Old 04-16-2007, 02:07 PM   #2056
Grinder's Avatar
Originally Posted by Grinder
The rod is the same. 17006
Sorry 07601.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 04-17-2007, 02:39 AM   #2057
jaykay's Avatar
What are the main diffrence between the Plus 12-3 and Plus 12-3 SC.
I only recognized that the SC have ceramic ball bearings and a 11.9mm crankshaft.
jaykay is offline   Reply With Quote
Old 04-17-2007, 03:30 AM   #2058
asw7576's Avatar
I know C = Rear Ceramic Bearings, T = Turbo Crankshaft, but I don't know what S means ?
Old 04-17-2007, 03:35 AM   #2059
asw7576's Avatar
Originally Posted by Delta9
I will normally clean my airfilters about 4 times before throwing away, sometimes less if they look dodgey. as long as you clean it from the inside out its fine as it wont push the dust into airfilter, i use denatured alcohol or petrol to clean my airfilters.
I soak and gentle wash my filter with highly concentrated detergents, about three times cleaning process. After complete drying, I right away give filter oil and keep them in clean containers, ready for use anytime I want. Mostly they could last about a year.
Old 04-17-2007, 10:22 AM   #2060
gtrmx's Avatar
Originally Posted by SalvadoriRacing
17006 is the front bearing (not for the SCT, only for the previous ones)
the conrod code is 07601 and yes it's the same conrod of NS/NSR series....
Thanks to all!!
gtrmx is offline   Reply With Quote
Old 04-18-2007, 06:06 AM   #2061
Grinder's Avatar
The main difference is the .4,, increase in crankshaft diameter. Nova also added an O ring to the head button. The Exhaust ports are constantly changing from Novarossi. This is also different depending on which +12-3CT you got. On the brand new batch of +12-3SCT's the transfer ports are a slightly different shape for the better.
Old 04-18-2007, 06:11 AM   #2062
Dynamite's Avatar
Send a message via MSN to Dynamite
interesting to see that they went to 11.9mm rather then 12mm with the crank, i guess it makes buying replacement bearings hard without getting genuine ones.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 04-18-2007, 09:43 AM   #2063
Grinder's Avatar
Default Is this ROAR/IFMAR legal
Does the 353 have too many holes in the cylinder to be legal?
Old 04-18-2007, 10:00 AM   #2064
stefan's Avatar
Send a message via AIM to stefan
As far as I know, they consider holes below the top of the piston (i.e. that are not opened to the combustion chmaber during the cycle , as cooling holes. Don't nail me on it though.
Actually, better don't nail me at all
stefan is offline   Reply With Quote
Old 04-18-2007, 03:34 PM   #2065
Hi guys:
The new 2630 pipe is good for the old NSR12s5 engine?
regards
eduardo_garcia is offline   Reply With Quote
Old 04-18-2007, 04:33 PM   #2066
Dynamite's Avatar
i know orion had protests at the worlds from the other manufacturers regarding the slits they had in their liners on the wasp rev, i'm sure it got over ruled because they were not extra holes, but a hole with a slit so not technically extra holes in the liner...
the extra holes in the nova while technically not part of the combustion process are extra holes in the liner because they are holes, this could be a very grey area on legality indeed.
Old 04-18-2007, 04:38 PM   #2067
JB04's Avatar
I have a JP Mod Plus 12 - 3 and have been told that the "C" designates 11 ceramic bearings. Without the "C" there are 9 ceramic bearings.
Can anyone confirm or deny this?
RCAmerica / XRAY NT1
JB04 is offline   Reply With Quote
Old 04-18-2007, 05:04 PM   #2068
freefallmarine's Avatar
Hi All, I was wondering if you can put a 7 port Plus-7 p/s into a 5 port Plus-5? Like the older 7 ports in the p5. Thanks.
freefallmarine is offline   Reply With Quote
Old 04-18-2007, 05:47 PM   #2069
afm
afm's Avatar
THIS IS THE NEW EFRA RULE CONCERNING .12 ENGINES
5.1 Appendix 7
The engine may have a total capacity of not more than 2.11 cc.
They shall be air-cooled, with front rotary valve, two-stroke induction.
The engines may have e maximum of four (4) ports in the liner, including the exhaust port, seen with the piston at lowest position.
No form of forced induction is allowed.
No form of variable port timing.
Only glow plug ignition is allowed.
One additional gap in the bottom (skirt) of the piston is allowed.
Additional slits or holes in the liner for cooling purposes are allowed as long as they do not reach the top of the piston at lowest position.
Standard and conical glow plugs allowed.
Where ever we say hole in this rule we mean a hole that is surrounded completely by material.
and i also know that because of the protest aver the Orion engines at the Worlds, IFMAR also ruled that slits or holes in the liner, below the piston at BDC are legal
AFM
afm is offline   Reply With Quote
Old 04-19-2007, 04:47 AM   #2070
Grinder's Avatar
5.1 Appendix 7
AFM
Thanks AFM. I guess Stefan was correct. I like these rules.
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
