Like Tree9Likes
Old 04-27-2010, 12:05 AM   #3541
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Default N12 T1
hi there,
can anyone tell me what is the spec of this engine? I mean any info on this N12 T1 ... with silver head??
I know its a basic engine.. any other info?
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 04-27-2010, 01:30 AM   #3542
Roelof's Avatar
Send a message via ICQ to Roelof
http://www.novarossi.it/eng/products...2T1&brand=nova
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is online now   Reply With Quote
Old 04-27-2010, 01:37 AM   #3543
jfc_tech's Avatar
Thanks Roelof. I was in Nova wesbite but missed this info..
thanks.
Old 04-27-2010, 01:45 AM   #3544
jfc_tech's Avatar
now may anyone help me on this:
let say i wanna use this engine [N12 T1]for bigger track... how to make it as competitive, on par, with the other big expensive engine... for example the 353.
what shud i do with the clutch setting?
what about pinion/spur setup?
tire size?
thanks. think this as the budget racer tips to hang out with the pro
I just wanna leave the other equation - how to drive, as the only other variable different.
any advice is appreciated - just dont ask me to stop dreaming
Old 04-27-2010, 06:59 PM   #3545
NitroWD's Avatar
Default Flash 21 and Flash 21 special
hi guys,
what's the main differences between the Flash .21 and Flash .21 special?
is there a very noticeable power difference?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 04-27-2010, 07:56 PM   #3546
Team Kamikaze's Avatar
Originally Posted by NitroWD View Post
hi guys,
Flash .21 had a microcast piston
Flash .21 Special had a CNC piston = increased bottom end power!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-27-2010, 11:15 PM   #3547
@Team Kamikaze
is it fact that the cnc piston improves bottom end? Just wondering, because I run Novarossi engines since many years and they changed the manufacuring process of their pistons between cnc and microcast a couple of times. Everytime they claimed that the change is an improvement...
fulcrum2 is offline   Reply With Quote
Old 04-27-2010, 11:56 PM   #3548
Roelof's Avatar
Microcasting is using a mold to fill it with liquid piston aluminium but under a high pressure. The molecules will be closer to each other making the material stronger. Finally this piston will be shaped by a CNC proces.
The CNC piston is just made from a bar delivered from the supplier.
Both are just piston materials.....
Depending the other materials inside (copper, iron, silicium etc) the specs/properties is determed like friction, strength, expansion rate etc.
So for me a CNC or a Microcasted piston is just a piston and only these words say nothing about the specs than only that the Microcasted must be stronger.
Old 04-28-2010, 01:16 AM   #3549
You made some good point here, Roelof. I think that the terms "cnc piston" and "microcasted piston" are just marketing hype. I had good success with both types of piston which leads me to believe that it makes no big difference. On the other hand I was wondering why Team Kamikaze claimed that the Flash Special has more bottom end by using a cnc piston. I never ran the Special, so I cant compare. By looking at Novarossis expoded views I can tell that the P/S set and the crank is the same between the Flash and the Special.
Old 04-28-2010, 02:21 AM   #3550
Roelof's Avatar
Some thoughts about the more bottom end:
- different timing (sounds to me the most logical)
- better expansion rate fitting the expansion of the sleeve.
- lower friction (when giving throttle the piston becomes hot and does expand faster compared to the sleeve what will create some friction)
Old 04-28-2010, 09:31 AM   #3551
Originally Posted by fulcrum2 View Post
@Team Kamikaze
The microcast piston is heavier and the CNC from bar-stock aluminum is lighter, and of course the lighter material helps the increase of the overall performance.
Old 04-28-2010, 10:08 AM   #3552
Roelof's Avatar
The weight is an issue for performance but is not THE reason for more bottom power. This I know because I have runned many experimental engines with different pistons, rods, timings etc. and a heavy rod/pistin can still deliver a lot of bottom power. The height of the exhaust port has more influence on that.
I think based on a bar of material or Microcasted (based on the same ingredients) there is not much difference in weight.
Old 04-29-2010, 08:46 AM   #3553
Hears the actual weights of cast v cnc billet pistons on Axe Rossi pistons as an example. Cast piston = 3.9 grams, cnc billet = 3.7 grams, The cnc piston has slightly more skirt cut away + two 5 mm holes as well so given this their probably the same weight.The reason to use billet material over cast is said to be stronger + billet they can get higher silicon content. A typical cast piston has around 20-21% max silicon, Billet is up to 30% silicon. The thermal expantion on 30% is less than 20% this is why billet pistons are said to last longer than cast ( the piston expands less so dosnt wear as much in the bore). This is also possibly why theirs more bottom end / acceleration because theirs less friction on the piston in the bore because the piston is expanding less. The thermal expantion on billet 30% silicon material is 15.4, Cast 21% silicon which is the maximum that can be made in cast pistons without compromising the material is 16.3. Obviously any reduction in piston weight will make differences as well. Martin.
martinh is offline   Reply With Quote
Old 04-29-2010, 08:51 AM   #3554
THANK YOU! Very well Explained
Old 04-29-2010, 09:15 AM   #3555
Very good and detailed explanation, Martin. Makes a lot of sense to me, thanks a lot for that. The only open question to me remains, why is Novarossi changing back and forth between the piston manufacturing processes and claims and improvement everytime...
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
