Like Tree21Likes
Old 04-05-2004, 03:16 PM   #241
PSI Racing's Avatar
Originally posted by DickemDown
www.nitrohouse.com
they have both the 421p & 421b. reviews about the 421b seem to be mixed. i've surfed the web, and found one guy on several boards saying it sucked and he had seen some team guys switching back to the p-5. again, one guy's opinion i've found on different forums. while i was @ nitrohouse, i had asked one of the guys, and he said it ripped. same bottom as the p-5 then pulled from mid to top. so there you go - one engine, two opinions. isn't that the way it always works?
The 421B is a completely different engine from the RX-421P that I was asking about.
The 421B is a buggy engine.
The RX-421P is Novarossi's new 1/8 on-road AAC engine.
PSI Racing is offline   Reply With Quote
Old 04-05-2004, 05:59 PM   #242
warpig's Avatar
no engine is alike... go to ofna.com and go to the engine tuning page... very accurate of how to tune an engine..
warpig is offline   Reply With Quote
Old 04-08-2004, 01:26 PM   #243
going backwards ?
Hi all Have just finished running in my .21 novarossi P5T
I've had poblem,s dialing in this beast
It started after the original plug blew ,when i replaced it the engine would start backwards . I checked the direction of the starter box and that was right ,the pug that i replaced it with was a OS P6 turbo plug which the shop had sent me so i though that this pug maybe to hot and had advaced the timing in some way ?
changed to a rossi RT7 (very cold) and all seemed well as i turned a corner I relased the throtal and excelarated only to find it had gone into reverce ?
any idias
Storm is offline   Reply With Quote
Old 04-08-2004, 01:39 PM   #244
One other thing novarossi dont realy give much away on there web site I can't find the factory settings for the carb and i don,t know if i should have taken out the red pug in the carb
I know that these maybe silly question's but i did'nt get any instution's with the engine so im a bit stuck please help if you know many thanks
Old 04-08-2004, 03:09 PM   #245
warpig's Avatar
that sounds made up... but, I guess anything is possible.. it would definately be a timing issue if it's truely happening... what pipe do you run?
Old 04-08-2004, 03:12 PM   #246
rod_b's Avatar
Send a message via AIM to rod_b
Are NSR12 S3 Piston and sleeve sets available anywhere?
rod_b is offline   Reply With Quote
Old 04-08-2004, 03:14 PM   #247
Yep I know i sounds crazy thats why i need help I guess this is a one off . as i said the first time it happened I thought it was because i had the starter box the wrong way.
Any how the pipe is a Rb efra 9863
do you know about the red plug in the carb
Old 04-08-2004, 06:19 PM   #248
rcabj's Avatar
Default need help..
hi...i'm havin problem with my nova S5...
its always cut down at half tank of fuel...
and latest thing that happen that havent happen b4 the
sound of exploding...same like when your motobike sound when your havin a bad plug...
...i've check everything that is possible...fuel line, new plug, fresh fuel, no visual leak anywhere....
and lastly the engine already has 35 hours running time.
and has change the conrod twice...thank u.any suggestion and opinion r welcome...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 04-08-2004, 06:51 PM   #249
warpig's Avatar
the plug is a restrictor.. you do not want to remove that... if you do you need to replace it with another size.. the stock one is the best though.. I run a P5 Turbo also.. an 2050 pipe... a novarossi gold 6 turbo plug... not one problem.. the engine is so fast and reliable it's silly... I'd ditch the plug and try another... but, I have never heard of an engine firing up backwards after it was just running correctly
Old 04-08-2004, 07:58 PM   #250
PSI Racing's Avatar
Default Re: going backwards ?
any idias
The engine runs the direction you start it.
Check the starter box again.
I've never heard of a plug causing these symptoms.
Old 04-08-2004, 08:07 PM   #251
warpig's Avatar
I'm calling BS on this..
I just simply cannot accept that an engine running counter clockwise will stop and run clockwise..
I think I'd prolly have to change my pants if I actually witnessed it...
you developed a new way to go in reverse.. that's for sure.. you should contact traxxas after you patent it
Old 04-08-2004, 08:11 PM   #252
PSI Racing's Avatar
Old 04-11-2004, 08:54 PM   #253
racer-oZ's Avatar
R/C Tech Charter Subscriber
I'm new to nitro, I see on my novarossi ns3 the idle screw, the high speed screw and the low speed screw, but there is a 4th screw on the left side of the carb right below where the fuel tubing hooks on. Is this the mid range screw? Do you mess with that much?
racer-oZ
racer-oZ is offline   Reply With Quote
Old 04-11-2004, 09:05 PM   #254
InitialD's Avatar
Nope. Don't mess with the brass screw that controls the position of the main needle jet if you do not have any tuning experience. Leave it as it is and flat against the carb body.
Old 04-11-2004, 09:15 PM   #255
warpig's Avatar
definately don't mess with it if you don't know what it is..
it's the spray bar adjustment.. it moves the venturi position back and forth for different air/fuel flow patterns.. makes minor adjustments to rpm gains... only for very experienced tuners.. you could ruin your engine if you don't tune the whole assembly correctly... easily throw it into a lean setting...
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
