Old 05-03-2010, 04:41 PM   #3586
Roelof's Avatar
Send a message via ICQ to Roelof
Originally Posted by Ballistik Mods View Post
This a great subject .
The original idea was to lighten the crank and silicone putty was a good way of filling the hole left from drilling.Manufacturers noticed a positive effect in shaping the silicone.
If you want to lighten a shaft for less mass rotation you must take it from the outside and not from the center....
Thats why MAX is still using 14mm crankshafts and not the 14.5mm
The use of putty is not to save on tooling wear. shaping the crank in its original form rather than using silicone is pointless as the original objective was to lighten the crank in aid of quicker spooling .
Actually it does save time and tools to create such a shape directly in the crankshaft. Producing in large numbers (60.000 a year regarding their promo movie) a short machine time and less maintenance and recalibration is wanted
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 05-03-2010, 05:19 PM   #3587
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
good point
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 05-03-2010, 07:25 PM   #3588
Ballistik Mods's Avatar
Wow hang on rotating mass is weight transfered from the centre out they mill the centre because it has a similar effect it lightens the crank which in turn reduces rotating mass.
As far as saving tooling. how is that possible it requires more programing additional cutters and time aslo machine servicing to cut the shape direrectly
calibration is required for both methods .
Max power used the 14mm crank because they required more mass on the delivery end so that there efforts to balance the crank was easier to achieve .
Ballistik Mods is offline   Reply With Quote
Old 05-03-2010, 07:34 PM   #3589
An object traveling in a circle behaves as if it is experiencing an outward force. This force, known as the centrifugal force, depends on the mass of the object, the speed of rotation, and the distance from the center. The more massive the outer object, the greater the force; the greater the speed of the object, the greater the force; and the greater the distance from the center, the greater the force.
Old 05-03-2010, 07:35 PM   #3590
As i said lightening the crank reduces overall weight and reduces mass.
Newtons law of physics lighter the action lighter the reaction
Old 05-03-2010, 08:37 PM   #3591
which one of newwy laws is that. Cos lightening the crank actually reduces the mass which hence reduces the weight .. ... and newton never wrote any laws of physic he wrote laws of motion .
Old 05-03-2010, 08:41 PM   #3592
i might not know about engines but i do know my physic's
Old 05-03-2010, 10:22 PM   #3593
newtons law of physics britanica encyclopedia smart arse:lol
Old 05-03-2010, 10:42 PM   #3594
Default newtons law
Newton used physics and motion to create the three laws.
Reduce weight reduces mass ,reduce mass reduces weight.mass is the total matter. reducing either reduces both
Old 05-03-2010, 10:42 PM   #3595
cdelong's Avatar
I don't really care about ramp vs. no ramp.... these engines make more power than 95% of drivers can use. My point is that if the silicon comes loose while running- kiss your engine bye bye....it will hose the p/s and likely the rear bearing at least.
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 05-03-2010, 10:51 PM   #3596
I agree with you there ive repaired engines where thats happened but if properly maintained it shouldnt happen.
Old 05-04-2010, 09:00 AM   #3597
lets end all this speculation and theorys on why Novarossi use this silicon in the shafts. To quote them on their web site, The inlet has a silicon filling to reduce the weight of the crankshaft to improve acceleration. Go to Novarossi site click on Nova Flash engine then click features and this is under crankshaft. Regards Martin.
martinh is offline   Reply With Quote
Old 05-04-2010, 11:48 AM   #3598
Roelof's Avatar
And per definition that is true and not just simple commercial talk?
As also they let you think you need 9 intake ports to go fast.......
Yes, they never gonna tell they have found a cheaper production to make more profit. No, they tell you the new piston is better and the filling works better.....
Ok, lets end this but Alex Siddique is right about rotating mass....
Old 05-04-2010, 12:41 PM   #3599
Does somone know if the Nova head buttons 28022 and 28022/01 are interchangable? The 28022 is specified for the 35+21 Collari Cordoba and the 28022/01 for the Collari 09 or the Flash. Can not see a difference between them...
fulcrum2 is offline   Reply With Quote
Old 05-04-2010, 09:28 PM   #3600
Originally Posted by BLKNOTCH View Post
Hello guy's and gal's, I have just opened my 353 09 for the first time since running the car last summer. I found that when turning the crank by hand it seamed a bit notchy, so I tore it completely apart. I found there was a large amount of orange residue on the conrod and at the top of the piston along with a black center on the piston, it also seems that the front bearing is a bit gritty, can I clean the front bearing with brake clear or something to that degree to get the grit out? or is this a sign that a new front bearing is needed? the main bearing still seams smooth with no roughness to it at all. I have pics and will post but the battery on my camera just died LOL.(Charging now) I run the engine with Byrons 20% Race 2000 Gen2 fuel and keep the temp between 240 deg and 280 deg when racing. I did not find there to be any slop in the conrod to crank bushing but I am just a bit worried about the orange colour.
Thanks guy's
Sean
Wow! of the 9 years I've been doing this I've never seen a engine internals look this bad... I've ran about 3 gallons of Byrons Gen 2 in my engine and it looked nothing like this. I'm surprised there isn't more damage ..
Twisted_Metal is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
