Old 05-16-2007, 12:53 AM   #2191
Sirio2127's Avatar
Send a message via MSN to Sirio2127
the rear main bearing size for a 35+21 novarossi engine is 14.5mm inside dia and 26mm outside dia and 6mm wide and front bearing for the 35+21 is 7mm inside dia 19mm outside dia and 5mm wide the front is a special size only the 35plus and i think the nova plus3c 7 port 21 onroad engine and the plus 2 359 engine all should have a 5mm wide front bearing. All the off road engines 21 size will use a 7mm inside dia 19mm outside dia and 6mm wide front bearing. Regards Jeremy.
Im not shore if i miss read your post are you looking to get sizes on the balls only?? or the bearing sizes??
Sirio2127 is offline   Reply With Quote
Old 05-16-2007, 03:38 AM   #2192
hi sirio,
i mean the balls only
dieter
4racer is offline   Reply With Quote
Old 05-16-2007, 07:26 PM   #2193
Sirio2127's Avatar
I'm would think there is no set sizes as each bearing would have the balls picked to minamize the tolarences for each bearing. If i was going to do what your thinking of doing i would buy a brand new bearing remove the cage from the bearing and remove the balls. Then i would take them to the best quality bearing shop you know of that would sell high quality pricshion ball's for bearings and get them to mike them and let them hand slelect the ball to suite that pitcular bearing. There are 2 major probs with doing this your self you could make the tolarences too low causeing the bearing to tighten up when the engine is at running temp. Or the tolarences may be to low causeing excess movement. But befor you try id have an email to as many bearing manufacturs as posable like boca Tko acerbearing. and ask them some tech info questions. They should be able to ancer your question better. I have thought about doing it but your almost playing with fire an less its done properly you could distroy your engine. Let me know how you go Best Regards Jeremy.
Old 05-19-2007, 06:25 AM   #2194
i will be starting to racing soon and i am new to the hobby i have a kyosho rrr. will the novarossi .12 engines be easy to tune for me?
racernut is offline   Reply With Quote
Old 05-19-2007, 08:08 AM   #2195
they're about the same as any other engine. do yourself a favor and only buy a new engine and get someone talented to do the baseline tune the first time so you only have to move it slightly on different days.
brianhatesnitro is offline   Reply With Quote
Old 05-22-2007, 02:59 PM   #2196
supermoto552's Avatar
Will a NSR12 (3port) Piston/cyl/rod combo be able to fit straight into my N12 LS5? Bore and stroke seem the same, or will this not work? Just looking into for re-build spares to stock up.
Thanks in advance.
supermoto552 is offline   Reply With Quote
Old 05-22-2007, 03:06 PM   #2197
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Thanks in advance.
NO WAY
it's impossible because LS engines comes with newer crankcase, combustion chamber and sleeve.........the cranck case is higher, and to make the combustion chamber and sleeve fit the new cranckcase then they both are longer than they were in previous engines......
only carburettor, backplate, head, bearings, shaft, conrod and piston are the same.........
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 05-22-2007, 03:18 PM   #2198
Brilliant mate, thanks thats all i needed to know...thanks for the quick reply.
There's one on ebay for 19 so thought i'd try grab a bargin, ah well maybe not! Just wanted to keep it in in case i needed to rebuild.
One more question i asked earlier on this page...will a newer head of the Plus 12-3 range fit on to my LS5? hate the purple and like the lower head look.
Old 05-22-2007, 03:23 PM   #2199
yes.........PLUS-3 only (or T, C, CT), not PLUS12-3 S (or ST, SC, SCT).......
Salvadori Racing
Old 05-22-2007, 03:24 PM   #2200
dg8one's Avatar
i'm having problem w/ my motor
after i breakin the motor i have this line on the piston (exhaust side) never blown a glowplug motor run 190-200 during the break in
anybody
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 05-22-2007, 03:30 PM   #2201
Cheers bud, your a great help thanks.
I'll get on and order one.
Old 05-29-2007, 11:08 PM   #2202
Trader Rating: 44 (100%+)
i recently read on the website that nova engines are tuned for 25% so i was wondering which shim should i add for 30% use? i am running odonell fuel btw and will run stock plug which will be replaced by a cold plug!
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 06-03-2007, 10:40 AM   #2203
asw7576's Avatar
.12 engines + 30% + 7Tf : 0.3 + 0.1 ( risky ); 0.3 + 0.2 ( safe ); 0.3 + 0.3 ( very safe )
.21 engines + 30% + 7Tf : 0.3 + 0.1 ( quite safe ); 0.3 + 0.2 ( safe ); 0.3 + 0.3 ( very safe ).
0.3 is original shim ( silver ).
Pick your cards .........
I prefer very safe rather than getting a melting coil situation.,,,,,,,, sucks man !!!
Old 06-06-2007, 03:15 AM   #2204
RevMaxx's Avatar
Send a message via MSN to RevMaxx
i own an old NSR12S5 engine with about a gallon run through it. the engine runs good, idles well and temp is good (230-240F).
my concern is that there would be times were coming from a curve going mid throttle and going to a straight, the engine suddenly dies when i squeez full throttle. what do you guys think is the problem here. definitely not the glow plug as i've change to new plugs and same problem... using tornado 25% fuel.
also, will any nova .12 conrod fit to this engine? TIA...
RevMaxx is offline   Reply With Quote
Old 06-06-2007, 05:56 AM   #2205
bottom end is lean, richen the bottom.
TomB is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
