Old 09-12-2010, 03:21 AM   #3751
-_-
anyone know where to get gd deal for this 2 size of bearing?
7x19x5
14.5x26x6
*if initially the front engine bearing is 5mm in width, will there be any effect if i replace it with a 6mm width instead?
-_- is offline   Reply With Quote
Old 09-12-2010, 05:51 AM   #3752
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Default Monty from H.E.S.
You can click on houstons engine service in my sig, and it will take you to his site,or get in touch with him in here s/n < Houston > hes a good guy, if its novarossi ANYTHING he's the man
Trying my hand at electric in off season...TLR Sct 2.0---Trinity D4 10.5---HobbyWing 120 amp Black Edition---Trinity the "Brick"--Panther tires--Savox
TommyBlazin is offline   Reply With Quote
Old 09-12-2010, 07:30 AM   #3753
Send a message via AIM to Bxclip
listen guys.. my car just got ran over by a real car lol.. it was a 710 with a megen x-12 so it was a nova engine.. i wanna get the 733 with a novarossi engine. what should i get i want great power.. want to spend around $300 give or take a little..
i want durability and want to make sure they last as well as be a monster
i see these flash engines for $600+.. what does it mean when the engines is flash
Bxclip is offline   Reply With Quote
Old 09-22-2010, 01:18 PM   #3754
GREGORY!'s Avatar
guys i want to make a question.
ehich engine will you buy?
the first cordoba edition in that set(pipe 3 plugs etc)
or the max mx 21 max xl9 tq?
and why?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 09-22-2010, 02:39 PM   #3755
and why?
I would go with the max xl9 tq it will have a little bit more power and better runtime being it is fully modded!!!!! The 35+21 have been none to hold up longer then the max .21s FYI.
HoboShop is offline   Reply With Quote
Old 09-23-2010, 01:24 PM   #3756
GREGORY!'s Avatar
the problems with the worn pistons in the exhaust side that some guys had with the cordobas is user's error or what?has anyone had any problem with the smaller crank pin?
Old 10-10-2010, 08:47 PM   #3757
wingracer's Avatar
Trader Rating: 22 (100%+)
I had a 35 + 21 do it. I think it comes from leaning it out too soon. You really need to break these tight ones in a LONG time and VERY gingerly.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-16-2010, 02:54 AM   #3758
Chickentrader's Avatar
Default Novarossi RER .12 Turbo engine
Does anyone know what a Novarossi RER .12 Turbo engine is, or where I can find the specifications for one?
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 10-16-2010, 01:29 PM   #3759
GREGORY!'s Avatar
wingracer do you know if the stock lc 35=21 engine has many difference from the lc cordoba edition?
Old 10-16-2010, 07:58 PM   #3760
Get the latest Collari. It has the large crank pin and R7 rod plus the new long crank.
http://www.novarossi.it/eng/products...display=public
Desoto Racing
Novarossi America, Serpent America, TOP Engines, Matrix Racing Tires, ProCircuit, Titan/Blitz Products, Xceed Products, KO Propo, Enneti, ArrowMax
info@desotoracing.com, www.serpentamerica.com
jdesoto is offline   Reply With Quote
Old 10-23-2010, 02:46 PM   #3761
captian's Avatar
Thumbs down
Where can I get the crank for this engine
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 10-24-2010, 09:23 PM   #3762
kai888's Avatar
Trader Rating: 17 (100%+)
hi guys, i have a n12t1 and when i spin the flywheel with my hand i can feel its abit loose and is notchy when i get to a certain position, i suspect the bearings are shot, had a few flame outs while running which i've never had before.
does anyone know what size the bearings are? and wheres a good place to get them?
or i should just bin this cheapo motor and go for something abit better?
motor still has good pinch though.
thanks.
kai888 is offline   Reply With Quote
Old 10-25-2010, 05:02 PM   #3763
Trader Rating: 12 (93%+)
kai .. it should spin free and be notchy when the piston is at the top dead centre this is called pinch and its how we measure its compression.
how old is the engine?
how many litres of fuel have you put through it?
do the bearings feel notchy when you turn the crank slowly?
it could be a case of bad o rings in the carb? if so i have spare novarossi carbs from the updated 353 series engines you could try
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 10-25-2010, 06:24 PM   #3764
kai888's Avatar
hi mrgsr
the motor is 9 meetings old, 5 by me and 4 from the previous owner, its been thrashed so i'm just guestimating around 10L or so.
yeah i think i know what you mean by the pinch, it makes that pop sound right?
when i turn the crank slowly, about halfway between top dead centre and bottom dead centre is where i'm feeling it is notchy, also the crank has abit of play from side to side parallel to the face of the bearing.
i'll rip the carb apart tonight and see if i've got any bad orings.
thanks mate.
Old 10-25-2010, 06:52 PM   #3765
That sounds like dodgey bearings. which is why you are havng these tuning problems.
whats your budget for a new engine?
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
