Old 07-20-2007, 01:40 AM   #2281
asw7576's Avatar
Originally Posted by FF25510 View Post
i'm running 20% with 6tf should i add to total 0.5
tks
Sorry, can't help...... I'm using 30% nitro and 7TF.
My home climate is near sea level, .... hot and humid ( 34C with 60% - 65% humidity ). A bit like in Hong Kong in June - July.
Old 07-26-2007, 08:59 AM   #2282
teamgp's Avatar
Originally Posted by warpspeed57 View Post
Hi guys, thanks for all your help so far with my new Max LS3. Ran it on the weekend ended up with the bottom needle ONLY 1& 3/4 turns out. Any further out and the engine wont idle for more than 10 sec,slowly just drops rpm and stalls. I know its rich if i have the bottom needle any further out because as you give it a small rev it coughs raw fuel out before it catches and revs. My problem is that even with the bottom needle at up to 4 turns out the bottom runs on for about 3 sec before coming to a nice reliable idle, IT is not running on because it is to lean, its different, it just seems to drop down to a very high idle and then takes about 3 sec to drop right down. Almost like you have "Idle Up" on. (At least it never stalls on the start) Only real problem with it doing this is in hairpin corners it doesnt allow the clutch to tottally disengage and can throw the car into the fence if you arent careful. Should I just put up with this running on and tighten up my clutch a bit ??
Sounds like you need to lean out the top needle and richen the bottom at the same time. Also keep checking the idle screw after each change to make sure that you don't have it screwed in too much. As you lean the top out, you may need to take the idle screw out some.
My SL3 just fully broke in this past weekend. When I get home from work, I'll look at the needle settings and post them tonight.
teamgp is offline   Reply With Quote
Old 07-26-2007, 09:07 AM   #2283
teamgp's Avatar
Doh! Just realized your post was from last month.
How is it working and what are your needle settings now?
Old 07-28-2007, 02:12 AM   #2284
asw7576's Avatar
Is Turbo SG crankshaft legal under EFRA / IFMAR 2007 rules ??
Consider N12 LL-3 versus N12 LL-T3. Is T3 legal now ?
Old 07-30-2007, 07:11 AM   #2285
Insane rc's Avatar
yes ,the turbo crank is efra/ifmar legal.
Insane rc is offline   Reply With Quote
Old 07-31-2007, 07:03 PM   #2286
quietstorm76's Avatar
Default Novarossi plus 21-3
I'm trying to find out some info on the PLUS 21-3, mainly durability. Didn't seem to have a lot of pinch before I started breakin and it doesn't seem like it will last very long. 3 tanks so far with heat cycle method as I always do, temps 180-190 deg. Did these motor have a durability issue?
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 07-31-2007, 07:08 PM   #2287
wallyedmonds's Avatar
i hear this too but i dont have the motor and ppl talk
just run it be carefull
but i did hear its fast.
wallyedmonds is offline   Reply With Quote
Old 08-01-2007, 03:13 AM   #2288
Thanks for the info. I'll be very careful.
Primary Weapon: ?
Secondary Weapon: ?
Old 08-01-2007, 03:22 AM   #2289
Originally Posted by Ghett0 View Post
could someone help me out, im looking for the stock needle settings for the old Novarossi MT12 engines
thanks
anyone??
Ghett0 is offline   Reply With Quote
Old 08-01-2007, 03:41 AM   #2290
HSN base setting is flush, but I can't remember lsn sorry.
Primary Weapon: ?
Secondary Weapon: ?
Old 08-01-2007, 04:02 AM   #2291
mt 12 i think the lsn is 3 turns out
Old 08-01-2007, 04:26 AM   #2292
Insane rc's Avatar
I have 2 12-3 engines one new and one used . when the engines are new they
pinch so hard that you have to use a hairdryer to get them fired up.
And even then it stil locks up .
My used engine has 7 liters and 6 races trough it and stil touches the cilinder in tdc position.(changed the conrod after 5 liters).
Durability is good the 12-3 outlasts a mega 12 ds2 and a sirio evo3 by far.
I have used the mega and the sirio the same way i have used the 12-3 so
for me its novarossi all the way.
Old 08-01-2007, 06:04 AM   #2293
M7H
M7H's Avatar
No more Mega DSII for you?...
But, about the pinch, the Mega doesn't have a lot of pinch either. I don't see why a lot of pinch will enlarge the durabillity...
M7H is offline   Reply With Quote
Old 08-01-2007, 07:10 AM   #2294
Insane rc's Avatar
Don't get me wrong the mega ds2 is a realy fast engine but not as durable as
the novarossi engines.
m7h where are you from?
Old 08-01-2007, 07:44 AM   #2295
M7H
M7H's Avatar
I was only reffering to the fact that in my opinion a hugh pinch or not doesn't really tell you if the engine will last long or not.......
Also from Holland.....
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
