Old 03-09-2011, 06:54 PM   #3976
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
The one with less is of course lighter but I believe it will have less roll resistance. Which is what I would rather have.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 03-09-2011, 09:01 PM   #3977
Originally Posted by ralphierace13 View Post
also i been told the new head on the flash makes it run alittle hotter if u have the old flash head better to use it..
Wrong, it does not run hotter. It read a higher temp because your temp probe is closer to the glow plug. Actually the lower heads have an extra fin.
Myself and some others Factory Novarossi drivers have tested this head for both sedan and 1/8 scale since the last summer. There is absolutely no problem with reliability, temp and performance of the engine. We even use this heads in Houston, last summer in the sedans!!
The BIG advantage is the lower CG. The Head of the engine is a heavy part of the car that sits high (after the body shell, of course).
By Lowering this one, the handling of the car improves a lot.
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 03-09-2011, 10:56 PM   #3978
I tested with the F21 PT, the new head is really in high temperature, BUT, the overall temperature is very stable, no matter how I drive, rich/lean, the temp keep constant around 120C.
beebone is offline   Reply With Quote
Old 03-10-2011, 01:30 PM   #3979
ralphierace13's Avatar
paolo do u know how much higher is the differance in temp, i just ordered the motor and would help if i knew...
thanks
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 03-10-2011, 01:46 PM   #3980
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
the head being lowered that little, really effects the handeling that much??
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 03-10-2011, 09:37 PM   #3981
To an extent, definitely!
As alot of people have said, the lower you can get the CoG, the flatter and faster you can go through corners (being within all the limitations)
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 03-10-2011, 11:57 PM   #3982
Roelof's Avatar
Send a message via ICQ to Roelof
Maybe for the top 30 world class racers as with electrics those guys can notice a difference if the electric motor is placed a few mm forward. The avarage racer will not notice a thing.....
The few holes Novarossi is drilling in their previous heads are just a few gram. I have drilled 16 holes of 4mm into a head and it did save just 5 gram.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 03-11-2011, 12:07 AM   #3983
wingracer's Avatar
Trader Rating: 22 (100%+)
In 1/12th I can feel the difference in just a 6 tooth difference in spur, and subsequent pinion change, which moves the motor forward maybe 2 or 3mm.
As for a lower head, I doubt you would feel the difference but it may make a very small difference on the watch. Of course most drivers are not consistent enough to be able to find that slight difference in times in all the background noise of poor driving
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-11-2011, 05:11 AM   #3984
thanks
Around 40F
Old 03-11-2011, 05:12 AM   #3985
Yes, specially in the fast corners
Old 03-11-2011, 05:15 AM   #3986
It's not about your level of driving. It's physics. That's the reason why all the car manufacturers are going more and more extreme to lower everything
Old 03-11-2011, 05:26 AM   #3987
Phil Trotta's Avatar
New lower head. Holes. This. That. The plus 35 was a killer motor as the kangaroo. Prices were on the money too. Now a kangaroo is 449.00. And these new motors are over 700 or close to it. Crazy.
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 03-11-2011, 06:32 AM   #3988
Roelof's Avatar
Yes, ofcourse there is a bennefit but new designs in cars and engines must have some changes or else it will not give a boost in selling. Remember the Magnesium heads 3~4 years ago? Did it make a change? Not really or else we had all toplevel engines with these heads. RB had already for several years a lowered head, did they win races because of that?
In my opinion, the new head is just a selling item to show the market improvements and I do wonder when they do run out of ideas, to me it is still a 2-stroke engine based on an ABC construction.
Old 03-11-2011, 06:50 AM   #3989
I still think that the 35+21 and +12sct tuned motors are just as fast as the newer nova engines and are a better buy for your money. And they can take alot more abuse. I have seen many pro racers use the 35+21 and +12sct with flash and 353 heads on them to promote the newer engines. If you have the money great buy the new stuff if you don't buy what you can afford it will still be fast.
HoboShop is offline   Reply With Quote
Old 03-11-2011, 07:53 AM   #3990
wingracer's Avatar
I know but the point is that the average driver (not a pro like you) might have a full second of variance in his laptimes so something that improves laptimes by .05 is going to be impossible to spot on the sheet, due to his poor driving. Yes the difference is in there, but can the average guy notice it?
A pro who can bust off 10 laps all within .2, small changes become quite noticeable in his laptimes.
Team Shepherd USA
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
