Like Tree21Likes
Old 02-28-2008, 07:22 AM   #2596
FF25510's Avatar
Originally Posted by teamgp View Post
Long body is for lower nitro content and/or higher humidity, and vice versa for short body. Here is a good page to print out.
that's what i'm looking for. thanks.
FF25510 is offline   Reply With Quote
Old 02-28-2008, 07:43 AM   #2597
choisan's Avatar
I have a 35Plus 3 and the inside large bearing 14.5 x 26 x 6mm is quite expensive. Found from ebay that it has the same size with no brand, wonder if anyone tried and any comment?
choisan is offline   Reply With Quote
Old 02-28-2008, 08:18 AM   #2598
Trader Rating: 4 (83%+)
i have tried them in my Nova engines and they hold up as good or better than the original Nova ones..
Roniel_R is offline   Reply With Quote
Old 02-28-2008, 02:57 PM   #2599
Team Kamikaze's Avatar
You can replace it with the original same size non ceramic bearing which is way cheaper.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-04-2008, 10:30 PM   #2600
Hi guys, can someone please help?
What differences did you find between the Max Power 2602 pipe and novarossi 2630 medium header on the Nova Plus 12-3t? Thanks!
air jordan is offline   Reply With Quote
Old 03-08-2008, 01:58 PM   #2601
rfy
Hi DJ,
On your shimming response above..does it hold true for .21 engines as well. thanks.
rfy is offline   Reply With Quote
Old 03-09-2008, 06:02 AM   #2602
the lower the compression ratio the higher the nitro you can run
Andyg01 is offline   Reply With Quote
Old 03-25-2008, 08:42 AM   #2603
I've just got a Nova m.12 from another racer, and had some problems tuning it. It would either run so rich it spurted fuel from the pipe, or so lean it would get very hot...there was no happy middle ground. Either way it had very little power. I opened it up to find a sleeve installed backward, IE the top edge of the sleeve had been cut with a dremel to fit the locating pin....the sleeve was for an engine with the pin on the other side! The exhaust port does line up very close to perfect, maybe .5mm off at most. The sleeve fits the block a touch looser than any of my other motors as well. Finally the crank has some sort of goo in it to create a fuel ramp which is now flaking off, am i correct to assume this engine did not come with these "mods?"
luke81 is offline   Reply With Quote
Old 03-25-2008, 10:07 AM   #2604
sounds like you have been done.
have a look here for correct parts
http://www.novarossi.it/
good luck
Old 03-25-2008, 01:20 PM   #2605
dj apolaro's Avatar
Originally Posted by rfy View Post
Hi DJ,
If I am not mistaken .21's come shimmed for 25% stock. Start with that and see how the piston and plug look to fine tune. Check the piston every few runs
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 03-30-2008, 03:25 AM   #2606
Default plus 2 353
why does the new plus 2 353 2008 edition comes in one engine at the same price as the 2 in one package...i would ecxept it to be at least 100$ off the retail price of the previous version that included the practise engine as well...(i saw it at rc-mushroom for 499$)...unfortunately it's very expensive compared to the plus 1 series which i had bought(the plus 12 ct) for 300$...that makes us a difference of 200$..it's really high priced.what's your opinions guys if we take in mind that there are out there engines at the same specs like rb r3 , os speed2 , sirio evo 4 etc that cost at least 150$-200$ less?
nickiphorosn is offline   Reply With Quote
Old 03-30-2008, 10:14 AM   #2607
stefan's Avatar
Send a message via AIM to stefan
If that's the case, you are being screwed. Over here in Europe, the 2008 353 single package is around 300, while the double pack from last year was 500.
I some shops, the new Plus 2 is only 5 more than the 12-3 ST.
http://www.spracing.it/catalog/index...Path=48_50_100
stefan is offline   Reply With Quote
Old 03-30-2008, 02:14 PM   #2608
YANMAN's Avatar
Trader Rating: 38 (100%+)
Just looking for a little help. There are so many options for .12 engines now and I have no idea where to go. I am coming back to touring car after 5+ years running off-road. I know I want to run Nova, but there are so many engines, 353, +.12 3SCT, LS3, LL3... I was thinking the +.12 3SCT was the way to go, put now that the 353 is about the same price I was thinking that the 353 is the way to go. Please help. Is the 353 a good all around engine? Short and big tracks? I know the +12 3SCT is a good short track engine and you can gear it to the moon for the big tracks. Just want to get the best all around engine. Thanks for any help
Tim
YANMAN is offline   Reply With Quote
Old 03-31-2008, 10:21 AM   #2609
asw7576's Avatar
Default Low Quality Novarossi Glow Plugs during 2005 - 2007 periods
I'm not bashing novarossi ..... infact, I'm novarossi loyal consumers with 10 novarossi engines in my rc box.
I have the feeling 2005, 2006, 2007 production of novarossi glowplugs were not long lasting as they were in 2003. The glow plugs have short life span, sometimes last only 20 - 30 minutes. It seems the glow plugs cannot stand long period of high operating temperatures ( I live in tropical country ). Lately I have to prepare 3 - 4 glow plugs for 1 day racing ( 1/10 engine ), and 4-5 glow plugs for 1/8 . Currently my glow plugs are easy to die resulted from high operating temperature ( 110 C )
Anyone have the same feeling ?
Old 03-31-2008, 05:24 PM   #2610
Ryan41's Avatar
Send a message via MSN to Ryan41
Honestly man, I think theres either something wrong with your fuel, or the tuning is a tad off. I would guess fuel maybe. There is no way you should be going through 4-5 glow plugs in one race day. You should only really need 1 or 2 spare plugs in case you blow one..but 5 is rediculous!
I very rarely go through plugs, using Runnertime. However I change the plug once every 2 meets, just as a pre-caution.
but yeh, what fuel you running?
cheers
Capricorn Tourer
AE TC5R- Drifter
Revo to annoy the dog
Yokomo DRB drifter for the missus.
Ryan41 is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
