Like Tree32Likes
Old 10-06-2008, 08:06 AM   #2836
Team Kamikaze's Avatar
Originally Posted by katze View Post
anyone know whats the actual head clearance for a 353? is it the same as the 3sct, ie 0.3mm + 0.3mm?
if thats the case, it should be safe to not add anymore shims for 25% nitro right? even if you add 0.1mm of shimming, isnt it a bit too much, ie 0.7mm? top end will suffer?
You will actually gain top end when adding shims, but you lose a little bit of bottom end, there should be a total of .55mm to .60mm shims if using 25% fuel.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-13-2008, 05:49 AM   #2837
which one is better the 353 or the 353 tune? Why?
Kyosho Baby
The Rookie is offline   Reply With Quote
Old 10-13-2008, 10:21 AM   #2838
Riketsu's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to Riketsu
Performance wise, the 353 tune would be better. I have seen a tuned's crankshaft and it has some nice cuts... I do not know if they changed the 353 tuned's timing. If they didn't I'd suggest getting the stock one, because the tuned one does not have any sleeve modifications...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 10-13-2008, 04:32 PM   #2839
well I race down at 301 and I need a motor with some legs and some punch I don't if to get the +12 or the 353
Kyosho Baby
Old 10-13-2008, 06:53 PM   #2840
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
I have heard the novarossi plugs don't last long.I know a couple people are using ninja plugs in theres.Are there any other plugs that work for this motor or are designed to work with novarossi.I have a 35plus21lc/wc.Thanks
sm1nts2escape is offline   Reply With Quote
Old 10-13-2008, 07:57 PM   #2841
wingracer's Avatar
Trader Rating: 23 (100%+)
Nova and RB plugs are great. Ninja's and GRP are even better.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-14-2008, 08:45 AM   #2842
Suspended
I think ninja plugs are the best I've been using them in my novarossi motors and they last a VERY long time unlike novarossi plugs!
Team-Shepherd // XS Power // IDM Engines // TKO Bearings // Airtronics
00VIP001 is offline   Reply With Quote
Old 10-14-2008, 09:56 AM   #2843
gearhead_22's Avatar
Send a message via AIM to gearhead_22
In my 353 I still have the plug in it that I broke the engine in with and I got the motor new in april. pluse in 321 in my 960, that plug has been it it sence the 8th scale nats.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is online now   Reply With Quote
Old 10-19-2008, 07:21 AM   #2844
It is almost a year since i last played with my G4S. It is powered by a Novarossi Rex engine(RE 12S3). I was expecting some difficulties in starting up the engine. But it turn out to be effortless.The compression is still strong. Thumbs up for the quality in Novarrossi engines. The car "shoots" like an arrow at the slightest pull of the trigger. A lot of power in it. But there is a problem; the engine can't hold the idling, it just dies off after a few seconds if i stop pressing the throttle. What could be the problem? How can it be resolved? Please advise me. Thank you.
Kiowa is offline   Reply With Quote
Old 10-19-2008, 06:57 PM   #2845
kschu's Avatar
Send a message via MSN to kschu
u might try increase your idling screw abit...
Give the best while u can !
kschu is offline   Reply With Quote
Old 10-19-2008, 07:50 PM   #2846
Trader Rating: 12 (93%+)
check your idle and low end mixture and if you haventd one so already try a new plug and fresh fuel
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 10-22-2008, 08:11 AM   #2847
Thanks for your reply. When idle screw & low end needle are mentioned, do you mean clockwise or counter clockwise? How to determine when to stop turning the screw? By listening to the sound of the engine or what? Oh yes my engine produces a "rough, dry" sound. Does it mean it is lean? The G4S is no longer in production. What are the essential spare parts i need to get(parts that wear @ fast rate)? Are they compatible with G4RS? Thanks & have a nice day.
Old 10-22-2008, 08:33 AM   #2848
I'm running 353 how come after straight then getting into concern. The car seems still want to run. I have richer the low end and it helps a bit but still happening the problem. If I richer too much low end, the engine has worse response. What should I do?
ioxqq is offline   Reply With Quote
Old 10-22-2008, 09:26 AM   #2849
JayL's Avatar
either your idle is too high
or
your clutch is dragging
JayL is offline   Reply With Quote
Old 10-23-2008, 04:54 AM   #2850
The idle can't low anymore. If I lower it, engine will be die after the car stoped when the rpm goes down.
I have tried to adjust the clutch with harder tension. But i think if I do it more, I will have too much cap on throttle before the car moves.
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
