Old 08-05-2008, 09:05 AM   #2746
dj apolaro's Avatar
Novarossi takes 1,2,3 at the 2008 GLC. Using 359 motors.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 08-05-2008, 05:00 PM   #2747
JayL's Avatar
Originally Posted by Roniel_R View Post
You will need to have .40 in total...
Same for 25%?
JayL is offline   Reply With Quote
Old 08-08-2008, 06:46 AM   #2748
viper01's Avatar
Default novarossi sx12 turbo head factory carb settings
looking for factory carb settings
thanks for any information
viper01 is offline   Reply With Quote
Old 08-08-2008, 09:33 AM   #2749
ALG
Originally Posted by motojon View Post
Help..I Have a JP engine that is being tempermental. the bottom end will run intermitantly rich during a qual or a main, so we then have to lean the top end down to get it to run good and the temps are way high. i just agrrevating ill have it running real good pull in take a piss and then go back out and itll run fat on the bottom end
Make sure, that the orings are ok. If you can ALWAYS change ALL the ORING after tearing apart the engine.
Hope it helps
ALG is offline   Reply With Quote
Old 08-08-2008, 10:29 AM   #2750
speedy2's Avatar
I had have a jp B5t that was hard to set up like that
after 1 gallon or so, I mounted a non turbo head
and magic....
the engine was tuned immediately and
idled regularly too till now at 3 gallons
so perhaps it is not the carburator or o-rings
but a different turbo plug you need ..?
GiGi//JQ The Car forever/ Soar-Graupner//Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 08-15-2008, 10:22 PM   #2751
dameetz's Avatar
I have Plus21-3 7ports on road engine that I like to rebuild. I have changed the bearings and would like to change the piston liner and conrod as well. I just want to know if 35plus21 9ports or 359 9 ports piston liner and conrod can fit to my crankcase? If it fits will it make more power?
dameetz is offline   Reply With Quote
Old 08-16-2008, 05:53 AM   #2752
wingracer's Avatar
Trader Rating: 22 (100%+)
The 359 rod will not fit your crank.
35 +21 is almost the same motor. All parts should fit.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-17-2008, 06:22 AM   #2753
PROVK's Avatar
Trader Rating: 14 (100%+)
Hi Guys
I have done this a million times but first time with a Nova 21.
I am trying to install a mrx-4x clutch to a 35plus21 LC and seems like the clutch screw it too short and I cant get no end play with zero shims
Any help would be apprecaited
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 08-17-2008, 07:06 AM   #2754
Wynnum_Racer's Avatar
What pipe would be recomended to be used on a 359 plus 2? On a more Bottom to mid range sorta track
I have a 2052 and a 2015. But only used on the 35plus found the 2052 was better but was told that 2015 made more power on dyno
http://www.youtube.com/watch?v=canY93sF15I
http://www.youtube.com/watch?v=NmxE9udKKdA
Everyone watch my movies on youtube
Wynnum_Racer is offline   Reply With Quote
Old 08-17-2008, 07:19 AM   #2755
PROVK's Avatar
I think is pretty simple dude.
You have both pipe right, then take them both to the track and test
George V
Mugen Seiki
www.rrcsa.org.au
Old 08-17-2008, 07:28 AM   #2756
Yeah i know i will with those 2. But they do make more then just those 2 pipes. Has anyone tried the others and had luck with them.
Old 08-17-2008, 07:32 AM   #2757
PROVK's Avatar
Wynum Racer
Read 2 posts up, did u have any probs with clutch install on 359
George V
Mugen Seiki
www.rrcsa.org.au
Old 08-17-2008, 08:01 AM   #2758
Nope no issue. None with my 35plus either maybe wrong fly wheel nut
Old 08-17-2008, 09:43 AM   #2759
Bad Mika's Avatar
Default ...
Originally Posted by PROVK View Post
Hi Guys
hi, i had the same problem of not enough endplay with zero shims on my mtx4r clutch with my nova 353... had to put and add a small shim at the end of the crankshaft between the lock screw.
did not like it, but not much choice.... others i asked did not need to do this . don't know why like that... couldn't possibly be they have different length crank shaft ??
Bad Mika is offline   Reply With Quote
Old 08-17-2008, 11:52 AM   #2760
The difference is most likely in the flywheel collet. Some are thicker than others. A thick collet against a flywheel that needs a thin one would move the whole assembly 1-or 2 mm futher down the shaft, thus eating up the play that you would normally have.
TM, Murnan, RB, Morgan, Nomadio, GQ, Integy, GP, Duratrax, Protoform, Cruisin, Raceday, Wolf
GBagRacing is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
