Novarossi engines thread
#2986
Or you can add pure castor to the fuel you normally use. 50cc to a full gallon should be ok. Make sure to set the high speed needle so that the motor barely runs, but can stay running at WOT.
Good luck,
DJ Apolaro
#2988
Anytime
DJ Apolaro
DJ Apolaro
#2995
One pipe may be different to tune than the other. I use the 2630 with short header and like it. The key to the 353 motor is gearing and the split from 1st to 2nd. I normally run about 2.3-2.5 final drive split and also make sure the 2speed is shifting correct. I use this pipe on tracks like Ft Myers, which is bottom and mid range and also at Kissimmee, which is top end. I do not think you need the 2602, however if you like to have choices, it can not hurt. However it is not needed.
Regards,
DJ Apolaro
Regards,
DJ Apolaro
#2997
anyone have info on this .12 size turbo 5 port mill?
i know its an oldie but i have a brand new one that has been fully modified.
http://s424.photobucket.com/albums/p...PTT12-S5HP.jpg
also which nova pipe do you recommend for it?(med to large track).
#2999
"Spec:
Displacement: 2.09 cm3
Maximum power: 1.62 hp
R.P.M. (M.P.)43.500 rpm
Bore x Stroke: 13.80 mm x 14.04 mm
Ports nr.: 5
Piston type: Microcasted
Crankshaft Ø: 11.5 mm
Crankshaft Type: Turbo SG
Glow Plug Type: Turbo
Exhaust Type: Rear
Carburetor Ø: 5.4 mm (interchargeable insert)
Type: Slide
Material: Aluminium alloy
Adjustement: Double
Fuel Type Recommended: 16% nitro
Crankshaft: The crankshaft is made in high quality steel. It is 11.5 mm size. The increased section provides more rigidity and allows a larger bore intake.
Piston: The piston is CNC machined in the TS version and it is realized with anew technique developed by Novarossi (microcasted) in the TSR version"
#3000
ezveedub THANKS!!!!
so i assume i can use the nova outlaw pipe?
(since this combo will be for personal enjoyment)
