Like Tree33Likes
Old 06-26-2008, 11:20 PM   #2701
keavze's Avatar
do the new nova engines come with a carb with insulator at the neck?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 06-27-2008, 01:57 AM   #2702
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by TOMJR View Post
Which is the best pipe to go with the 353 engine ?
The 2630 is a rpm pipe, if you get a good one. They seem to vary in quality.
The 2602 is a better all around pipe IMHO. It gives you more torque and better midrange but you loose a few rpm's.
Most people here like the 2602 better.
stefan is offline   Reply With Quote
Old 06-27-2008, 03:12 AM   #2703
GREGORY!'s Avatar
how can someone understant if he has a good one?
GREGORY! is offline   Reply With Quote
Old 06-27-2008, 04:50 PM   #2704
Default novarossi 367
what is the plus2? how is it better than before? plz share your experience. I am considering getting one.
silverM3 is offline   Reply With Quote
Old 06-29-2008, 05:19 PM   #2705
NitroWD's Avatar
Originally Posted by BLKNOTCH View Post
I will let you know what I think next weekend as I have a new NS12TS1 which I have just broken in ujsing Josh Cryles method, I also have an O.S. .12 TZ so I will run them both next weekend and let you know what I find is better.
Sean
hi sean, any feedbacks?
NitroWD is offline   Reply With Quote
Old 07-08-2008, 06:14 AM   #2706
Bad Mika's Avatar
Default novarossi 353 plus 2
hi, if the race i'm attending does not restrict me to a 5.2mm pipe and can go 'outlaw', which pipe should i consider to match with the 353 plus2 engine ?
thanks in advance
Bad Mika is offline   Reply With Quote
Old 07-09-2008, 11:49 AM   #2707
What about pipes for .21 onroad engines? All I hear about is the 2015, what are other options and the attributes of those pipes compared to each other. Or is the 2015 "the" pipe?
automator is offline   Reply With Quote
Old 07-09-2008, 12:51 PM   #2708
wingracer's Avatar
Trader Rating: 23 (100%+)
thanks in advance
I would go with whatever the latest and greatest Nova pipe is and if you don't care about rules just drill out the stinger a bit.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-09-2008, 12:53 PM   #2709
wingracer's Avatar
Well, the 2015 is an excellent all around pipe. If you want to try something different try out a Sirio or RB 2013. Sounds different, looks different, runs great.
Team Shepherd USA
Old 07-10-2008, 05:25 AM   #2710
Is there a 2052 pipe or something like that? How does that pipe compare to the 2015 or 2013?
Old 07-10-2008, 03:37 PM   #2711
Someone tried to Efra 2604 Rb in this engine 353??
Alambrito is offline   Reply With Quote
Old 07-11-2008, 06:40 AM   #2712
Bad Mika's Avatar
Default pipes
hi, anyone can enlighten what is the difference between the 2601 pipe, 2607 pipe and the 2620 pipe ?
am more familiar with 2630 and 51607 pipes..
thanks in advance..
Old 07-11-2008, 10:04 AM   #2713
Lots of pipe questions...where are the experts at?
Old 07-11-2008, 05:34 PM   #2714
MHarrison's Avatar
thanks in advance..
The 2601 pipe is a good all round pipe ( very similar to the 2602 )good low,mid & top end With best fuel mileage,the 2620 is gonna give you a little more top end over the 2601. the 2607 is a picco based pipe..if you have created a header to fit a nova motor its gonna give you alot more bottom But I find it very flat from mid to high RPMs. It does however work great on the picco motors..but again not on long straights. hope this helps
MHarrison is offline   Reply With Quote
Old 07-12-2008, 12:14 AM   #2715
stefan's Avatar
When your engine runs good, you got a good one. If everybody else with the same engine / pipe combo passes you, you got a bad one.
Easy actually, ain't it?
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
