Like Tree195Likes
Novarossi engines thread
Old 04-17-2010, 09:13 AM
  #3526
how does the 08 353 Race .12 Plus 2 perform?
thinking of getting that engine with a 2630 pipe.
LiL_JaSoN is offline
Old 04-18-2010, 02:54 PM
  #3527
The 2652 pipe with a short header will give better millage and better performance. There is also a 2660 pipe that is really good, kind of new though. Not a lot of testing with that pipe. The 2630 is a little of a fuel hog.
DJ Apolaro
dj apolaro is offline
Old 04-19-2010, 10:15 AM
  #3528
gearhead_22's Avatar
is the piston & sleve kit still available for the 08 353 race?
gearhead_22 is offline
Old 04-19-2010, 10:30 AM
  #3529
G87z's Avatar
Check with murnan.
G87z is offline
Old 04-21-2010, 10:15 AM
  #3530
I have a band new flash .12 do you recommend that I add a shim and what size I will be using 20% byrons race fuel insted of 16% tha tit calls for.
Old 04-21-2010, 11:45 AM
  #3531
If I were you I would add at least .05, but .1 would be safer and still give great power. Total of .4 is the safest way to go. It already comes with .3 standard.
DJ Apolaro
Old 04-21-2010, 01:15 PM
  #3532
DJ Apolaro
thanks dj just the answeri was lookin for.
Old 04-21-2010, 02:51 PM
  #3533
Anytime!!!
Old 04-26-2010, 10:07 AM
  #3534
SMcpot's Avatar
Trader Rating: 22 (100%+)
Questions??
Can anyone give me the part number or the name of a supplier for the Torx head screws that my R1WC came with? It looks like the 01001 screws spec'd for the current Kangaroo engine are flat headed and slightly shorter like my older Novas, but I need a replacement and would like to retain the Torx screws.
Or are there possibly allen head screws from another manufacturer that I could substitute?
SMcpot is offline
Old 04-26-2010, 10:41 AM
  #3535
Roelof's Avatar
It is just an M3.5 screw, with some searching you will find a hardware store who can deliver them in hex and torx.
Roelof is offline
Old 04-26-2010, 11:07 AM
  #3536
SMcpot's Avatar
Thumbs up
Thanks, Roelof. I took the easy way out and ordered a set of head and backplate hex screws for an RB engine.
SMcpot is offline
Old 04-26-2010, 11:08 AM
  #3537
http://www.mcmaster.com/#socket-cap-screws/=6tx5gy
nitrodude is offline
Old 04-26-2010, 11:16 AM
  #3538
SMcpot's Avatar
Thanks for the link. Can't find socket head torx screws in metric thread, though. More than a couple of people I've talked to only recall Novas ever having slotted head screws, so mine must be one of those super-special, ultra rare engines
SMcpot is offline
Old 04-26-2010, 11:57 AM
  #3539
Roelof's Avatar
Yes, RB has indeed hex screws, they do need a 3mm hex wrench.
Regarding the torx, I had them too on my JP R01-2003 teamspec engines.
Roelof is offline
Old 04-27-2010, 12:04 AM
  #3540
awins's Avatar
can anyone give me the heat range i should be running my 353 nova at please
awins is offline
