Like Tree21Likes
Old 07-19-2008, 07:49 AM   #2731
Bad Mika's Avatar
Default pipes...
Originally Posted by Bad Mika View Post
correction.. should be 2601/51606 or 52626
very sorry, type too fast..
correction.. should be 2601/51606 or 52606
Bad Mika is offline   Reply With Quote
Old 07-22-2008, 06:14 PM   #2732
fatboy's Avatar
Send a message via MSN to fatboy
I would be very much appreciate if anyone would provide me the follow information what is the rear bearing size for the following engines:-
1) Nova 35 plus 21 Tuned : Ceramic Rear : 14.5 x ? x ?
2) Nova Kangaroo 2007 : Rear Bearing : Size 14 x ? x ?
3) Both Engine Front Should b the same but size ? x ? x ?
fatboy is offline   Reply With Quote
Old 07-22-2008, 06:31 PM   #2733
wingracer's Avatar
Trader Rating: 23 (100%+)
1) Nova 35 plus 21 Tuned : Ceramic Rear : Size ?
2) Nova Kangaroo 2007 : Rear Bearing : Size ?
3) Both Engine Front Should b the same but size ??
35 plus 21 rear bearing:
http://tkocompetitiondev.com/shop/pr...roducts_id=361
This is the one for the R1WC kangaroo. Not sure if the 2007 version uses this or the bigger one above:
http://tkocompetitiondev.com/shop/pr...roducts_id=206
Front bearing:
http://tkocompetitiondev.com/shop/pr...roducts_id=156
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-27-2008, 08:03 PM   #2734
mcsquish's Avatar
Originally Posted by NinjaRacer View Post
Whats better a Novarossi 353 Race or a Picco JLReddot Evo 3?
Not sure if you're still looking for an answer, but I have been running a Reddot Evo 3 Modified and have decided to go back to Novarossi...........
Originally Posted by GHETTOTEACHER View Post
I have a question.
Is there a huge difference between the tuned 353 vs the stock 353 ?
Let me know what you think.
Did you get an answer? I'm going to order one tomorrow.
mcsquish is offline   Reply With Quote
Old 07-29-2008, 10:10 AM   #2735
Suspended
Trader Rating: 34 (97%+)
Quick question. should I be running a JP-1 pipe on a 528x r or will that cause tuning problems. Tuning problems are what I'm having, everything is sealed up nice and I do have a pretty good grasp on tuning. Just wondering if the JP-1 is too much low end tune and causing issues. I will try another pipe but it's the pipe that came stock with the Hyper ST PRO and not sure how good it is either.
Thanks for any input.
FG101C is offline   Reply With Quote
Old 07-29-2008, 10:50 AM   #2736
speedy2's Avatar
I run a JP Fx B5t with normal plug
+ Jp1 and 13/44 ratio
and on the straight nobody is quicker bottom
and I must go off the throttle at the end or the buggy will take off..
//JQ The Car forever/ Soar-Graupner//Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 07-29-2008, 07:42 PM   #2737
suntok2's Avatar
Send a message via ICQ to suntok2 Send a message via AIM to suntok2 Send a message via Yahoo to suntok2
How many shim does your engine have?
suntok2 is offline   Reply With Quote
Old 07-30-2008, 10:14 AM   #2738
David Day's Avatar
Send a message via AIM to David Day Send a message via MSN to David Day Send a message via Yahoo to David Day
What pipe should be ran with the Nova P5XS for maximum performance?
Will the OFNA 086 work?
Day Brothers Racing
*http://daybrosracing.webege.com*
2nd Place 2006 Winter Series 10th/Scale Gas @ Lake Havasu RC Raceway
RC10GT - Snoopy #5x
Kyosho Inferno777 WC SP2
David Day is offline   Reply With Quote
Old 07-30-2008, 11:24 AM   #2739
wingracer's Avatar
086 is a great choice for any Nova based motor.
Team Shepherd USA
Old 07-30-2008, 11:38 AM   #2740
David Day's Avatar
Awesome, Thank you
Day Brothers Racing
RC10GT - Snoopy #5x
Old 07-30-2008, 04:19 PM   #2741
Send a message via Yahoo to motojon
Help..I Have a JP engine that is being tempermental. the bottom end will run intermitantly rich during a qual or a main, so we then have to lean the top end down to get it to run good and the temps are way high. i just agrrevating ill have it running real good pull in take a piss and then go back out and itll run fat on the bottom end
motojon is offline   Reply With Quote
Old 08-04-2008, 09:29 PM   #2742
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
Can someone tell me how many shims do I need for a Novarossi 353 and a 12-3SCT if I use 20% fuel???
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-05-2008, 06:58 AM   #2743
Trader Rating: 4 (83%+)
You will need to have .40 in total...
Roniel_R is offline   Reply With Quote
Old 08-05-2008, 07:12 AM   #2744
Riketsu's Avatar
Thanks Roniel...
its the same for both? and thats mm for shims not actual head clearence right?
Old 08-05-2008, 07:32 AM   #2745
Yeah just measure all the shims together and you should have 0.40mm
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
andreas78
