Like Tree8Likes
Old 09-14-2008, 06:42 PM   #2806
chadlow21's Avatar
I just bought this M12 and I'm not sure how the flywheel and clutch set-up is supposed to go on the crank shaft, the crank seems to have an extention or something on it as you can see in the pics, I just dont see how a flywheel can be bolted on to it, can someone help please. Thanks,
Chad
Novarossi engines thread-delta-016.jpg   Novarossi engines thread-delta-018.jpg   Novarossi engines thread-delta-017.jpg
Zerodog Designs
chadlow21 is offline   Reply With Quote
Old 09-14-2008, 06:48 PM   #2807
PROVK's Avatar
Trader Rating: 14 (100%+)
Go get a refund mate.
Thats looks like a threaded type crank shaft with an adaptor of some type on there
I cant see it working
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 09-14-2008, 08:08 PM   #2808
Michael_T's Avatar
Trader Rating: 47 (100%+)
Send a message via MSN to Michael_T
Either it is a cheap fix to a broken crank, or a weird modification...
I would return it, otherwise you would need to source a M12 crank which wouldn't be worth it.
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 09-15-2008, 04:52 AM   #2809
chadlow21's Avatar
Ok, thanks, I only paid $15 for it, so I guess its not that bad, sucks because O.S Rocket just pinched it and you would think that he would have said something.
Zerodog Designs
Old 09-15-2008, 04:59 AM   #2810
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
I used to have an Mugen MT-12 that had an SG adaptor so it would fit on my MTX-3... But I dont see that crankshaft having the thread for the centax clutch, so I dunno.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 09-15-2008, 05:20 AM   #2811
lil-bump's Avatar
Trader Rating: 82 (100%+)
OS rocket just does the pinch; he has no idea of your specific application
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 09-15-2008, 05:24 AM   #2812
chadlow21's Avatar
So, what is a centax clutch? The crank is a 2 piece, it doesnt look like it was ever broken and fixed. The end of the crank has a hex end and the front half unscrews from the rest of the crank, when you take the front piece off, the hole where it threads into seems to be smooth and clean like it came that way from the factory.
Zerodog Designs
Old 09-15-2008, 06:25 AM   #2813
wingracer's Avatar
Trader Rating: 22 (100%+)
It's a standard shaft crank that someone has put some oddball thing into. The standard cranks were two piece back then.
If you need a standard shaft crank you can get a bolt the right size to thread into the crank and then cut off to length.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-15-2008, 01:47 PM   #2814
chadlow21's Avatar
Thanks wingracer
Zerodog Designs
Old 09-15-2008, 02:17 PM   #2815
Roelof's Avatar
Send a message via ICQ to Roelof
And if you need to fix a Centax clutch you can search for a special adapter which is delivered with the HPI R40
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 09-15-2008, 02:45 PM   #2816
JayL's Avatar
Originally Posted by JayL View Post
What is the Nova part number for the spring that connects the exhaust pipe to the manifold, 2630 to nova 6 fin conical? The only spring I could find was part #60004 and they are shorter than the ones I got with the manifold...
Nobody knows?
JayL is offline   Reply With Quote
Old 09-17-2008, 10:22 AM   #2817
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
OK I have a quick question you guy's, I am currently usin g the NS12 TS1 with a 2630 pipe and the short manifold. I am able to get just over 5-6 mins run time with this combo but I am wondering what pipe I would go with that would help to get better fuel consumption out of my engine??
Sean
HB/HPI Racing | Morgan Fuels | HOBBYWING | Airtronics | REDS Racing | HRP | Hobby Revolution | Team N.E.R.D.
BLKNOTCH is offline   Reply With Quote
Old 09-17-2008, 11:26 AM   #2818
N.O
Sean
use the RB 2604
N.O is offline   Reply With Quote
Old 09-17-2008, 11:42 AM   #2819
BLKNOTCH's Avatar
Originally Posted by N.O View Post
use the RB 2604
This will give better fuel consumption? how will this effect the power?
Sean
Old 09-17-2008, 02:36 PM   #2820
JayL's Avatar
the 2602 has great runtime. With the 2602 mani and pipe , max, I got at least 1:30 mins more runtime over 2630 with med conical mani, the race director said 'track closed' so I didn't get to go past 6:30 but I had fuel left
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
