Like Tree32Likes
Old 03-27-2007, 11:49 PM   #1996
M7H
M7H's Avatar
Try a new plug first....
Serpent
M7H is offline   Reply With Quote
Old 03-29-2007, 08:08 PM   #1997
rcabj's Avatar
hi.. can anybody give a review or comments on the Novarossi LL3...? tq
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 03-30-2007, 07:18 AM   #1998
ziggy12345's Avatar
Fantastic engine... I have 4 for sale
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 03-30-2007, 07:41 AM   #1999
Quick Question:
I am still using my old Rossi engine from `2000. Itís a MT12. Itís been running well for years. I just recently purchased the MTX-4 and dropped my old MT12 engine in and she works great. I will be racing this summer and I think its time for a new engine. I think I would like to stick with Nova Rossi. Which Rossi engine\pipe would be a good fit for racing this summer, it must be ROAR legal.
Ghett0 is offline   Reply With Quote
Old 03-31-2007, 03:43 PM   #2000
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Ghett0
Quick Question:
Nova plus 12-3
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 03-31-2007, 06:45 PM   #2001
tenderfoot57's Avatar
Send a message via AIM to tenderfoot57 Send a message via Yahoo to tenderfoot57
Default WTF
O.K. here's the question for ya all. I have a NSR 12 that I have modded the crank and sleeve. The engine ran fine last season and I went to fire it up today and had a strange experience. The engine will sit there and idle, as soon as I give it any throttle it starts to run backwards, it will idle like this for a few seconds then I give it gas again and it stalls. Whats the deal? The only difference from last year to this is the type of fuel that I am running.
Thank in advance for your thoughts.
TF
tenderfoot57 is offline   Reply With Quote
Old 04-01-2007, 07:38 PM   #2002
Dynamite's Avatar
Send a message via MSN to Dynamite
starter box battery not connected in reverse?
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 04-04-2007, 09:10 AM   #2003
blanks596's Avatar
Trader Rating: 14 (100%+)
can anyone tell me how many head shims to use for the N12LL3 with 30% fuel?
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 04-05-2007, 12:24 AM   #2004
M7H
M7H's Avatar
TF
How much did you do to the crank?...
If you really changed the timing, you just might have gone to far....
and then these things can happen......
Serpent
Old 04-06-2007, 08:33 AM   #2005
Considering buying a 12-3SCT (HotMod) at a good price and was wondering which pipe would be the best match on a small technical track(120ft x 70ft) ? Also, what is the difference in 5/6/7 fin manifolds?
I'm a newbie to Nova motors, so any help would be appreciated.
unc_tarheelz is offline   Reply With Quote
Old 04-06-2007, 09:55 AM   #2006
Novarossi EFRA 2630 Pipe. The different manifold lengths affect the powerband you want. Shorter is more bottom end punch and longer is more top end. I'd start with the 6 fin manifold like in my sig.
Kyosho V-One RRR - JP Modified Mugen X12 - GQ Racing Tires - Futaba servos - KO Helios w/Spektrum Pro - Maxy's Fuel
Losi 8ight 2.0 RTR for fun times
Dredd is offline   Reply With Quote
Old 04-06-2007, 10:10 AM   #2007
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
at a very very short track you can even try the efra 2601
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 04-06-2007, 10:11 AM   #2008
it's the opposite.............
the shorter the manifold, more power at higher rpm.........
the longer tha manifold, more power at low rpm.....
Salvadori Racing
Old 04-06-2007, 12:10 PM   #2009
where did you read this cause every single place I read and checked said the longer length gave more top end because the resonation takes more time to pass through.
Old 04-06-2007, 12:23 PM   #2010
Trader Rating: 73 (100%+)
SalvadoriRacing is correct !!
http://www.challengers101.com/IntakeTuning.html
Copied from above: Read last paragraph !
A 2-stroke is different of course since there is only a finite amount of fresh mixture available in the crankcase to be transferred up into the cylinder. In a 2-stroke, we want to maximize the retention of that finite fuel charge. We can't afford to "waste" any of it by having it escape out the exhaust port.. This is not a concern in the 4-stroke because the intake flow of fresh mixture is unlimited, or at least limited only by the duration of the intake valve timing. The closing of the exhaust valve prevents significant escape of the incoming charge.
The exhaust tuning of a 2-stroke is designed to preserve the positive pulse going down the pipe and reflect that positive pulse back up the pipe. A racing engine exhaust system uses an expansion chamber at the end of the pipe which is basically two cones that reverse themselves prior to the end "stinger" where the spent exhaust is allowed to exit the chamber.
That sort of expansion chamber creates a very strong positive wave reflection back up the exhaust pipe, and this positive pulse will reduce the amount of fresh charge escaping out the exhaust port, and in some cases, force back into the cylinder any charge that may have escaped before the positive pulse arrives.
On 2-stroke racing engines, we will see an immense change in power delivered when the exhaust system is tuned for a particular RPM range and the engine revs into that range. It's called "coming on the pipe" and the burst of sound and power that occurs when that happens is easily witnessed.
The length of the exhaust pipe, prior to the muffler, is another important factor due to the speed of the pressure waves mentioned earlier. The length must be such that the exhaust pulse can travel to the end of the cone and be reflected back up the pipe to arrive at the exhaust port just before it closes.
Higher RPM will require a shorter pipe and lower RPM a longer pipe to produce the maximum effect at the RPM we want to use for maximum horsepower. It's not practical to vary the pipe length, so we compromise with some specific length that will deliver the best push at near top RPM.
Nitro-mech is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
