Like Tree8Likes
Old 03-18-2010, 05:09 PM   #3511
Trader Rating: 15 (100%+)
Originally Posted by Turbo9000 View Post
are most novarossi .21 rods interchangeable? do they share the same dimensions, ie, length, bushing I.D. etc ?
If i have an old novarossi on-road .21, would i be able to put a new rod in it?
I can get dimensions of my old con-rod.. if somebody has measurements of a newer rod so i can compare.. that would help me out a ton.
No, some have smaller crank pins. If you know what the engine you have is and post it here I am sure that some of these guys will know what rod to use.
THE DOCTOR is offline   Reply With Quote
Old 03-18-2010, 07:38 PM   #3512
Turbo9000's Avatar
this motor is probably 15-20 years old. The case says nova on one side, and 2000 on the other side. One of the mounting flanges has the word COMPET stamped into it. Here it is before i started rebuilding it. I will snap some better pics and get some dimensions of the internals.
I have the engine sitting on my bench at work, so hopefully i can remind mysefl to do this
It is the dirty old engine on the right
Turbo9000 is offline   Reply With Quote
Old 03-24-2010, 03:14 PM   #3513
has anyone tried the new flash .12 motors yet, what do you reckon to them?
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 03-29-2010, 02:48 PM   #3514
Default Exhaust 353
I have an 2008 353 .12 and need an new exhaust. Which of the novarossi exhaust will suit the engine best, the 2630, 2652 or 2660? thanks
ma_RC_el is offline   Reply With Quote
Old 03-31-2010, 02:53 AM   #3515
Michael_T's Avatar
Trader Rating: 47 (100%+)
Send a message via MSN to Michael_T
The 2630 was made for the 2008.
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 03-31-2010, 02:55 AM   #3516
Michael_T's Avatar
Has anyone with a .12 353-09 used the Novarossi Rubber Front bearing (#17009) instead of the standard metal shielded front bearing (#17010)
Opinions?
Old 03-31-2010, 03:00 AM   #3517
Opinions?
works fine Mike. probably the rubber is the easier long term option. I think all the 353 09's come with the rubber sealed bearing now. The first batch had a dodgy set of bearings it seems
TomB is offline   Reply With Quote
Old 03-31-2010, 03:14 AM   #3518
Michael_T's Avatar
No, mine is a late 2009 version (fresh from the factory) and it comes with the metal shield front bearing.
To be honest, I never knew Novarossi had an optional rubber version for the 353-09, and it is exactly the same price as the metal shielded standard front bearing....
Old 03-31-2010, 03:26 AM   #3519
Trader Rating: 12 (93%+)
Ive been using the RB variant and it works fine
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
mrgsr is offline   Reply With Quote
Old 04-08-2010, 03:59 PM   #3520
Default Flash .21 Conrod - Longevity
Hi everyone,
I believe engine break-in is quite severe on conrods - so could anyone advise me as to how much running they would recommend a conrod (R7, from a .21 Flash Special Tuned) to do after having being "pre-run" before sale, and then the run-in completed on the track?
Cheers,
Kronos.
Kronos is offline   Reply With Quote
Old 04-12-2010, 06:45 AM   #3521
keavze's Avatar
what's the usual temp you guys run your 359 tuned? mine's about 120C...
do tuned engines usually run hotter?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 04-13-2010, 04:23 PM   #3522
Default Flash .21 - Gudgeon-pin clips
Could anyone tell me if it is possible to use the gudgeon-pin
clips with part number 05000 in the Flash .21 Special engines?
- Although the exploded view for the Flash shows that a gudgeon pin clip
with part number 05001 is required.
Thanks,
Kronos.
Old 04-13-2010, 05:18 PM   #3523
Kronos, you are correct that the rod is stressed alot on break-in and that is why I bought two Go-Tech rods that are the same size as my 35+21 and Kangaroo motors and use them exclusively for new engine break-ins only. I also use off-road 14mm or 14.5mm cranks in the new engines as well so the new crank-pin on the new crank isn't worn prematurely. After the engine is broken in and no ill pinch, I re-install the unused new rod and new crank back in the motor and off we go. This was the best piece of mind for me since I didn't want to damage my new stuff on the most critical time of a brand new engine.
Brent Davis is offline   Reply With Quote
Old 04-16-2010, 12:44 AM   #3524
FF25510's Avatar
Default con rod
anyone knows does NR 07006 same as 07009, thanks in advised
FF25510 is offline   Reply With Quote
Old 04-16-2010, 04:35 PM   #3525
Default 353C Tuned vs Flash12 Tuned
What is the difference in performance ?
jelayne is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
