Old 05-24-2011, 06:42 AM   #4081
dj apolaro's Avatar
Originally Posted by jcrc View Post
Can some one give a comparison of the new PT.12, against the old Flash engine? In terms of power and how the engine works..
For me the midrange power is better on the new motor and milleage is better. I run it with the 2660 and short header and still get milleage.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-25-2011, 03:50 PM   #4082
What turbo plug gives better performance in a +12sct nova #6 or nova#7??
Also what manifold goes better with the nova 2660 pipe the short or medium manifold??
HoboShop is offline   Reply With Quote
Old 05-25-2011, 09:29 PM   #4083
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
#6 and the short manifold
Inf1nity CM Beat1 Racing
Serpent-Dan is online now   Reply With Quote
Old 06-10-2011, 02:57 PM   #4084
what are the differences between the rods 07604/1 and 07604?
Radiopost TS401
SebO is offline   Reply With Quote
Old 06-10-2011, 03:16 PM   #4085
Chickentrader's Avatar
There are no set rules for which plug or heat range of plug that are best under all conditions. It depends on fuel. atmospheric conditions etc. but perhaps this quote from E-bay could give you a general guide:
"Use a hot plug when using fuel with a low nitro content (less than 24%), and a cold plug when using fuel with a high nitro content (25% and higher)
If you remove your glow plug heater from your idling engine, and there's a noticibly large drop in RPM, you may need a hotter plug or a fuel with a higher nitro content.
If your engine tends to backfire often, you may be using a glow plug which is too hot, or you may need to use a fuel with a lower nitro content.
Whether or not yo agree with that information, you really need to try them out for yourself, to see which you think is better. Nearly all the experienced drivers where we race seem to think that plugs that are comparable to Nova 6 are usually the ideal; but then there is one guy who swears that Nova 5 is the ideal, and he has some of the fastest engines????????
The different manifolds are designed for bottom-end, mid-range or top-end performance. The track that you use the 2660 pipe on, should determine which manifold to use. The 2660 is supposed to be a great top end pipe, and we like using it on fast tracks with a 5 fin header.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 06-11-2011, 06:06 AM   #4086
Pirty's Avatar
Trader Rating: 35 (97%+)
Send a message via Yahoo to Pirty
Hello sirs, just wanted to know if the piston,sleeve and conrod of a nova plus 12 will fit and work on an s12 engine? thanks.
SIG KADET SENIOR - YAK 54 30cc - Super Air
RDS-8000
Pirty is offline   Reply With Quote
Old 06-13-2011, 08:30 AM   #4087
spenzalii's Avatar
Send a message via AIM to spenzalii
Question. I have a JP Plus 12 that needs a p/s set. Would any p/s from a base Plus 12 fit? I know finding another JP set will be next to impossible, and would like to know if I had other options besides a stock plus 12 p/s
Thanks in advance. I plan on getting a fresh motor at some point, but would love to rebuild this one. That motor went like stink when it was running
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 06-13-2011, 12:18 PM   #4088
Get the Murnan +12 sct piston&sleeve set it will be just as fast if not faster than before. it will fit it fit in the eagle .12 with is based of of the nova +12sct
Old 06-14-2011, 02:29 AM   #4089
Les
Les's Avatar
Default Conrod
Does anyone know the answer to this question ? re conrod.
Cheers
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 06-15-2011, 04:06 AM   #4090
choisan's Avatar
sorry ahead of time that being lazy for not searching thru this thread, i would like to know if r5 and r7 conrod are inter-useable. thanks a lot!
choisan is offline   Reply With Quote
Old 06-15-2011, 04:10 AM   #4091
Roelof's Avatar
Send a message via ICQ to Roelof
Cheers
I can only imagine the /1 is a newer version, if I do a Google search on it it shows a lightweight rod.
R5 and R7 are interchangeable. Almost all R rods are, I have seen an R2 and an R4 rod fitting as well, keep in mind the R7 must be the strongest of them all.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 06-15-2011, 04:22 AM   #4092
choisan's Avatar
pretty much appreciated. thank you!
so lucky that i just got a set of new piston, nice price, exactly identical to my jp-r03, i am thinking to use the original r5 or to replace to run in with a new r7 instead.
btw, the new pt piston set with underhead, r7 is very good price, only US$250. i almost wanted to use this one for my 99% new jp-r03 housing.
and the price for the piston set of the kangeroo is very nice as well.
Old 06-15-2011, 04:46 AM   #4093
Roelof's Avatar
I am no fan of getting a new P/S set for an used engine. There is always wear on the crankpin and bearings that it will not run as a new one. Before you know it you do ned new bearings as well and by then you could have a fresh 35+ or even a new JP R03 somewhere from Ebay.
I do like to experment with the used stuff I have in a large bag. Building up engines with used parts and see what it does, sometimes I have a good training engine or something I can ruin with driving in the rain.
Old 06-15-2011, 06:13 AM   #4094
choisan's Avatar
i can understand your advice. but i do have 2 brand new cermaic bearing for this r03, and the housing with crank itself is 98% new. so, spending half of the os speed II i recently bought would something worth to make this jp as a practice engine.
by the way, do you have idea if the conrod of the exceed's 21 is the same as the one with the picco's torque(sorry for off topic) no one is able to answer this, they are just there to sell the engines only. thanks again.
Old 06-15-2011, 06:20 AM   #4095
Grinder's Avatar
No. The piston/sleeve is not interchangeable, only the rod is.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
