Novarossi engines thread
#3301
Ehm.... yes......
I have read somewhere the coating is a reinforcement of the crankcase but I doubt it will make the case stronger. But you will never know what the teamdrivers are using, maybe their cases are from a different matirial.
Once I swapped the internals from a JP Eagle over to a crankcase of a 35+ due some problems and I did not notice a difference in performance.
#3302
Hi Guys
Can anyone explain why the 353 comes with 2 low end needles. ships with a short one and a longer one in the packet of bits. Under what conditions would each be used.
Thanks heaps
Peter
Thanks heaps
Peter
#3303
On high traction tracks the short fat needle was the hot ticket and on low traction the longer thin needle was best.
Hopes this helps.
Lee
#3304
The coating that is on most of the black or gray crankcases is a hard coating and it changes the actual Rockwell rating for the hardness of the material used in the crank case. Rockwell is a measurement used to rate the hardness of materials. So the case will usually display signs of more rigidness and less flex.
#3305
Hey.. what would be the best pipe to run with a Novarossi 359 RACE .21
#3309
Why those cars have two extra body post behind rear shock tower ?
#3310
#3311
novarossi 353 '08 & '09 edition...
hi,
what is the performance difference between the novarossi 353 '08 (blue head) edition vs the new '09 (purple head) ?
also notice the new 2652 pipe ?? many thanks :-)
#3312
353 '08 / '09 conrods
Can anybody tell me the difference between the 353 2008 & 353 2009 conrods?
They have different part numbers (NOV07602 for '08 and NOV07604 for '09).
Are they interchangeable?
Thank you
Thank you
#3313
Hi Guys, just willing to let you know that the Novarossi On Road engines are in. All of them in stock. Pipes, headers, plugs, etc, etc are in stock.
Check our dealers or go to serpentamerica.com
#3314
just want to verify that the Plus 12- 3SCT and the 353 '09 use the same con rod? I need to replace them and wanted to be sure before I order it!
