Old 12-11-2012, 02:48 AM   #4486
Roelof's Avatar
Send a message via ICQ to Roelof
The keep on has a different bore/stroke and does need some cut outs in the sleeve to prevent the rod is hitting the sleeve. With the bore/stroke difference I doubt the JP P/S set is also giving the right offset and timings for a Keep-on crankshaft/crankcase.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 12-12-2012, 08:47 AM   #4487
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
so with that being said can i use the p/s/r set #08569 in the R09 case just checking thanks for the help guys
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 12-12-2012, 11:09 AM   #4488
Roelof's Avatar
Probably it will work but you will end up with a smaller capacity, somewhere 3.3~3.4cc
And still I can not say something about the offset of the ports and timings.
Old 12-12-2012, 07:31 PM   #4489
thanks
WILLIAM PENDERGRASS
Old 12-25-2012, 02:06 AM   #4490
Originally Posted by stefan View Post
If you can get your hands on them, Sirio plugs are awesome. IDM is the same plug btw.
I have the same problem plugs keep dying very easily. What sirio plug do I need?
speed6 is offline   Reply With Quote
Old 12-27-2012, 08:41 PM   #4491
beaim's Avatar
Trader Rating: 8 (90%+)
Send a message via MSN to beaim
INSTATE OF 0.3 SHIM ON 16 %. SOME ADVICE GIVEN IS ADDING 0.1 SHIM ON IT TOTAL 0.4.
beaim is offline   Reply With Quote
Old 12-28-2012, 02:08 AM   #4492
Roelof's Avatar
Indeed, some engines have a tight compression not giving any tolerance on a lean setting.
Also take a look at Merlin Glowplugs, very good and affordable. They can handle a lot.
Old 12-28-2012, 04:23 PM   #4493
DS Motorsport's Avatar
Sirio 6 for a .12 and 16% nitro. Might need a 7 when you use more nitro.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 12-28-2012, 07:41 PM   #4494
Stick with Nova plugs. You'll damage the threads when you use other plugs. If you want a colder plug try a C7GTF or C8TGH. The C8TGH is a very tough plug and it should never blow in a .12.
desotoracing is offline   Reply With Quote
Old 12-29-2012, 04:34 AM   #4495
if use C8TGH,would the performance effected?
kyosho malaysia is offline   Reply With Quote
Old 12-29-2012, 06:18 AM   #4496
bassman2's Avatar
The tunning window will be narrowed slightly but you can tune the engine slightly leaner.
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 12-29-2012, 06:58 AM   #4497
HHH
HHH's Avatar
The owner of ORCAN engines told me that plugs need to be fresh/new. If a plug is in the package for more than 6 months--the life and performance of the plug decreases a lot. He also told me that Nova changed their manufacturing for the better in early 2012. He is a big fan of the nova C7GTF plug for .12 engines.
Since getting fresh/new C7GTF plugs (for 4-5 months now), running in tropical (hot and humid) weather, I have had my best lap times, my plugs now last 2-3 times as long as they used to and there is no noticeable difference in power over the 6F.
I am a believer.
Sadly, it is hard to tell the manufacture date of plugs so buy from someone who you trust and who gets them as direct as possible from Nova.
HHH is offline   Reply With Quote
Old 12-29-2012, 09:32 AM   #4498
leaner would it effect when reach the peak rpm and also the engine life?
Old 12-29-2012, 09:36 AM   #4499
I am a believer.
do you mean the filament will oxidized if keep it too long
Old 12-29-2012, 12:44 PM   #4500
bassman2's Avatar
Will give you slightly more power overall. As long as the engine is properly tuned overall then engine's life will not be compromised.
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
