Old 01-12-2009, 03:38 PM   #2971
PROVK's Avatar
Trader Rating: 14 (100%+)
Originally Posted by NiTrO BoOsTeR View Post
the 2630 with a 5 fin header would be killer. but it depends on what your track is like
if it is small and twisty with a shortish straights i would say the 2630 with the 5 fin header
but if its long and flowing with long straights i would say the 2630 with a 7 fin header
Mitchell
Mitchell
You got it the wrong way around mate, 5 fine header is more top end
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 01-12-2009, 03:55 PM   #2972
dj apolaro's Avatar
Mitchell
I do not want to disagree with someone, however this is opposite. The 5 fin is for top speed and the 7 fin is for bottom end.
Hope this helps.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 01-12-2009, 04:04 PM   #2973
PROVK's Avatar
Hope this helps.
DJ Apolaro
DJ
The above is 100% correct.
Thats what happens with these forums, heaps of people dish out the wrong info.
No offence Mitchell
George
George V
Mugen Seiki
www.rrcsa.org.au
Old 01-12-2009, 05:23 PM   #2974
NiTrO BoOsTeR's Avatar
woops i must of got it backwards, i gotta get off the turtle weed
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 01-12-2009, 09:20 PM   #2975
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
I have both the 2602 and the 2630. I have seen my engine faster all-around with the 2602.
eBay user id: riketsukirai
Selling all my MTX4 parts, bodies, radio and everything!
Riketsu is offline   Reply With Quote
Old 01-15-2009, 02:06 PM   #2976
Trader Rating: 21 (100%+)
Just got my stock 353 in and it has no shims. I guess there are none needed to run 16%. If I wanted to run 20%, 25%, or 30% fuel how many shims would I have to add?
VA_Racer is offline   Reply With Quote
Old 01-15-2009, 03:07 PM   #2977
dj apolaro's Avatar
Are you sure there is not any shim in there? Typically there is a .3mm shim for 16%, it is silver. Maybe it is stuck to the button. For 20% add a .1 and for 25% and 30% add .2
16% = .3mm
20% = .4mm
25-30% = .5mm
With 16% I use a 6f plug. with 25 and 30 I use a 7f plug. I am at sea level with high humidity.
Hope this helps.
DJ Apolaro
Old 01-15-2009, 03:14 PM   #2978
Thanks I will check again, I didn't know they were silver thought they were brass.
Old 01-15-2009, 03:14 PM   #2979
Trader Rating: 284 (100%+)
DJ,
Are these shims in addition to the stock shims that came with the engine or total shims?
rcdoktor2 is offline   Reply With Quote
Old 01-15-2009, 03:20 PM   #2980
dj apolaro's Avatar
The .3 should be in the motor already. The .1 and .2 are in addition.
As for the color of the shims. The .3 is silver, the others are brass.
DJ Apolaro
Old 01-15-2009, 03:29 PM   #2981
Just checked and there was 1 shim silver and it was .3
Old 01-15-2009, 03:42 PM   #2982
dj apolaro's Avatar
Perfect. That motor is ready for 16%.
DJ Apolaro
Old 01-15-2009, 04:32 PM   #2983
anybody have any good breakin methods for these engines. I do have a breakin bench.
Old 01-16-2009, 02:50 PM   #2984
dj apolaro's Avatar
First I would take the motor apart and clean it. Make sure there is nothing of dirt in the motor. I do this with all new motors. For the break in I would do the first 6 tanks on the break in brench at "WOT" (wide open throttle). Try to get some heat in the motor while doing this. Around 180-190 degrees. You may have to put some aluminum foil around the head of the motor.
Then put it in the car. Use a soft clutch that engages very easy and set the 2speed to shift easy also. Run it in the car for about 5 tanks very rich, it may not even shift at first. Key note; make sure to let the motor sit between tanks at all times and make sure the piston is NOT at the top of the sleeve. This methods helps cycle heat into the motor and helps set the piston and sleeve. After these 5 tanks start leaning the motor a little at a time per tank. Over the next 3 tanks it should get close to a rich race tune.
At this point take the clutch off the motor and rebuild it to normal race conditions and reset the 2speed to normal also. Now the motor is ready to race and should run good and consistent.
Hope this helps,
DJ Apolaro
Old 01-16-2009, 04:44 PM   #2985
Just to make sure when you mean 6 tanks, is that 6 of the 150cc tank on the breakin bench or is that 6 75cc tanks like on the car because the tank is 150cc on the bench. And wouldn't WOT put alot of stress on the conrod?
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
