Old 06-25-2004, 02:12 AM   #391
Originally posted by daniz24
I think the RR is a bit tight too compare to NSR, isn't it darling?
Yes honey..
Like AMG mentioned, the NS and RR is using cnc-machined piston. But in NSR you will find the microcasted already.
Newer batch of NSR, comes with the piston that you will found in MAX S series. Even lighter than before and only have i pit/oil groove in top.
GoldFinger is offline   Reply With Quote
Old 06-25-2004, 03:40 AM   #392
Taylor-Racing's Avatar
Originally posted by jscamry
lol its funny how taylor and amg were speaking about the tinking sound ffrom the engines, that were pinched by osrocket my mt12 that I just had done is doing th e same thing, so this is ok? I have had some other engines worked by osrocket but those did not make the same sound it my memory serves me.
jason
I just don't know. My ozrocket pinched sleeves were all 4mm top spacing and if I recall, a new Nova P/S set is usually about 3.5mm - could be wrong here.
With the persistant "tinking" I just thought I wasn't getting anywhere and probably doing more harm than good. When the rear bearing failed, that decided it for me. Remember too, that this was a X/12 Rody - rather marginal in the crank strength department.
The other thing going through my mind was that a new P/S set has the fresh hone cross hatch that gets polished during the break in. The pinched sleeves were still polished from previous running and weren't going to be helping that situation.
My theory with the bath cleaner was to create a roughened surface that would bed in correctly, reduce the diameter of the piston to lessen the pinch point and also eliminate any out of round situation that may have resulted from the pinching procedure. It may be a bit crude, but seems to have worked OK.
I should also mention that I e-mailed ozrocket my concerns re the 4mm pinch point and he said it was correct and would be fine. Plenty of people swear by his method so I may have been over cautious. I'd use ozrocket again, too, and probably still use the bath cleaner.
Taylor-Racing is offline   Reply With Quote
Old 06-25-2004, 03:42 AM   #393
Originally posted by GoldFinger
Yes honey..
Oh, I thought the RR also used the MCP?
Old 06-25-2004, 03:58 AM   #394
No, the piston is not as good as NSR.
The top coat will break on the 3rd gallon if you are using max temp (110-120 C) all the time.
Old 06-25-2004, 03:59 AM   #395
Originally posted by finchy
I've broken in many Nova engine now and I hate to say this but I've never replaced a rod after break in. I think this is a money spinning idea injected into our heads by the company and it's represententives. That's my 2 cents worth. All my engine have done well over 25 litres of fuel and not one ever had rod failure.
AMGRacer those NS3 are a tight motor from what I've seen at the track.
I'm sure there's some truth in what you say. I haven't changed the rod in the NSR yet and it still feels fine but I guess it's only had about three litres. With the X/12 Rody, I had to feed it rods and bearings regularly - but geez it screamed.
One thing I've noticed with these newer engines using the 11.5mm crank is they seem much more robust in the bottom end. I'm just surprised that an extra .5mm and different bearings have made such a difference.
Just thinking about it, I don't recall anyone posting here that they'd broken a NS or V12 crank. There were plenty of broken S3/S1/X-12 Rody cranks though.
Old 06-25-2004, 04:04 AM   #396
Well isn't that strange. I figured they would use the MCP since the RR is one of the latest generation of NS engines.
Old 06-25-2004, 04:37 AM   #397
BrainTeased's Avatar
I heard it takes like 45 mins to run in the first tank of a NSR engine... how long did it take you guys to run in your first tank of your NS or NSR's?
Also may i please ask where is this OSrocket guy from australia or america? does he have a website or an email?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 06-25-2004, 03:16 PM   #398
Hi
I have got a new NSR 12 engine, and, on the carburator, the middle speed needle, isnt flush whit the carb body, its a few turns in??? Should i leave it there , or adjust it to flush with carb??
Finken is offline   Reply With Quote
Old 06-25-2004, 04:46 PM   #399
jrabbito's Avatar
My came absolutely flush...
jrabbito is offline   Reply With Quote
Old 06-25-2004, 08:10 PM   #400
Ours was a couple of turns in also.
Old 06-25-2004, 08:15 PM   #401
finchy's Avatar
Taylor Racing your right, these new gen cranks seem to hold up alot better than the older one. Alass that's how my X12 Rody went a few months ago. Damn crank.Shit happens
Pilot the BEST MUGEN kills the rest.
Team Ball Banger Racing inc.
OS Speed R2101
Futaba 3PK (HRS) - Crystals still rock.
Old School for Old Fools.
finchy is offline   Reply With Quote
Old 06-26-2004, 02:04 AM   #402
Should i turn it out, flush with carb then??
Old 06-27-2004, 03:54 AM   #403
Good question.
I did.
Old 06-28-2004, 04:19 AM   #404
Our NSR was easy to run in - no problems.
You can e-mail John HERE.
He's in the USA.
Old 06-28-2004, 06:50 AM   #405
He's in the USA.
Thank you very much for OSrocket's email Gav
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
