Like Tree21Likes
Old 05-06-2007, 01:36 PM   #2161
Ice_nl's Avatar
Send a message via MSN to Ice_nl
OK thanks, how do the plugs compare, i used an Mega 6 cold plug is an Novarossi 6 the same or do they use a different number system. I had a problem with my last mega plug that the coil fell in the engine and i don't want that to happen when i got the new set in. JP plugs are easier to get for my lhs so i am going to try some of those.
RC-Models.nl | Shepherd Velox V8 EC OM-Edition | Shepherd Velox F1 | Buri Racer E1.2 | Tamiya 419x
Ice_nl is offline   Reply With Quote
Old 05-06-2007, 02:51 PM   #2162
MRX4-R03's Avatar
Well the plug fell apart, probably because your were running way to lean and the plug could not take it and came apart, you need to check your engine inside, and on top of the button those metal fragments could get in the bearings and so on..I would say that a mega 6 is the same as a nova 6 what % of fuel are you running try going to a nova 7tf you will alittle more torque and may run alittle cooler..
MRX4-R03 is offline   Reply With Quote
Old 05-07-2007, 01:04 AM   #2163
Ice_nl's Avatar
That's the strange thing, it was running OK, and suddenly it stopped and couldn't get started again. temp was max 113C, there was a nice trail of smoke coming out of the exhaust and no signs of lean running. i run 16% as that's only allowed in 1:10 races over here. so i guess it might been just a bad plug or just bad luck. I already ordered the new parts for the engine and i dont want it to happen again.
Old 05-07-2007, 11:56 PM   #2164
Dynamite's Avatar
Send a message via MSN to Dynamite
hey guys, got a question about my nova N12LLT3 motor...
ever since when it was new when you tightened the flywheel onto the crankshaft there is a little front to back movement through the little bearing in front of the flywheel. everythings tight it just looks like it rocks on the inner race a little and seems very strange.
is this normal for nova motors? as i have never expirienced this before with any other motor brand i have bought before and this is my first nova motor so i cant guage it against any others.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 05-08-2007, 02:25 AM   #2165
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
axial play is normal.........
radial play is dangerous.......
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 05-08-2007, 02:41 AM   #2166
Dynamite's Avatar
axial play = so if it moves in and out a little thats ok?
radial play = if you hold the end of the crank and move it in a circular motion
is this what you mean?
Old 05-08-2007, 02:44 AM   #2167
yes.........
Salvadori Racing
Old 05-08-2007, 02:50 AM   #2168
rcabj's Avatar
woaaah.......mine is having both i think but still i use for practicin..
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 05-08-2007, 02:52 AM   #2169
Dynamite's Avatar
thanks Salvadori,
it just seems weird, as i have never had a motor from another brand do this ever. i did have a mega/picco that had the radial play problem but that was after 2+ gallons of fuel.
thanks again mate
Old 05-08-2007, 05:34 AM   #2170
thanks Salvadori,
thanks again mate
You front bearing is worn out.....
eduardo_garcia is offline   Reply With Quote
Old 05-08-2007, 05:53 AM   #2171
Dynamite's Avatar
i hope not eduardo.... it was like that new from the packet
Old 05-08-2007, 07:04 AM   #2172
I hope too.. But I had the same problem with a brand new NR engine... After 1 liter I notice the axial movement... After more 0.5 liter I notice a very small leak on the front beraring. I removed it and find out that the axial movement was happening because of the faulty front bering. I would check if I were you.... better be safe than sorry....
I hope it helps
Eduardo
Old 05-08-2007, 07:36 AM   #2173
That's probably why Nova included new bearings with the 367 offroad engine
brianhatesnitro is offline   Reply With Quote
Old 05-09-2007, 01:26 AM   #2174
Dynamite's Avatar
can anyone tell me the size of this bearing so i dont have to pop it out to see before ordering one? because i'll just try get one from my local bearing shop.
also if i get it from a local bearing shop is there any particular type of bearing i should be asking for or just a std bearing thats rubber sealed?
Old 05-09-2007, 01:46 AM   #2175
MRX4-R03's Avatar
if I am correct it is a 7/17/5 or 6
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
