Like Tree21Likes
Old 04-25-2007, 05:32 PM   #2101
MRX4-R03's Avatar
From the pic is that a 5 port p/s: Or is that something new.
And the crank does show weights:
Sleeve: The sleeve has 3 transfer ports and an exhaust with booster ports. The special shape and positioning of the ports, covered by a patent, improve the internal fluid-dynamics to obtain the maximum possible performance.
Crankshaft: The crankshaft is grinded to increase the mixture flow and has a special shape to reduce turbulences inside the crankcase. The balancing is done by two inserts made of tungsten alloy and the inlet has a silicon filling to reduce the weight of the crankshaft to improve acceleration. The ball bearing was lowered to5mm. The front part was extended to improve the seal against fuel leaking.
MRX4-R03 is offline   Reply With Quote
Old 04-25-2007, 05:48 PM   #2102
yeah the sleeve is probably the wrong picture, but the text for the crank is very specific so i expect it to be similiar to the picture, if it doesnt have the weights and silicon and whatever, then i will have to wonder just what exactly i am paying for... for 500 dollars i would be happy with a factory modified nova and a crap engine, but a 3sct with a smaller bearing and two tiny holes in the sleeve and a crap engine? no thanks.
randay is offline   Reply With Quote
Old 04-25-2007, 05:51 PM   #2103
MRX4-R03's Avatar
And from the parts list this P/S is gonna be expensive because you will have to buy the whole button assy, P/S/AND BUTTON.
Old 04-26-2007, 01:35 AM   #2104
hi randay,
this is what you become from novarossi
4racer is offline   Reply With Quote
Old 04-26-2007, 01:45 AM   #2105
M7H
M7H's Avatar
I notified the webdesigner from Novarossi about the aparently wrong info on there website....
He is also a member on this forum, but I will not tell who he is.....
At the moment the website is undergoing a complete makeover, so the ".it" website will come available again after the ".com" website is finished....
Due to this makeover, I reckon they made a mistake with the pictures on the site.......
Serpent
M7H is offline   Reply With Quote
Old 04-26-2007, 02:32 AM   #2106
hi m7h,
read the post to the cranck of the 353, i think it is not a mistake.
the pic ist the right,the text is ok to this pic.
dieter
Old 04-26-2007, 02:50 AM   #2107
M7H
M7H's Avatar
4racer
The pictures on the website are different from what you posted in your previous post about what really is in the box!....
I see no "tungsten" and also those "booster" ports are not there... (but it is difficult to see in your picture, so I could be wrong)
Grinder posted a picture, with no booster ports, but 2 additional small holes under the main intake port....
According to me "booster" ports are also not IFMAR legal....
Serpent
Old 04-26-2007, 02:53 AM   #2108
Dynamite's Avatar
Send a message via MSN to Dynamite
engine would be worht more sold for whatever you can get for it then as a paper weight or at the local trash depot
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 04-26-2007, 03:29 AM   #2109
hi m7h,
thats the problem. my crackshaft have no balanced weights,
and my piston have 2 extra holes.
thats not what novarossi shows.
my distubutor have write to novarossi about the problem.
dieter
Old 04-26-2007, 05:38 AM   #2110
Grinder's Avatar
Originally Posted by MRX4-R03
So the only thing different they did different was add the hole's to a sct sleeve do you see any other difference in the sleeve timming,
what other differences do you see in the engine compared to the sct
The sleeve has different timing. The boost port is much larger on the 353. The exhaust port is a different shape slightly..Similar to the new batch of +12 engines. The transfers have also been reshaped slightly similar to the new batch of +12's. The crankshaft is basically the same as the +12, but the crankpin is smaller. You must use the new connecting rods with the new engines. 353, and 359. The piston is cast in the 353. The case of the 353 no longer has the wing shaped transfer port seperators. The backplate of the 353 has a steel insert to avoid scratches and extend engine life. The stock engine is smoother, faster, and cooler running than the past +12 engines from Novarossi. The modified version has similar characteristics, just more overall power. I will be pounding the mod 353 at 301 this weekend. Stay tuned to see how it runs over the long haul.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 04-26-2007, 10:03 AM   #2111
Originally Posted by 4racer
hi randay,
Well thats not so bad I guess. All thats missing really is the tungsten weights.
From what murnan has said it is the fastest yet, and if it is the fastest yet, I really cant complain. I guess the problem is seeing all the pretty pictures and getting something else in reality.
Old 04-26-2007, 10:09 AM   #2112
Derby Bros Racing's Avatar
Just like the pretty pictures of hamburgers when you go to McDonald's only to find out they don't look the same when you get them but it's still good stuff *humor only*
Derby Bros Racing is offline   Reply With Quote
Old 04-29-2007, 12:15 PM   #2113
border r/c's Avatar
Originally Posted by rcabj
is there a novarossi LR3 ? thanks
cool that use the foto for avatar that I made
http://www.the-border.com
Europe's largest 1/8 scale 1/10 rc car warehouse.
3Racing-Ride-BRP-Team Orion-XRAY-HUDY-Serpent-Kyosho-Lrp-Speed Passion-MR33-JG-and many more
border r/c is offline   Reply With Quote
Old 04-29-2007, 12:25 PM   #2114
border r/c's Avatar
Yea from what I heard it comes with this piece of junk:
The engine is not even listed in the catalog: It is just supposed to be a club engine!!
today we did try this motor run it in in heat 3 and race in the finale on a NT1.
absolute a very good motor to race, 3rd place in the A finale with all the topshot guys with Mega's and Max's only 0.2sec slower.
(Mach circuit link )
Next race we will try the Bomb very curious what will happen
Old 04-29-2007, 01:02 PM   #2115
wow,
that must be the hammer engine, even fast as the plus 2.
why did novarossi not built so a engine bevore.
or are the other engines also built bevore 2004.
dieter
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
