Old 04-20-2004, 12:53 AM   #271
ziggy12345's Avatar
TECHNICAL DATA
TT 12 TT 12 T
C. CAPACITY 2.1 c.c. 2.1 c.c.
POWER 1.35 H.P. 1.35 H.P.
R.P.M. 36.000 37.000
STROKE 14.00 14.00
BORE 13.80 13.80
PORTS 3 3
WEIGHT gr 240 gr. 240
SHAFT 11mm 11mm
TOP TT 12
From Novarossi site
ziggy12345 is offline   Reply With Quote
Old 04-20-2004, 01:28 AM   #272
VenomWorldOrder's Avatar
hi i have a nsr12 s3 nova and i'd like to changed the motor bearings to ceramic bearings. i visited the bocabearings site and sent them a email but i still haven't found, or recieved a reply of the correct bearings i need.
i noticed on the boca site there are:
high speed and
high temp bearings
which are better for the .12 use? i want the higher rpm, but does this mean they will explode at high heat? ie 150degrees celcius, it is the R version so i am going to run it at the required temp for max performance.
MY QUESTION IS WHICH MODEL NUMBER BEARING DO I GET? I WANT FULL CERAMIC BEARINGS.
thanks
pm me the answer please as i don't visit the engine thread often
VenomWorldOrder is offline   Reply With Quote
Old 04-20-2004, 03:52 AM   #273
stefan's Avatar
Send a message via AIM to stefan
Originally posted by ziggy12345
TECHNICAL DATA
TT 12 TT 12 T
STROKE 14.00 14.00
BORE 13.80 13.80
PORTS 3 3
SHAFT 11mm 11mm
TOP TT 12
From Novarossi site
Ziggy, TSR12, not TT12.
Frag, I ran mine the first time this past weekend. Fastest engine I've ever had.
stefan is offline   Reply With Quote
Old 04-20-2004, 04:52 AM   #274
ziggy12345's Avatar
Sorry
TSR12S5
1.62hp
43,500rpm
5ports
13.80 X 14.04
turbo
11.5
NSR12S5
1.62hp
43,500rpm
5ports
13.80 X 14.04
turbo
11.5
No difference in spec to the NSR. Is there a difference in power band?
Old 04-20-2004, 04:52 AM   #275
BaxterC's Avatar
So the TSR12 actually exists, I would imagine that it would be identical to the NSR12, only different markings and head colour?
BaxterC is offline   Reply With Quote
Old 04-20-2004, 07:00 AM   #276
ziggy12345's Avatar
I*'ll mail my contact at Novarossi and find out if there is a difference. I cant see any on the spec sheet
Cheers
Old 04-20-2004, 08:27 AM   #277
BaxterC's Avatar
Cheers
Thank you Ziggy...
Old 04-20-2004, 08:45 AM   #278
afm
afm's Avatar
You are right, Novarossi manufactures under three different brands, Novarossi, Top and Rex. All of them have the same engine version with same characteristics.
Novarossi = NSR12S3(5)
Top = TSR12S3(5)
REX = RER12S3(5)
Question of marketing. Same girl with different underwear.
AFM
afm is offline   Reply With Quote
Old 04-20-2004, 08:52 AM   #279
stefan's Avatar
Old 04-20-2004, 09:09 AM   #280
BaxterC's Avatar
I see, thank you. I wonder, are the Top and Rex motors cheaper than the Novarossi Stablemates, I would expect so, otherwise, why make 3 motors, with the same specs, and the same price, with different names, at the same time? seems odd. Maybe I am just being stupid. or not thinking as usual...
Old 04-20-2004, 10:07 AM   #281
stefan's Avatar
1.) It's not the same spec than the Nova Rossi. It's made to Jim Hottinger's spec. (the guy who ran Paris Racing and now owns Fusion Motorsorts)
2.) It's not cheaper, it's more expensive than the NR!
3.) It's worth it!
Old 04-20-2004, 10:27 AM   #282
BaxterC's Avatar
3.) It's worth it!
Well, I have been knocked sideways... Where does one get one from? I thought the Nova's were the best from there, I never even looked at the TOP or REX motors as I was under the impression that they were budget motors, like Celeron and P4, and Duron and Athlon, like H... No War Starting... sorry...
Where can one get one from (not ebay) ? they look cool with the black... I wander what the Palmaris puts out.
Old 04-20-2004, 11:03 AM   #283
stefan's Avatar
Usually, they are all exactly the same, no 1st or 2nd tier, but in this case it seems that Jim got special Top versions for the US.
www.nitrohouse.com
under engines -> Nova Rossi -> all the way on the bottom.
Old 04-20-2004, 07:46 PM   #284
Trader Rating: 4 (83%+)
I think reason for having 3 brands is so they can have more exclusive distributors in each region. Sort of what Gadini does with Elligi/Power/Fast/Sprint/...etc tires. Except for the Mugen Fast with different rims, all other brand use the same rims and rubbers for touring car tires.
On the external, the engines all have slightly different crank case... The internal porting are exactly the same. If you are after a stock engine I think they are all the same. You have to go to JP/Max/M.Rossi version to get one that has been worked on.
slooookomo is offline   Reply With Quote
Old 04-20-2004, 08:39 PM   #285
Nitropimp's Avatar
Wow I'm lost now Not that's something new But I thought NovaMega and NovaMax were Novarossi engines too. Are RB's Novarosssi too???
Nitropimp is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
