Old 05-13-2012, 10:09 AM   #4306
MugenDrew's Avatar
Trader Rating: 24 (100%+)
Originally Posted by GMartinez View Post
Got a chance to test out my Keep on vs my pt this weekend @ Fort Myers
Almost tq'ed the 1st rd with the pt just got spinned out by another driver did 33 laps 7:02 qualified 2nd
then in the 4th rd went with the keep on got a bit more faster made 1 mistake but still got the Tq 34 laps 7:09
Both motors ran great the pt seemed to have a bit more top
The Keep on had more bottom but felt the same to compare top end all in all you can't go wrong either way
Yeah that PT was flying! The KEEP ON, well lets just say there was some magic happening on the in-field. Enough magic that mine are on there way. Good run George!
MUGEN SEIKI NOVA ROSSI ENETTI TYRES HUDY PROFESSIONAL TOOLS
BYRONS FUEL AIRTRONICS RADIO EQUIPMENT PROTOFORM RACE BODIES
MUGEN RACING RC AMERICA AKA RACING NUGGETS RACING DESOTO RACING
MugenDrew is offline   Reply With Quote
Old 05-14-2012, 01:25 PM   #4307
GMartinez's Avatar
Trader Rating: 82 (100%+)
Thanks Drew see ya in a couple of weeks @ the Cow Patty
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is offline   Reply With Quote
Old 05-20-2012, 01:42 AM   #4308
Mazda614's Avatar
Default Broken pistons
Anyone know what causes the bottom part of the piston to breakup. We had two engines one week apart where the piston has broken the skirt all the way up to the bottom of the piston pin. The rod was damaged but still in one piece. Both engines a Nova's, one a 353 and the other a Flash .12. Both engines were running OK and slightly rich as opposed to lean. Both about 18 months old but in good condition and running well before the failures.
OS Speed T1201
Futaba 4PK 2.4Hz
Serpent 748 TQ
M16 Racing Fuels
Mazda614 is offline   Reply With Quote
Old 05-22-2012, 04:32 PM   #4309
roscoe 141's Avatar
Default jp rer3
i have a jp rer3 need a rod ..anybody know a part number for a rod thank you
"BOARDS DONT HIT BACK"
Go real fast and if you lose your break use the boards
Serpent 733,OFNA DM-1 ,KAMIKAZE RACING
NOVAROSSI, DESOTO RACING,Bruckner Hobbies
FLOY BENNETT RACEWAY
roscoe 141 is offline   Reply With Quote
Old 05-22-2012, 08:54 PM   #4310
Grinder's Avatar
07601
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 05-23-2012, 12:27 AM   #4311
i have dropped the skirt off 2 pistons both 353 and flash.
i run at brendale
first one the bearing in the lay shaft dropped causing the second gear to move on the back straight OVER rev .. dropped skirt after 2 runs
the second was stripped 2nd gear at the end of the back straight . broke it the following run
this is just my experience
peter
The_Keeper is offline   Reply With Quote
Old 05-23-2012, 05:01 AM   #4312
Mazda614's Avatar
i run at brendale
peter
No stripped gears or dropped bearings on the two engines, just stopped and on restart attempt the engine was difficult to start but started, half a lap later "pop". Engine seized and piston skirt found smashed off. The flash had run a perfect 20 min B final just before, very strange two engines same failure mode. Only common thing both about 18 months old.
OS Speed T1201
Futaba 4PK 2.4Hz
Serpent 748 TQ
M16 Racing Fuels
Old 05-24-2012, 01:40 AM   #4313
kickass's Avatar
Default Novapistonkaboom
My PTS done exactly the same thing never even raced it just in testing & it wasn't even quick.
Running those OTHER engines now and very happy
"KicKass "OS" Racing Engines" "capricornrc.com.au"
"RC Arena" Home of "Maxima Fuel"
kickass is offline   Reply With Quote
Old 05-25-2012, 03:04 PM   #4314
duneland's Avatar
Default Nova Star
I have a Nova Star (Nova Rossi made for HPI).21 Needs a Piston/sleave and cumbustion chamber. Anyone know of original or newer parts that might fit?
Thanks,
Ron T.
duneland is offline   Reply With Quote
Old 05-25-2012, 06:11 PM   #4315
roadrage's Avatar
What fin header would give you the best runtime for a .12, a 6 or 5 ?
Austin Wolfe
Team RoninRC-Team ARC USA-Trinity/Revtech-www.activRC.com
roadrage is offline   Reply With Quote
Old 05-25-2012, 11:26 PM   #4316
Hi,
Whats the normal operating tempature of a sywc kangaroo .21 on road. Mine is running between 95 and 120 degrees. Its seems still rich?
Capricorn LAB C02
Protoform
Futaba
Sirio
xray man is offline   Reply With Quote
Old 05-26-2012, 12:22 AM   #4317
Roelof's Avatar
Send a message via ICQ to Roelof
Thanks,
Ron T.
The sleeve is so far I know a 7-port sleeve with just 1 exhaust port (no 2 small additional exhaust ports). Bit I wonder if it is a longstroke (16.8 x 16.2) engine or a square stroke (16.4 x 16.4). In case of a long stroke something like a Kangaroo P/S set will fit.
Beside that I wonder what the size of the crankpin is, older engines have a smaller crankpin.
But a P/S/R set can go up to 170-200 dollars while a new engine will cost uou 250-300 dollar. Be wise and get a new one.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 05-26-2012, 01:17 AM   #4318
asw7576's Avatar
I think you will be dissapointted if you expect to achieve longer runtime only by using 6 or 5 fins manifold.
I think you should consider to use pipe ( 2630 ) and non-conical manifold to achieve longer runtime.
6 fins probably will get micro seconds longer runtime than 5 fins. ..... however, ... I'm just guessing with assumption : longer manifold = less top end rpm. Probably I need second opinion for this answer.
Old 05-26-2012, 03:28 AM   #4319
Thumbs up 2630 pipe
i think the 2630 has been replaced with 2660 or some thing like that we were told that the later pipe made more power and we still got run time it was recommended by cap/aus it was used by them all last year we ran 353 n over /5 fin conical header
greg
greg.dawn is offline   Reply With Quote
Old 06-04-2012, 01:56 AM   #4320
Hi
Started running in my pts 21 and noticed after two tanks there is no pinch
I wondering if I got a Pre run engine the piston and sleeve didn't look run
When I had it apart to flush it how can u tell if it's Pre run thanx
monaro is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
