Like Tree32Likes
Old 10-23-2009, 06:02 AM   #3346
captian's Avatar
well there you go !!!! its all up to who has what and if they can make it fast and make it last
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 10-23-2009, 08:04 AM   #3347
emancipation007's Avatar
Default Flash
I'm thinking about buying a nova rossi flash anybody got any feed back,is there a motor that is close to performance for about five hundred bucks
emancipation007 is offline   Reply With Quote
Old 10-23-2009, 08:22 AM   #3348
dj apolaro's Avatar
Check out this site. They have it all. The 35plus is $520.00 and Flash is $550.
http://www.serpentamerica.com/shop/home.php?cat=10
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 10-23-2009, 08:22 AM   #3349
Actually the 35 Plus 21 is an excellent engine and in that range of price. You can't go wrong with a 35 Plus
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 10-25-2009, 03:58 AM   #3350
Renault_Tech's Avatar
Hey guys. I was a Novarossi .12 and have .4mm worth of headshims in at the moment with 16% nitro and 10% oil (6% synth oil and 4% castor). What benefits would i have of reducing the number of headshims??
[KYOSHO] [NOVAROSSI] [TEAM MAGIC G4RS] [O.S SPEED T.Z SPEC II] [SPEKTRUM DX3R]
Renault_Tech is offline   Reply With Quote
Old 10-25-2009, 04:16 AM   #3351
aussies1129's Avatar
Trader Rating: 74 (100%+)
removing head shims will increase combustion pressure which should increase power, be carefull here be sure to follow what the manufaturer recommends, you may need to lower your
nitro content but 16% should be ok also keep an eye on your plugs as they usually dont last long, also this will change your tune so you will need to retune.
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 10-25-2009, 04:24 AM   #3352
Hey mate, thanks for the quick reply. The nova website has the picture listed with only a .3mm shim
http://www.novarossi.it/files/explod.../N12TS1_RT.pdf
and have been using .4 till the engine has been fully run in ie lost pinch which it now has. would this be a good time to remove the shim and just do the usual richen the needles and work my way back in from there??
Old 10-25-2009, 05:20 AM   #3353
if you feel your not getting the power out of the engine give it a go, have you tried changing your fuel brand?
H.E.I AUSTRALIA
Old 10-25-2009, 01:29 PM   #3354
haha its a rocket since its freed up but in the words of Ricky Bobby - "I wanna go fast!!"
Old 10-26-2009, 08:39 AM   #3355
the 353 09 that i got is an amazing engine. excelente power on bottom, mid and high. and haven't have any problem with front bearing, so far...
mc_chofo is offline   Reply With Quote
Old 11-22-2009, 02:59 AM   #3356
M16
Questions??
What's the story with the 353' 09 blowing front bearings. At our Nat's in October a number of 353's had front bearing problems. Does the 3SCT have the same problem? .... I note the 353' 09 has a metal sealed front bearing others have a rubber sealed bearing. Most of the guy's with bearing problems used RB front bearings as replacements.
I am in the market for a new engine and aren't yet convinced to buy the 353' 09 or to buy the 12-3SCT... any ideas on which way to go...
M16 is offline   Reply With Quote
Old 11-22-2009, 10:08 PM   #3357
i think the 353 09 has been updated and they now come with a rubber seal bearing on the front.
TomB is offline   Reply With Quote
Old 12-06-2009, 05:43 AM   #3358
musti72's Avatar
Hi guys I have a new question about +12SCT. I stripped the motor to inspect it after about 15lts(about 4 gallons?) and I turn the crankshaft when its not connected to the rod, and there is a feeling that it became heavier than my newer engine. It feels as smooth as possible, but just like I added weight to the crankshaft. Is it about bearings? Whats the deal with it?
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 12-06-2009, 10:48 AM   #3359
wingracer's Avatar
Trader Rating: 23 (100%+)
Sounds like it's just thick, nasty, gummy castor oil in the bearings. That stuff can really make things feel smooth but thick and heavy, kind of like new rubber sealed and greased bearings.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 12-06-2009, 11:06 AM   #3360
musti72's Avatar
So, is it a good thing, or bad, or doesnt affect the performance? What should I do?
Mustafa Alp
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
Currently Active Users Viewing This Thread: 6 (3 members and 3 guests)
Dougie1986
