past.
GHN
ghn-sp is offline   Reply With Quote
Old 05-24-2013, 01:51 PM   #4637
afm
afm's Avatar
two possible causes:
1.- glow plug failure......change for a new one.
2.- check for any loose old silicone header gasket inside the pipe....i had this issue once and it was these piece of gasket floating inside, obstructing the pipe´s outlet sometimes yes sometimes no.
hope this hepls
AFM
afm is offline   Reply With Quote
Old 06-13-2013, 09:35 AM   #4638
choisan's Avatar
Anyone knows why the collari 09 is on sale for about US$250?
Any issue with this engine?
choisan is offline   Reply With Quote
Old 06-13-2013, 09:35 AM   #4639
choisan's Avatar
Old 06-13-2013, 09:55 AM   #4640
Roelof's Avatar
Send a message via ICQ to Roelof
I think people do not want it anymore with the many newer models today.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is online now   Reply With Quote
Old 06-13-2013, 10:29 AM   #4641
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
nothing wrong.....maybe some shops is just getting rid of stock.....
I'm distributor of Novarossi in Brazil and the price remains the same.
If I were you, I'd buy it, it's a great engine and for the price you don't get money to afford half of the new engines while performance is almost the same
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 06-13-2013, 04:45 PM   #4642
choisan's Avatar
Old 07-03-2013, 12:34 PM   #4643
wiggindude6969's Avatar
This weekend in Houston, It seemed that everyone was having issues with motors flaming out. The track temp ranged from 125-150 and the actual temp was around 98-100. When the track temp gets that high, what are the affects on the tune?
I tried to richen the bottom end, which helped but after the straight, halfway thru the sweeper the motor would flame out. A lot of guys had the same problem.... I was running the maxy 5 port " off road" with a 6 plug and 6.5 venture. Just looking for tips to help tune when the temp gets hot. The motor seemed to work well when the track temp was under 120... when it got to 150... it kept flaming out. thanks
F104v2 - RSD/TC6.1 - CRCXTi - AE B6
wiggindude6969 is offline   Reply With Quote
Old 07-03-2013, 03:19 PM   #4644
bassman2's Avatar
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 07-03-2013, 03:21 PM   #4645
bassman2's Avatar
As the air temp gets hotter, the general rule is to lean the settings more and use colder plug. If you richen the engine settings while air temp is so high the engine will flame out due to too rich of the settings.
Old 07-06-2013, 07:23 PM   #4646
Not sure where that is on sale at, but I can't find that engine for sale.
Isn't that a Works engine from like 2004???
Hermit 713 is offline   Reply With Quote
Old 07-07-2013, 09:46 PM   #4647
X4
X4's Avatar
Brand new AB Mod .21 Novarossi Keep On Pre Run in (For Sale)
X4 is offline   Reply With Quote
Old 07-07-2013, 09:46 PM   #4648
X4
X4's Avatar
Old 07-07-2013, 10:31 PM   #4649
choisan's Avatar
no, it was offered from our local distributor, it said NR is putting all factory left over parts to build up and then to fulfill the order. i didn't manage to get one.
Old 07-16-2013, 06:16 PM   #4650
Does anyone know where I can purchase a 35plus Piston.
On the Novarossi website it has its own part#06008, so can it can be ordered/purchased by itself?
ace16 is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
