Old 04-01-2009, 05:23 PM   #3136
gtrmx's Avatar
Originally Posted by c1 racin View Post
NEED help ....
This weekend at the Texas Biggie I had a Max SL3 implode, so I put in my back up which is a Novarossi NSR3 Race ... I got it new a couple years ago but it has only had MAYBE a half gallon thru it ... After putting it in the car and tuning a little (hadn't been started or ran in about a year) it ran surprisingly well. I continued tuning it, getting the gearing, and clutch / two-speed adjusted. It was running better than it did when I replaced it with the Max.
In the main here's were the problem was, which was why I replaced it to begin with. It runs great, never gets about 270ish. However when I come in to pit an refuel it will flamout ... not everytime and not as soon as the idle slows. It happened twice in the 30 min main, first time (about the 10 min. mark) my pit man refueled me and I left pit lane and on the second turn it just flamed out. It fired right back up with no problem. The second time (about the 25 min mark) after getting refueled I was at the end of pit lane when it flamed out. Once again it started without any problem.
..... Can someone tell me what causes this .....
I have seen this happen to me when I shim the engine on the high side. If the engine restarts right away it's because the mixture is rich at low revs. Try leaning out the bottom or open up the idle until it stabilizes.
Since I like saving some fuel, I tend to use many shims in the engine and I open up the carb just a tad by holding steady on the trigger during refueling. Itīs risky but has worked out just well for me. I sure enjoyed watching faces in awe when the other drivers saw how much run time I was getting...
I think its easier to prevent flaming out when the head is lower, but if I were you, I'd find more expert advise... Besides, you do not want to lower the head too much...
I hope someone else suggests something here...
gtrmx is offline   Reply With Quote
Old 04-02-2009, 09:05 PM   #3137
c1 racin's Avatar
Send a message via ICQ to c1 racin Send a message via AIM to c1 racin Send a message via Yahoo to c1 racin
NEED help ....
Thanks for the input .... I was starting to wonder if anyone had read the question .... I haven't shimmed the head, it's stock .... I'll try to lean the bottom out, the temps were around 270ish as I said .... thanks agian ...
NeXusRacing.com
MurnanModified.com
MobileRCRacing.com
c1 racin is offline   Reply With Quote
Old 04-03-2009, 05:47 PM   #3138
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by andy4 View Post
Those are most likley production control codes
no one else knows why my 7602 rod for a 353 has a P2 stamped on it rather than all my other 353 rods having P1 stamped on them ? i have asked the shop where i got them, but slow response from novarossi, so i thaught id ask here.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-05-2009, 10:31 PM   #3139
Just wondering if anyone has information on the 3006 and 3007 pipes from Novarossi? I see that at least the 3007 was used at last year's Euros most likely as per the new EFRA rules. But I was wondering how these pipes compare in performance to the 2015 and such.
automator is offline   Reply With Quote
Old 04-05-2009, 11:20 PM   #3140
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
"The 30XX pipe set gives more counter pressure therefore increasing low rpm power and decreasing maximum rpm. You should know this before choosing your manifold."
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 04-06-2009, 01:39 AM   #3141
M7H
M7H's Avatar
In 1 word.
They suck...
No really, indeed they where used due to the new EFRA rules, but this year these rules are thrown overboard, and most 20xx pipes are allowed again (not all).
The 3007 pipe is ok.. but the 3006 Pipe is really bad!
If you don't have to, I would not recommend anyone to use the 30XX pipes....
Serpent
M7H is offline   Reply With Quote
Old 04-07-2009, 09:52 PM   #3142
Suspended
What is the nova 2652? I can't find this anywhere
kyosho player is offline   Reply With Quote
Old 04-12-2009, 08:20 AM   #3143
racer301's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to racer301
Thumbs up conrod 7602 vs 7601
hi do you know if there is a difference?
I have a 353 .12 Race Plus not plus 2?
What is the correct part number for 353 .12 Race Plus Con Rod?
also I have a Massimo Fantini mortor MF12 is it true that I can use 7601 conrod?
thanks!!
racer301 is offline   Reply With Quote
Old 04-12-2009, 11:53 AM   #3144
stefan's Avatar
Send a message via AIM to stefan
thanks!!
Okay, here are the facts
353 is PLUS 2, and Plus 2 uses 7602 conrod.
12-3, S, T, ST, SCT, CT are all Plus and use the 7601 conrod.
Not sure on which engine the Max is based.
stefan is offline   Reply With Quote
Old 04-12-2009, 06:27 PM   #3145
Pattojnr's Avatar
the MF is the Mega MF . based on the LS or LL3, not quite sure. it is a novarossi engine, and does take the 7601 rod also.
to answer your PM, i change my rods after run in, and then after every meet i pull the engines down to inspect. there is no set time to change the rod, but generally should be looking at chaging it say every 6-8 lts of fuel. the more often one changes it the more life the engine will give you.
Serpent - Walter RC
Old 04-16-2009, 07:42 PM   #3146
Default re glow plugs
check your bearings to, ive got S12 THAT WAS BLOWIN PLUGS AND THE BEARING WAS SHOT AND LITTLE BITS OF METAL SOMEHOW GET INTO THE PLUG, HOW CAN I IDENTERFIE WHAT BRAND MY ENGINS ARE, IVE GOT 2 S12 AND ONE SX12 ROSSI, ANY WEB SITES??
shazdave67 is offline   Reply With Quote
Old 04-17-2009, 06:51 AM   #3147
G87z's Avatar
Hello,
Does anyone know where to get a conrod for the new 353 09? all the sites I visit only have the 08 conrod instock.
Thanks in advance!
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 04-17-2009, 07:05 AM   #3148
Suspended
Hi,
Is the novarossi exhaust # 51607 a good exhaust? What is this exhaust for bottom end or top speed?
thank you
Old 04-17-2009, 09:19 AM   #3149
Ivan Dickson's Avatar
Trader Rating: 7 (89%+)
Questions??
Originally Posted by G87z View Post
Hello,
Thanks in advance!
Good question does anybody know..
SPECIAL THANKS TO ✦ MY WIFE ✦✦ GLOBAL PRIVATE FUNDING ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 04-17-2009, 11:36 AM   #3150
The 353/09 uses the same rod as all the pre-353/08 engines, e.g. 3ct, 3sct, etc.
The change was to go back to the larger crank pin diameter older rod.
Novarossi did it also with the 359 and Flash.
maxflo777 is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
