Like Tree33Likes
Old 08-01-2007, 11:38 AM   #2296
thanks
Ghett0 is offline   Reply With Quote
Old 08-01-2007, 01:51 PM   #2297
wallyedmonds's Avatar
what fuel are you guys using in holland now.
wallyedmonds is offline   Reply With Quote
Old 08-01-2007, 11:59 PM   #2298
M7H
M7H's Avatar
On track you will find mostly:
Runnertime, Tornado, Roga, R&B, and some drivers mix there own blend....
Off track (parking lot bashing), modeltechnics fuel is also quiet popular (cheap), and it is also returning to the track, because they changed the contents which makes your engine tunable...
M7H is offline   Reply With Quote
Old 08-02-2007, 03:29 AM   #2299
Insane rc's Avatar
M7h have you ever tried teflon in your fuel ?
I am experimenting whit this, someone i know works in the aircraft industrie
and is blending fuel for me .
He uses teflon 2 mu thicknes and some other high qwality turbine oils
it runs like all other fuels no noticable difrence exept some carburator tuning.
the inside of the engine is now extreemly smooth.
Insane rc is offline   Reply With Quote
Old 08-02-2007, 04:05 AM   #2300
M7H
M7H's Avatar
I never experiment with fuel.....
I just buy it, and use it.
I did hear about people adding Serpent premium lube (20ml) to a 5 liter can of Tornado, just to give your engine a bit more lube, and "afterrun"....
Last time I spoke to a guy at the track, who is sponsored by Putoline oil, they are developing lubricant especially for our type of engines.... lets wait and see.....
Old 08-02-2007, 07:11 AM   #2301
Insane rc's Avatar
I know ruud schuitmaker is sponsord bu putoline oil.
he is running mega engines for 1/10 200mm .
Old 08-02-2007, 07:49 AM   #2302
M7H
M7H's Avatar
Ruud is also a Serpent team driver, but it wasn't Ruud, it was his mate, they do a lot together....
laat maar, we dwalen erg af.
Old 08-03-2007, 10:35 AM   #2303
RevMaxx's Avatar
Send a message via MSN to RevMaxx
what do you guys think is the best and/or simplest test to know your conrod needs changing? apart from counting fuels the engine has already ran?
RevMaxx is offline   Reply With Quote
Old 08-05-2007, 07:04 AM   #2304
Good Day,
I am having an issue that i need some assitance with, whoever can assist me, kudos to them. Ive posted here about my old rossi engine the MT12. The engine has never been rebult and has had at least 3 full galons of the same fuel put through it from 99 to 2007. after the car gets going for about 6 to 7 mins the engine works well, but after it begins to bog at full throttle, only sometimes tho. The engine runs hot 210 220 deg, which is how hot the engine has always ran. compression is still there with the engine but personally i figure the engine may be on its way out. What could result in the engine boging at full throttle on occasion? and what steps should i do to try and fix it? at this point the car has been taken apart totally, and is being rebult since i just finished my weekend of racing. Whatever you guys reccomend i will take to the bank and make the neccessary changes.
Thanks again
Cole.
Old 08-05-2007, 05:39 PM   #2305
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
guys, is it true that all nova based engines are unable to fire up when your engine is hot? i.e. u run it until fuel finished, which of course died off, then u refill and start it up, it just can't be started right away rite? coz i m having this problem and was wondering if its just me or because of the metal carb of nova. coz for OS engine and wasp, its fine due to the plastic carb. thanks.
uniquexme is offline   Reply With Quote
Old 08-05-2007, 08:58 PM   #2306
sounds like fuel lock. that can happen with any engine. take the hose off the tuned pipe and blow through it untill you see the fuel entering the carb via the fuel hose then re-connect the hose you were blowing into back on to the pipe...... it should now fire up.
mugengreg is offline   Reply With Quote
Old 08-05-2007, 11:03 PM   #2307
uniquexme's Avatar
hmm, isn't there a better way?
Old 08-06-2007, 06:49 AM   #2308
Bad Mika's Avatar
could you have tune it too lean, thus it has overheat which will not allow you to start even if you 'closed' the stinger to forced fuel in ?
just my thoughts...
Bad Mika is offline   Reply With Quote
Old 08-06-2007, 05:24 PM   #2309
uniquexme's Avatar
hmm. but if u lean the LSN, doesn't that make the engine less torque?
Old 08-06-2007, 11:52 PM   #2310
twiggy's Avatar
take the backplate off and check if there is any play on the crankshaft pin where the rod connects to the crankshaft. just rock the crank back and forth and if there is any play between them then change the rod.
www.Moorebankraceway.com
Hamilton 2008 F1 champion!
twiggy is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
