Old 04-24-2011, 01:49 AM   #4051
rcmike's Avatar
Trader Rating: 38 (100%+)
Default Nova r-1 and kangaroo motors
When putting in new P/s/r in these motors at what measurement do u just say its not worth it cause to much wear on crank pin ? What are the specs on a new crank pin ? thanks
rcmike is offline   Reply With Quote
Old 05-03-2011, 08:07 AM   #4052
choisan's Avatar
Underhead On-Road 37,8mm
can someone kind enough tell me what are the 37 and 8mm? thanks!
choisan is offline   Reply With Quote
Old 05-03-2011, 08:22 AM   #4053
stefan's Avatar
Send a message via AIM to stefan
It's the diameter of 37.8 mm or 1.4881889 inches
stefan is offline   Reply With Quote
Old 05-03-2011, 08:30 AM   #4054
choisan's Avatar
thanks stefan. this data was copied from the turbo head of my jp r03, i just wonder what is it differed from the normal underhead without these 37 and 8mm?
Old 05-07-2011, 05:05 PM   #4055
ralphierace13's Avatar
what is the difference between the long body turbo glow plug and the short?
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 05-07-2011, 06:01 PM   #4056
What do you mean long or short? Here is the list of on-road plugs:
http://www.novarossi.it/eng/products...php?plug=ctuon
For .21 engines, I like the C8TGH. I use it all the time.
Desoto Racing
Novarossi America, Serpent America, TOP Engines, Matrix Racing Tires, ProCircuit, Titan/Blitz Products, Xceed Products, KO Propo, Enneti, ArrowMax
info@desotoracing.com, www.serpentamerica.com
jdesoto is offline   Reply With Quote
Old 05-07-2011, 06:26 PM   #4057
sorry i ment the long body and the short body, also now that i looked at the chart what is the difference between c8tgh and c8tgf?
RALPH FORTUNATO
Old 05-07-2011, 08:54 PM   #4058
Default Flash 21 PT
Anyone has experienced that when tune the engine near peak power then everything is fine for few tanks. After a long rest, the engine will be richen and bugging in low rpm, then give it fulll throttle for a while, it will be fine. Then it keeps richen alittle itself in the same tank.
I read from the new plug. The plug is shiny, little bit wet around, but the surrounding is black.
Any best way to tune this engine?
beebone is offline   Reply With Quote
Old 05-07-2011, 11:44 PM   #4059
Pooh2's Avatar
Send a message via MSN to Pooh2
I think your engine needs to be broken in more.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 05-08-2011, 12:48 AM   #4060
May be, but it ran already 10+L fuel.
Old 05-08-2011, 02:36 AM   #4061
Roelof's Avatar
Send a message via ICQ to Roelof
- check the bearings
- try a different brand glowplug
- check you exhaust system, change the pipe (a loose conus can cause this)
- try a different tank
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 05-08-2011, 03:14 AM   #4062
Try change the head to the old flash head..i've heard from some of my local guys that the new head is sitting too low and might affect the tuning..even in the recent worlds,robert was using the old head in the finals..can give it a try..
tq23 is offline   Reply With Quote
Old 05-08-2011, 10:26 AM   #4063
oic. Yes, the cooling performance is very good, but too cool. May be its a problem.
Old 05-08-2011, 04:38 PM   #4064
Les
Les's Avatar
Hi All, can anyone tell me the diameter of the crank pin on a Nova 3SCT Tuned.
Cheers
Les is offline   Reply With Quote
Old 05-09-2011, 06:16 AM   #4065
Grinder's Avatar
Cheers
4.26 mm
www.murnanmodified.com
Grinder is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
