Old 02-18-2013, 03:18 AM   #4531
shanwright's Avatar
Trader Rating: 25 (100%+)
Thumbs up Thanks
Originally Posted by wingracer View Post
I'm a .21 guy not a .12 guy but knowing Nova the way I do, I think I can shed some light on it.
Generally Nova uses a letter and a number to identify their rods. The first letter denotes what it is for (R,C,P,N, whatever). Any motor that has an R rod in it can use any other R rod. So if you have a 2000 era .21 with an R2 rod, a modern R7 will fit it.
The number is the version of that particular size rod. The higher the number, the newer the rod.
Now again, I don't know the recent .12s but if Nova's nomenclature remains the same, any motor with an N1 rod can be replaced with an N2. The 2 just means it's an updated design and they are usually better.
Of course, sometimes even the same numbered rods get updated. I just replaced an R7 09 rod with an R7 13. Though they are the same part number, they are noticeably different. Both are dimensionally the same and will work just fine.
Thanks sounds right.
Steve
shanwright is offline   Reply With Quote
Old 02-18-2013, 04:07 AM   #4532
asw7576's Avatar
The most right looks like a bad bridge in the exhaust port. The other 2 I have seen more. Probably caused with the combination of a tight pinch, low lubrication and to fast on the throttle after a cold start. All of these problems I have seen were with the latest version of the microcasted piston about 2 years ago. After that they switched back to the CNC piston and made some cooling channels just under the exhaust port (flash models).
Thank you
Old 02-18-2013, 12:22 PM   #4533
Default engine advise
Hi,
I am looking to replace my 353'08 which i drove for much joy the last couple of years. I am a serious clublevel racer on a large fast track. As my budget is thight I need the best value for my money but still being reasonably competative.
I can get a new 353'08 for EUR 180 ($240) or move up to the newer and more expensive ones, like:
* 353 race .12c/tuned or flash tuned -2010 --> both EUR 290
* flash .12PT tuned or keep-on 12 tined --> both ~EUR 340
I find the price difference between the 353'08 striking and am wondering if they gives enough performance to justify the extra money.
Thanks!
ma_RC_el is offline   Reply With Quote
Old 02-18-2013, 06:17 PM   #4534
any one know when Nova will release the next .12 like the new Vir-tus.21??
jorge858 is offline   Reply With Quote
Old 02-18-2013, 07:16 PM   #4535
bcebwecb's Avatar
They probably released only the .21 engines just because the 1/8th Worlds are coming soon.
Brandon Cho
1 Corinthians 10:31
_______________________________________________________________________________
Team ARC USA - Hobby Authority Distribution - TiTAN BLITZ - Prolevelrc
bcebwecb is offline   Reply With Quote
Old 02-19-2013, 12:49 AM   #4536
Default Exhaust for .12 Keep On
Dear all,
i have a Capricorn 2662 exhaust how does it work with the Keep On .12
or would you recommend a Nova Exhaust and which one please.
speed6 is offline   Reply With Quote
Old 02-20-2013, 09:42 AM   #4537
Originally Posted by speed6 View Post
Dear all,
The Nova 2660 is their latest and best combo of power and fuel mileage. I think it will compare similarly to the Capricorn 2662.
These are probably your best bets...you can further tune using different manifolds.
Breckenridge is offline   Reply With Quote
Old 02-20-2013, 10:20 AM   #4538
DS Motorsport's Avatar
Dear all,
The Capricorn pipe will give very good mid and top end power.
It's a very good exhaust which works well with all Novarossi and also Picco engines.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 02-21-2013, 12:04 AM   #4539
mick8488's Avatar
Hi Guys,
Have been running the Plus 12-3sct with a 2652 pipe combo for the last year in my MTX5, but have struggled on getting 5mins of runtime (even with gas cooler) and poor bottom end acceleration. Recently switched to a Max Power 2649 pipe and very impressed with the difference. Now reaching almost 6mins and the bottom end is ballistic! The 2649 really makes it scream!
Has anyone else noticed this with the 2652 pipe? Is it thirsty?
Cheers,
Mick
NOVAROSSI WORLD s.r.l.: RACE ONE OR CHASE ONE
mick8488 is offline   Reply With Quote
Old 02-21-2013, 12:05 AM   #4540
mick8488's Avatar
Double post
Old 02-22-2013, 11:03 AM   #4541
asw7576's Avatar
Can someone help me ......... I lost my confidence determining when the engine has completed break in process. I am in the process of break in new piston sleeve...... the Top Dead Center is still very stiff even without glowplug. However, the engine sound ( idling rythem ) is perfect and it can idling for 4 tanks. Right now, i think , the engine has completed 12 tanks. I use " heat cycles : 4 tanks stop and let it cool interval ". This sunday I will continue the break in process on the track. How do I know the break in process has been completed ?
Old 02-22-2013, 07:08 PM   #4542
nitrodude's Avatar
I have an old 359, does anybody know the P/N for the P/S set? Or what other engine set is compatible? I want to rebuild it and keep it as a practice motor.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 02-23-2013, 12:50 AM   #4543
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
See if that helps Nitrodud
http://www.novarossi.it/2012/images/...0RACE%2021.pdf
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-23-2013, 04:19 AM   #4544
wmay11's Avatar
35+ will work in there
RX8 - Savox - Reds Racing - Ko - Contact - Enneti
wmay11 is offline   Reply With Quote
Old 02-23-2013, 05:09 AM   #4545
Pooh2's Avatar
Send a message via MSN to Pooh2
The rod is different. It won't work because of the pin on the crankshaft is smaller.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
