Like Tree33Likes
Old 08-18-2008, 05:28 PM   #2776
PROVK's Avatar
Trader Rating: 14 (100%+)
Originally Posted by wingracer View Post
Yep I three spring them. One long one and two short ones.
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 08-18-2008, 06:01 PM   #2777
JetMD's Avatar
Sean, You got a private message.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 08-19-2008, 07:28 AM   #2778
Bad Mika's Avatar
Default urgent help needed...
(Sorry to hijack this thread... but really need urgent help and advice, many thanks...)
Hello all JP lovers ,
Need some urgent help and advice...
I just got my first JP , was very excited about it but unfortunately the clutch bell bearings ARE NOT ABLE TO SLIDE IN to my surprise
I have other engines nova 353, os tz, nova max etc... and never had this problem but this is my first JP , by the way my clutch set is from the mugen mtx4r...
Appreciate if anyone could share if they encounter any sort of this experience... Many thanks !
Bad Mika is offline   Reply With Quote
Old 08-19-2008, 07:48 AM   #2779
wingracer's Avatar
Trader Rating: 23 (100%+)
Got it. Give it to me next time you see me or Ricky if you see him first.
Answered in the JP thread.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-24-2008, 10:16 PM   #2780
hi i just bought a nova 3sct and i already broke in the engine, and started to racing, but i being having hot temps, like 230f i think thats pretty hot, what do you think, i think i might be 'cause i run the engine with the stock shims at 30% nitro with the stock plug which i think it's pretty could. what do you think temps are good or too hot?
mc_chofo is offline   Reply With Quote
Old 08-25-2008, 12:08 AM   #2781
stefan's Avatar
Send a message via AIM to stefan
These engines with the new cooling head do show higher temperatures when you measure, especially when you have a cheap temp gun.
With the Exergen it's more realistic.
I run mine at 130-140C, which is around 100C at the block, directly under the head.
Further, you modified that engine, which also brings the temps up.
stefan is offline   Reply With Quote
Old 08-25-2008, 04:47 AM   #2782
wingracer's Avatar
230f is pretty cool. As for the shims, as long as it's not killing plugs you should be fine. To be sure pull the head off. If the top of the piston and/or bottom of the head have a rough sandblasted look then you need to add a shim.
Team Shepherd USA
Old 08-25-2008, 05:45 AM   #2783
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Even with the exergen... I still run it on the hot side... It seems my sct likes to run 250-260, thats when I find it running at optimum performance...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-25-2008, 08:20 AM   #2784
Derby Bros Racing's Avatar
230 is break in temp .
Kidding aside, tune your motor to performance and smoke trail. You'll notice that it will run best at about 260 to 290 degrees Farenheit depending on your location (some location are already hot like where I'm from 135 degrees asphalt on raceday is normal ).
Derby Bros Racing is offline   Reply With Quote
Old 08-25-2008, 09:28 AM   #2785
Francis M.'s Avatar
I've had my +12 for over 1.5 years now and running on 5 gallons of Mugen 30% or O donnel 30% running at race temps of 230f to 269f depending on performance for the day....
I just checked the rod and the top of the piston and everything is o.k.
I've been running the skyline pipe with a nova/medium conical header with decent performance...
I just bought the nova 2630 pipe so I'll let you guys know what the differences are....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 08-25-2008, 07:19 PM   #2786
jk1152's Avatar
Default composite / plastic carburator (carb)
I have a Novarossi 12-sct plus, does anyone know if there is a plastic / composite carbuator (carb) that will fit? I run in hot weather, I run the first 10 minutes just fine then start to have vapor lock issues.
jk1152 is offline   Reply With Quote
Old 08-25-2008, 09:54 PM   #2787
the thing is that i re checked everything, and a guy on the track told me that my centax was not right, 'cause he said that my centax was hot, it' was like 160-170f, it had great grip but i don't know if i had just set the centx right, what do you think?
it's good to know that i will be safe if i run the engine between 240-270f, great to know.
Old 08-25-2008, 10:12 PM   #2788
Francis M.'s Avatar
I've never temped my clutch for settings... just set the clutch so the motor does not bog. tune the motor for performance and just use the temp gun so you don't run the motor past 300f
Old 08-25-2008, 11:49 PM   #2789
stefan's Avatar
The carb of the Picco Evo 3 will fit. It's a composite carb with a plastic insulation around the neck. Works great, not hot starting issues on the Picco.
Old 08-26-2008, 04:16 AM   #2790
Riketsu's Avatar
Check that your clutch bell is not hitting the chassis... This can cause the clutch to reach high temperature and probably melt the shoes like it happened to me...
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
