Like Tree8Likes
Old 08-01-2012, 09:13 AM   #4366
Roelof's Avatar
Send a message via ICQ to Roelof
No, it is a mater of more friction and less lubrication. Because the piston expands more at the exhaust side because it is much hotter over there the piston will create an egg shape pushing against the sleeve. Because there is no transfer port there is also less lubrication. With both things hapening it can create scratches and the amount and how deep is depending how carefull you are heating up the engine.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 08-01-2012, 09:59 AM   #4367
asw7576's Avatar
This is brand new engine with dirty manifold and pipe.
It happened twice with the same manifold and pipe ( 3 years I never clean the inside, ie. dirty )
The engine quit working after just few laps. I check the engine exhaust port and notice big scratches on the exhaust port.
I suspect the turbo charge effect ( or sonic pulse created from the pipe's cone ) is pulsing back some carbon dirts from manifold into combustion chamber.
Old 08-01-2012, 10:12 AM   #4368
asw7576's Avatar
Roelof, I'm not engine expert though ......
I'm open to your ideas or anyone ideas.
My mechanic said the main bearing is not good ..... however this is brand new engine.
No problem whatsoever during break in process.
It happened on its first day of racing ( heat 1, dnf, 5 laps and done ).
Old 08-01-2012, 06:59 PM   #4369
blanks596's Avatar
Trader Rating: 14 (100%+)
that's most likely not due to a dirty pipe-I had the same thing happen on a newly broken in engine and new pipe set (JPGIMAR Mig 21 R09 prerun). Piston got stuck at the top of the sleeve and shut the engine down during a race. Open it up had very similar scratches on the exhaust side.- I'm still running this motor without fault several gallons later- I was told the same thing; to properly warm the engine before racing as well as avoiding certain fuel brands
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 08-01-2012, 11:29 PM   #4370
Roelof's Avatar
That I have seen more and was related to the last batch "microcasted" pistons and since that they have switched to the CNC piston in combination with small lubrication ports just under the exhaust port and later on to coated pistons. Novarossi knows what did go wrong but do not tell....
We have discussed about this issue and someone mentioned it could be a cold weld due the tigth fit. Normally an engine will stop/lock itself when the engine is not fuly runned in and you want to go to fast during the warm up. With this piston it seems it locks itself and directly has broken loose to run on. I could be a lack of lubrication with a different material piston.
In my previous post I was talking about tiny visable scratches not a compleetle damage surface....
Old 08-01-2012, 11:43 PM   #4371
I concur with Roelof. I've had several painful and expensive experiences where my very new pistons looked just like the ones you've posted.
Causes : Not enough lubrication + mixture too lean.
Exhaust port section of the piston heat expands more and couple with a lack of oil, jams itself against the port opening on the liner. It has nothing to do with a 'dirty' manifold or pipe.
Since my experience, I stopped using fuel with less than 11% oil and more specifically full synthetic lubrication fuel. Castor oil gives better high temp and RPM lubrication. A good mix of synthetic and castor oil is imperative for these ultra high revolution on-road engines until technology gives us better synthetic oil for our micro engines.
Also, once I feel my engine is peaking, I back off the HSN a little s that I can be sure my engine is if anything slightly on the 'rich' side.
peppernick is offline   Reply With Quote
Old 08-02-2012, 12:24 PM   #4372
Those scratches are not caused by foreign debris. Looks like seized piston probably due to a combination of tight engine and high RPM's while engine was cold and sleeve had not expanded.
[QUOTE=asw7576;11042560]This is brand new engine with dirty manifold and pipe.
Wachsmann64 is offline   Reply With Quote
Old 08-02-2012, 10:14 PM   #4373
rip67vdub's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to rip67vdub
Default Which Fuel + Lube combo is recommended????
Pls ignore. PM sent to Roelof.
rip67vdub is offline   Reply With Quote
Old 08-05-2012, 07:43 AM   #4374
theerm's Avatar
What is the difference between c8tgf and a c8tgh . I road race a plus 28 7 port. The c8tgh workes fine but the c8tgf is less expensive .
Any advice ?
Cheers Greg T
People will do anything to loose weight! ! Except eat less and exercise
theerm is offline   Reply With Quote
Old 08-05-2012, 07:43 AM   #4375
theerm's Avatar
Any advice ?
Cheers Greg T
Old 08-05-2012, 10:26 AM   #4376
Default 35 plus 21
do anybody can tell what is the difference between 35 plus 21 and 35 plus 21A
performance and runtime?
thks in advance
kyosho malaysia is offline   Reply With Quote
Old 08-05-2012, 10:49 AM   #4377
Roelof's Avatar
thks in advance
http://www.amainhobbies.com/product_...ine-Turbo-Plug
Old 08-05-2012, 12:34 PM   #4378
Grinder's Avatar
Any advice ?
Cheers Greg T
The c8tgf is slightly colder than the c8tgh.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 08-05-2012, 12:43 PM   #4379
Grinder's Avatar
thks in advance
The A means front, and rear steel bearings. Normally the 35+21 comes with a ceramic rear bearing, steel front.
The A version is a good option if your on a budget, but the ceramic rear bearing will add performance, and runtime. Although slightly.
Old 08-06-2012, 12:57 AM   #4380
thks for the info
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
