Like Tree34Likes
Old 09-06-2011, 10:33 PM   #4141
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
The non conical short nova header
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 09-07-2011, 01:19 AM   #4142
Tom.B's Avatar
could someone please refresh my memory, what is the differences between the conical and non conical headers?
is it true that the conical headers offer better bottom end?..or am i wrong? cheers
Tom.B is offline   Reply With Quote
Old 09-07-2011, 01:20 AM   #4143
Conical provide more power, less runtime. Whereas non-conical does the opposite (slightly less power, but longer runtime)
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 09-07-2011, 01:21 AM   #4144
Originally Posted by sammies View Post
Hi,
Recently purchased and run-in a 35+21 (steel bearings).
Currently matching it with nova 2015 + 6-fin manifold.
Power is decent at best, but run time is approximately only 4 minutes.
Does anyone have any recommendation for pipe/manifold combination for a large track that offers decent run time (say approximately 4:45?)
Thank you in advance.
Sam
Could also try to adjust your clutch and/or driving style? (not trying to shoot you down, honestly)
Old 09-07-2011, 06:10 PM   #4145
Trader Rating: 13 (93%+)
hi guys looking for a flash pts who has the best price ??
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 09-07-2011, 06:27 PM   #4146
Kamikazercracing.com ships worldwide!
Old 09-07-2011, 08:04 PM   #4147
haha.. No worries That could be a major contributing factor. Will experiment and see what the results are.
sammies is offline   Reply With Quote
Old 09-08-2011, 06:49 AM   #4148
Arahawak's Avatar
Trader Rating: 32 (100%+)
Hi,
Sam
eh.. lean it?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 09-08-2011, 09:47 AM   #4149
Chickentrader's Avatar
You should go to P.J. http://www.radicalrchobbies.com.au/p...ce-engine.html for great price of a Nova engine. You also get the best possible backup assistance, cheap postage and next day delivery to Sydney.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 09-08-2011, 06:38 PM   #4150
Hi guys! Is it advisable to reduce the shimming of button head for my flash in order to gain rpm? And will there be changes in bottom power?
Johny is offline   Reply With Quote
Old 09-08-2011, 07:46 PM   #4151
Tom.B's Avatar
no don't do this, leave the shims stock. Reducing the shims will decrease the squish band and lead to the plug breaking and pitting your head button and piston.
if you want more RPM you can dremel the top edge of the exhaust port just a fraction, i think adding shims will increase RPM, but i'm not 100% sure about this.
i wouldn't be too concerned with RPM, it isn't a measure of power so to say, torque is a better attribute to have as it allows you to gear for top end, whilst still having punch out of the corners.
Turque is an atribute of a lot of factors, so it isn't as easy as a shim here or there. I've fooled around with raising the sleeve height...but i have no idea what this does
Old 09-08-2011, 08:08 PM   #4152
a shorter manifold will give you more rpm
Old 09-08-2011, 11:23 PM   #4153
Don't reduce the shimming, it would only cause problems instead of solving any. Adding .1mm usually moves the power up, but it isn't guaranteed, plus you would lose some bottom end power as well.
A shorter manifold should give you more RPM, at the cost of losing some bottom end power. A different pipe could also make it better all round.
Carefully dremelling the exhaust port to make it open for longer can do the same thing as a shorter manifold, but this is a permanent modification and you could possibly ruin the engine if it isn't done correctly or carefully
You could also go a little leaner (if there is room for it) to get more engine speed, or you could change plugs to one slightly colder, but this would lose a little off the bottom end, and could also make it hard to idle nicely.
It's a lot of trade-off's to get more top-end, otherwise there's isn't a great lot to do.
Old 09-10-2011, 10:25 AM   #4154
Team Kamikaze's Avatar
Today and Tomorrow ONLY!!!
http://kamikazercracing.com/proddeta...d=NOVA35plus21
http://www.facebook.com/pages/Kamika...c/104578818154
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 09-13-2011, 01:30 PM   #4155
Default Novarossi Plus 12-5SCT
How would a old Novarossi Plus 12-5SCT compare to a New .12 PT?? in power??
jorge858 is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
