Novarossi engines thread
#2660
This weekend we had our Region 4 Championship. I want to say thanks to Novarossi for providing such great products. I was able to TQ sedan and 1/8 scale and win the Sedan main. I had some issues in the 1/8 scale main, but had the fastest lap and fastest car. Thanks again Nova.
DJ Apolaro
DJ Apolaro
#2662
35plus21 get the biggest conrod's hole diameter, while 359 get the smallest conrod's hole.
#2663
manifold question
can someone share their knowledge/experience on the effects or performance of using the different manifolds on your nova engine?
type - performance
short (3-fins) - ???
medium (4-fins) - ???
lonog (5-fins) - ???
which manifold is best for
12-3SCT
LS3
LL5
type - performance
12-3SCT
LS3
LL5
#2664
A longer manifold will give a longer exhaust system what will result in more bottom power and less top RPM. This is basic 2-stroke theory.
#2665
#2666
It is all about resonation, the shockwave comming back to the engine act like a exhaust valve keeping the fresh fuel in the motor. Shorter exhaust will give a shorter resonation time which will give the better timing on higher rpm's
All you want to know about 2 stroke engines, their exhausts and tuning:
http://edj.net/2stroke/jennings/
#2667
Okey, thanks..... I know that too. I was testing your education skill.
#2668
yeah...right.....
#2669
Temperature of 35 plus 21 Collari
Hi guys!
One of my motors is the Collari (1) version of the Nova 35 plus 21 mill. Whatever I do, I can not get the temperature below 120 deg. C. A little bit richer on the HSN needle and the car wont even go into second gear. The motor smokes like a steam train, which is telling me that it is still to rich. Performance is close to other engines on the track, even that rich. Piston/sleeve contact area is smooth with no scratches and compression is very high (hard to turn flywheel over hot and cold). Standard head gap with 0,7mm shim stack. 25% Nitro, Orcan/Serpent fuel (Jonker Netherlands).
I know how to tune an engine, and I ran other engines leaner with temps around 110 deg. C, so I think the Collari "likes" or needs higher temperatures.
Any thoughts or advise on this?
Many thanks in advance!
Regards Stefan
Regards Stefan
#2670
It can be the exhaust, the Sirio 2013 exhaust can make the engine 15 to 20 degrees higher.
