Like Tree8Likes
Old 10-07-2012, 10:59 AM   #4441
Thumbs up
Originally Posted by greg.dawn View Post
we have used o'donnell plugs they were cheap and the white dose not fall out and wreck your engine but i is a personal thing we got heaps when they were about $4.oz each and they are hard to get now can run for a lot of race events
greg
kyosho malaysia is offline   Reply With Quote
Old 10-07-2012, 11:02 AM   #4442
Originally Posted by hobbs View Post
what o'donnell plugs did you use???
77 or 97??
use 97,99 will lost some power
Old 10-10-2012, 08:48 PM   #4443
What is the difference between 35 plus 21, flash 21, and keep on 21?
howard85may is offline   Reply With Quote
Old 10-10-2012, 09:01 PM   #4444
X4
X4's Avatar
Fast, Faster and Fastest
X4 is offline   Reply With Quote
Old 10-10-2012, 09:10 PM   #4445
Why is the keep on cheaper? On amain it's 489 and the flash is 575?
Old 10-10-2012, 11:23 PM   #4446
Spillertwo's Avatar
Difference between them is also age:
the 35 Plus has been around for a while
the flash was last years new engine
the keep on was this years new engine
No idea why the keep on is cheaper, normally it is the other way around.
Maybe amain bought a big batch of keep on's for a low price.
Maybe the keep on is more difficult to sell because it has a very special and expensive main bearing.
Maybe the flash is getting rare and price goes up because people are still looking for it.
Just my thoughts :-)
Spillertwo is offline   Reply With Quote
Old 10-10-2012, 11:43 PM   #4447
So the flash just came out last year? I just recently started following Novarossi lineup.
Old 10-11-2012, 01:53 AM   #4448
Roelof's Avatar
Send a message via ICQ to Roelof
Depending the driver there are more options....
fastest - slower - slowest
controlable - uncontrolable -wrecked
5:00 - 4:45 - 4:30 (runtime)
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 10-11-2012, 02:00 AM   #4449
Roelof's Avatar
The flash is already for serveral years on the market but they have changed it from time to time as they have done it with the 35+.
Regarding the "special" bearing of the Keepon, as far I have seen you can mill out the edge in the crankcase and place a normal bearing.
Old 10-11-2012, 02:23 AM   #4450
One more thing I don't like about the Keep-on. It is using a special exhaust seal which is only available from Novarossi and goes for around 12 Euro a pop
fulcrum2 is offline   Reply With Quote
Old 10-11-2012, 02:35 AM   #4451
Ok, so with the best driver, all other variables being equal, the keep on is the fastest? I see some flash and keep on with the "A" or "S" behind the name. Does this mean steel and ceramic bearings? Also, i looked on kamikaze rc website and they have some listed as "S" and full ceramic. Aren't they the same thing?
Old 10-11-2012, 03:01 AM   #4452
Roelof's Avatar
Does it matter if it has a light cooling head? (just a few grams)
Does it matter that it has a lowered head? (comes most of the time with more heat in the engine)
Does it matter if it has a steel or a ceramic bearing? (most drivers can not notice the difference)
You have to think about the engine itself and not the gadgets which comes with it. If you are no fast driver all those gadgets will not help to get you close to the toplevel drivers..
Old 10-11-2012, 04:51 AM   #4453
GREGORY!'s Avatar
Roelof,i think that a ;good; 35 plus 21 with steel bearing is a faith dog!
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 10-11-2012, 09:56 PM   #4454
Why doesn't the keep on have coated piston like the flash? Is it better material?
Old 10-12-2012, 02:36 AM   #4455
Roelof's Avatar
Before the coated pistons there were a lot of issues with damaged pistons at the exhaust port, they looked like they had to less lubrication in conbination with a tight pinch and so the surface of the piston showed as it was rubbed.
The coating was a some kind of DLC which creates a very low friction surface. But after running in the part where it touched the sleeve most had no coating anymore. Probably they have done it to give it a smoother run-in for not damaging the piston.
In the real automotive industry (as I was tod for sure with Mercedes) this is also done a lot on the crankpins.
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
