Old 05-11-2009, 02:07 AM   #3211
Nitro-Racer*'s Avatar
by the way there(novarossi) last ultra plugs come in the silver body not black any more...
Xray Nt1-Novarossi 3sct-KoPropo-GRP-Altis 2.3-RB Fuels
Xray 808 09-RB Killer 9-Hitec-KoPropo-RB Fuels
Nitro-Racer* is offline   Reply With Quote
Old 05-11-2009, 02:20 PM   #3212
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
Really? They silver and say ultra plug in the packaging?
eBay user id: riketsukirai
Selling all my MTX4 parts, bodies, radio and everything!
Riketsu is offline   Reply With Quote
Old 05-12-2009, 12:45 AM   #3213
asw7576's Avatar
novarossi glowplug :
http://www.novarossi.it/content_uk/p...lugs/index.php
Old 05-12-2009, 08:19 AM   #3214
yes they say ultra plugs and are in the traditional golden pack but the body is silver...
Old 05-13-2009, 06:20 PM   #3215
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Just wonering what the difference is between following engines
12-3c
12-3ct
12-3sct
Bit confused guessing t is for tuned?
J.Gonzalez is offline   Reply With Quote
Old 05-14-2009, 01:59 AM   #3216
NiTrO BoOsTeR's Avatar
the C is for Ceramic Bearing
and im not sure and dont quote me on this but i think the
S is for Silicon filling in the crank
and T is for some work on the liner.
a Tuned version has work done to the crank.
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 05-14-2009, 03:11 AM   #3217
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
12-3c
12-3ct
12-3sct
The Plus 12-3c is the engine with ceramic rear bearing and standard plug
The Plus 12-3ct has the ceramic bearing and uses a turbo plug
The Plus 12-3sct has the ceramic bearing, turbo plug and uses an 11.9mm crankshaft (the c and ct version use and 11.5mm crankshaft)
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-15-2009, 01:14 AM   #3218
the 3C has a turbo plug have a look at the website
http://www.novarossi.com/content_uk/.../plus12-3c.htm
Old 05-15-2009, 01:32 AM   #3219
I am going to revise what I said as it appears I am wrong. I downloaded the exploded views of both the 12-3C and the 12-3CT and there are two differences. The cylinder heads are different (almost positive the only difference is what is written on them). The other difference is the crankshaft. EVERY other part number is identical. The SCT has a larger crankshaft 11.9mm vs 11.5mm
Old 05-15-2009, 04:53 AM   #3220
Riketsu's Avatar
I knew I had answered this question before, . Just didnt remember, i made a search back on the thread and found this:
The "S" is there to distinguish between the 11.9mm and the 11.5 mm crank
The "C" is there to distinguish between Steel Rear Bearing and Ceramic Rear Bearing
The "T" is there to distinguish how worked up the crankshaft is. See these pictures:
"T"
"Non T"
Hope this helps. This is what I know, someone please correct me if im wrong.
Old 05-15-2009, 03:15 PM   #3221
J.Gonzalez's Avatar
Ok thanks guys...
Another question
12-3 series motor vs a 353 series
Pro/Cons differences?
Old 05-16-2009, 02:34 AM   #3222
well the most obvious difference is that the 12-3s have low to mid power, while the 353 has mid to top power delivery. there is also a difference in the conrod and crank pin. my suggestion is to get a 353 unless the track that you are racing has little straights
Old 05-16-2009, 04:39 AM   #3223
they are basically the same engine, 353 has 500 more rpm, but a 3sct can be as fast or even faster that a 353, get what u like, what u can get the parts for real quick, look at what will last longer, dunno about the new 353 but the old 1 use to wear a bit on the crank pin
Old 05-17-2009, 12:18 AM   #3224
I believe the new 353 09 has an extra layer of coating on the crankshaft. Supposed to be lasting longer. You can see the discussion on the NovaRossi 2009 thread
silverM3 is offline   Reply With Quote
Old 05-18-2009, 02:33 AM   #3225
yea and i think they have gone to the same rod as a sct now
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
