Like Tree33Likes
Old 10-20-2009, 09:24 AM   #3331
serpentamerica's Avatar
The one's we have in stock are the latest Batch. No problem reported at the moment. If you are in USA, contact your LHS in order to get your Novarossi products. There is no need to go overseas. Products are available and in stock in USA
Facebook: http://www.facebook.com/pages/Miami-FL/Serpent-America/120322987992068
www.serpentamerica.com
e-mail: [email protected]
telf: 1-305-677-3253
serpentamerica is offline   Reply With Quote
Old 10-20-2009, 02:52 PM   #3332
thanks, i'm from Mexico, so most of my hardware has to be imported, since here things are overpriced. it's not that i have only one LHS, i buy my stuff from several HS including several from US, some of them from HK, this time i got the engine from him no special reason. but thanks anyway
so is there any way that i can see if my engine is one of the latest batch or if is one of the oldest? i would appreciate your help.
mc_chofo is offline   Reply With Quote
Old 10-20-2009, 04:21 PM   #3333
Team Kamikaze's Avatar
Hi Rodolfo,
All Nova Rossi engines from where you bought it are the old batch, their distributor bought a lot of engines when the engines first came out, so up until now they still have a lot in stock that they are trying to get rid off at a cheaper price, but with all the bugs that came with the engine it end up more expensive because of the bearing and Rod issues.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-20-2009, 04:37 PM   #3334
Good to hear from yo Sam, i just come back to onroad at least for bashing, right now i'm at the offroad stuff. Sam the front bearing with black seal from nova that you have at yourwebsite is the direct replacement for the 353 09? also the conrod that you have also fits in it?
Old 10-20-2009, 05:05 PM   #3335
Nice to see you back to on road again too, The correct rod for the 353 09' engine is http://kamikazercracing.com/proddetail.php?prod=NOV7604
and I should have the front rubber sealed bearings for the 353 09' by next week.
Old 10-21-2009, 09:13 AM   #3336
thanks again Sam, is there any other bearing that can substitue the novarossi orginal one, any one that is rubber seal instead of the steel one?
Old 10-21-2009, 09:16 AM   #3337
and is there any serial number on the engine that could indicate that the engine comes from the lastest or oldest batch?
Old 10-21-2009, 05:15 PM   #3338
So Far only Nova Rossi had the bearing, but they do have a rubber sealed bearing, regarding the batch of engines, just trust me because the batch that is in the US just came in are fresh, but the one you got it from is the first batch that got problems.
Old 10-21-2009, 07:35 PM   #3339
Is there anyway to identify what engine I have?
Is there any sort of recall? I mean, a known defective engine should have a recall for those engines that have not been used.
Serpenteer is offline   Reply With Quote
Old 10-22-2009, 12:14 PM   #3340
captian's Avatar
good thought !!!!
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 10-22-2009, 02:14 PM   #3341
It's a good idea to email Nova Rossi World and ask them or ask the shop you bought it from.
Old 10-22-2009, 11:26 PM   #3342
jds5150's Avatar
Default MAX POWER XL9 TQ
Originally Posted by kitracer View Post
I saw one and know another guy doing really well with the Flash .21 (std, not tuned). The conrod is the Plus model, not 359.
I have been running 2 x 359 with no problems (other than my tank leaks) Careful with the ceramic bearing because it will take at least 1 litre to break in with slow acceleration otherwise they could skip.
I suggest stay with Nova and I like #9886 with the conical header, 5 to 7 fin depends on your track.
Hi Chris,
Have you or any of your buddies tried the MAX XL9 TQ. I believe it has a smaller diameter crank (i.e. 14mm). Do you reckon this engine will produce more torque due to less rotation mass in the crankshaft. Apparently, the 359 Flash 21 has a larger diameter crank (14.5mm) and I think the purpose is to prolong the life of the rear bearing.
Julian
jds5150 is offline   Reply With Quote
Old 10-23-2009, 05:18 AM   #3343
Paulie Bee's Avatar
Default Novarossi Flash is your best bet
Originally Posted by jds5150 View Post
Hi Chris,
Julian
Hello Julian:
I ran "that motor" that you are referring too...... no comment on this thread based on my promise to Fabio and Massimo not to go "there", but send me your email address via pm, and I will send you some "very nice" photographs on my pit table of the capital classic race if you promise in writing to keep them confidential. I bought two brand new ones right before this race. Now that everybody knows what I am talking about, the Flash .21 is a mid-to high RPM based motor by design. The 14.5mm crank is part of the equation. This does not take away from its bottom. You run it with a long headder and a 2015 or 2052 pipe and hold on tight! As far a torque, I can vouch that the Flash, be it stock or tuned has an even better bottom-end but top end is a missle. The "other" one has a more linear RPM-band and then flattens out on larger tracks compared to the Flash. Just my humble opinion.
Paolo should confirm this.
My recommendation to you is the Novarossi Flash all the way. Your LHS can get you a freshly imported version.
I know Brooklyn Hobbies has them in stock...call Richie for great service and price.
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 10-23-2009, 05:48 AM   #3344
captian's Avatar
Originally Posted by Paulie Bee View Post
Hello Julian:
now paulie be fare all engines have there problems
Old 10-23-2009, 05:49 AM   #3345
Phil Trotta's Avatar
Thumbs up novamax xl9
Hi Chris,
Julian
i ran this motor a good amount at chaplin...........once broken in had awesome power.....ran 16 percent maxy fuel stock head shims with a nova fuel cooler nova med header conical and a 2015 pipe........had no problems................ buying a spare for next season...........lessmoney than the flash....seen the flash go also definately not a turtle.........
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
