Like Tree9Likes
Old 02-09-2008, 04:47 PM   #2566
Originally Posted by cdelong View Post
the LC rod will not fit the 359. My understanding is that the LC has a smaller crank pin. The LC/WC rod says C2 on it.
I believe a 35+ rod will fit a 359, but the #'s are different. 35+ takes a R7 rod with standard pin clips and the 359 takes a P1 rod with different clips.
Thanks cdelong, please confirm so i can buy them. What about the .12 con-rods? .. 359 and 353 rods are hard to get where im from , so i just need options.
seikob is offline   Reply With Quote
Old 02-10-2008, 12:51 AM   #2567
stefan's Avatar
Send a message via AIM to stefan
same goes for the 353. the crank pin is slightly smaller than that of the regular Plus 12-3 engines
stefan is offline   Reply With Quote
Old 02-10-2008, 04:07 AM   #2568
JetMD's Avatar
Anyone know the difference on the version 2 of the 353? Thanks.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 02-10-2008, 04:30 AM   #2569
stefan's Avatar
The mounting point on the case have been slightly changed so it would fit into that XRay car
Old 02-10-2008, 07:03 AM   #2570
Trader Rating: 72 (100%+)
Default Rods
359 crank pin dia. is 4.45 mm ( P1 rod # 07011 )
35+ LC crank pin dia. is 4.71 mm ( C1 rod # 07010 )
I undestand that the LC/WC has a C2 on the rod with part # 07010/1
Original & current 35 Plus 21 uses a (R7 rod # 07009) with a crank pin dia. of 4.99 mm ( R4, R5 & R6 rods will also work )
.12 353 Race ( rod # 07602 )
.12 Plus 12-3SCT (rod # 07601)
Nitro-mech is offline   Reply With Quote
Old 02-10-2008, 08:30 AM   #2571
does anyone know the difference in performance between the +12 sct and +12ct. i know the sct has a bigger crank. which engine has better performance?
thanks in advance
Joe Chaplow is offline   Reply With Quote
Old 02-10-2008, 09:08 AM   #2572
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
neither is better neither is worse. the ct has more bottom end and torque while the sct has a smoother powerband and more top end. I dont think that the CT comes with the rubber seal at the head button, which is a plus because dirt doesnt go that way.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 02-10-2008, 03:22 PM   #2573
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
I was told they were both the same speed wise.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 02-10-2008, 06:58 PM   #2574
Riketsu's Avatar
the crank diameter changes... so I guess it changes somewhere in the powerband.
Old 02-11-2008, 07:36 PM   #2575
rcabj's Avatar
Default nova NS12 S3
after almost 15 tanks my NS12 S3 is still hard to fire up, piston still tight. guess i need to add few more tanks before it get less tight.
anyway, i find there is "freeplay" where the cranksahaft moves horizontally in and out after i install the cone+flywheel ( this before i started to break in process) ,i have tried a few times to reinstall but still the same is this normal or factory defects. but it idle and run normal.
thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 02-11-2008, 10:53 PM   #2576
Roelof's Avatar
Send a message via ICQ to Roelof
A smaller crankpin will give a lower surface speed on the pin at the higher revs. That will give less friction and also a better lubrication.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 02-12-2008, 09:37 AM   #2577
DS Motorsport's Avatar
He means the crank itself, the sct has a 11.9 mm crankshaft and the ct a 11.5 mm crankshaft. he want's to know what difference that make's
The inner diameter doesn't change because it's restricted.
The only thing that can make a difference are the smaller bearings used which are lighter, also the crank should have less flex so higher rev's.
Only the 353 race has a smaller crankpin, that's why it hase it's own special conrod's.
DS Motorsport is offline   Reply With Quote
Old 02-13-2008, 04:09 AM   #2578
Trader Rating: 62 (100%+)
Red face o-ring replacement - help please :)
is there a technique on how to replace the o-rings for the high and low end needles? im afraid i might rip up the o-rings because theyre a tight fit i just ripped up a couple while removing them, and now im about to install new ones, but they are so difficult to put it any help would be greatly appreciated, thanks
marvi is offline   Reply With Quote
Old 02-15-2008, 02:18 AM   #2579
quietstorm76's Avatar
What header is recommended for the 2602 pipe when using on the plus 12-3?
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 02-15-2008, 03:45 AM   #2580
when you take the needles totally out, it's best to change the o rings as the act of taking htem out will sheer some rubber of them.
if you are rushed for time, and have no o rings, use some plumber's teflon thread tape, make sure you position it so it does not interfere with the needles pasage though.
TomB is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
