Like Tree9Likes
Old 03-19-2007, 08:46 PM   #1981
Pooh2's Avatar
Send a message via MSN to Pooh2
I'll b there sunday. I've learned not 2 say what I'm gonna do and just do it.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 03-20-2007, 08:21 AM   #1982
Bigbarn's Avatar
Anyone out there know the factory carb settings for the .12 NSR3?
HSN?
LSN?
Bigbarn is offline   Reply With Quote
Old 03-20-2007, 08:51 AM   #1983
stefan's Avatar
Send a message via AIM to stefan
HSN?
LSN?
HSN 4.5 turns out
LSN 2.5 turns out
stefan is offline   Reply With Quote
Old 03-20-2007, 11:02 AM   #1984
Bigbarn's Avatar
Originally Posted by stefan
HSN 4.5 turns out
LSN 2.5 turns out
Thanks Stefan
Old 03-21-2007, 06:19 AM   #1985
ziggy12345's Avatar
Can somebody tell me what the performance difference will be for a .21 engine with and without the silencer? I dont have enough room to fit a silencer on my project and noise will not be a problem
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 03-21-2007, 08:48 PM   #1986
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Running without an exhaust system will make the engine run louder and hurt performance drastically.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-22-2007, 01:58 AM   #1987
Sirio2127's Avatar
Send a message via MSN to Sirio2127
running any engine with out some kind of chamber will damage your engine. If your making a one off prodject car id strongly think about making a custom system for it with some kind of expantion chamber. These engines need the pipe chamber to matain back prushure and they also act like a fuel pump by preshureizing the fuel tank.
Sirio2127 is offline   Reply With Quote
Old 03-22-2007, 02:18 AM   #1988
ziggy12345's Avatar
Damage your engine?? How could that be? All the expasion chamber does is produce a positive and negative wave cycle to compress the bypass fuel back into the cylinder than help in evacuating the exhaust fumes
If this is missing then all that happens is you might get blow by of fuel, which can be compensated by running rich.
The only thing I would expect is that the engine will produce a slightly less power and peak at a lower RPM and use slightly more fuel.
Sponsored by:
Norfolk and Chance
Old 03-22-2007, 07:42 PM   #1989
Default Lamberto Collari Conrod
I recently purchased the LC 35 plus 21 and i have heard people say that you should replace the conrod after the first gallon. is the conrod the same in the LC as it is in the standard 35 plus 21
sikbrahmugen317 is offline   Reply With Quote
Old 03-22-2007, 07:48 PM   #1990
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
the conrod lasts longer than 1 gallon..........
it's different than the 35 plus 21, the conrod is called C1, the pin diameter is smaller than the R7 which comes with the 35 plus 21.
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 03-23-2007, 08:01 AM   #1991
Default Best pipe for Novarossi NSR12S5 pls advise...
I have rebuild my old NSR12S5,
Pls advise which pipe (and part number..) is most suitable with this engine from these option: RB pipe, Nova, Shark, skyline VR12 plus?
Faiz is offline   Reply With Quote
Old 03-23-2007, 10:54 AM   #1992
asw7576's Avatar
Novarossi Turbo pipe & manifold.
Old 03-23-2007, 01:54 PM   #1993
Sirio2127's Avatar
I have a stock out of the box 35+21 and kained it from the first start. I only needed to change the rod at 15ltrs that nilly 4us gallons. But like the person befor me The collari 35+21 uses a difrent rod weather its just renamed or not. I would say change it as soon as you see play but rember when a conrod gets play thats when they ware the crank pin and thats more expencive to replace than a conrod. My engine has 2 rod piston pin and bearing changes and over 30ltrs of running time on it thats about 7us gallons. and its better than some engines ive seen with less than half the run time. Most of the ware factor is in the tune and fuel. The right combo will make an engine last and last. Regards Jeremy.
Old 03-25-2007, 08:22 PM   #1994
Of the pipes you mentioned the Skyline VR12+ is the best option, but I would still recommend a Novarossi pipe.
Kyosho V-One RRR - JP Modified Mugen X12 - GQ Racing Tires - Futaba servos - KO Helios w/Spektrum Pro - Maxy's Fuel
Losi 8ight 2.0 RTR for fun times
Dredd is offline   Reply With Quote
Old 03-27-2007, 03:43 PM   #1995
Default c12 engine help
I have an hpi nitro rs4 2 with c12 pullstart engine. i cannot keep the engine running without the plug charger on. is this a tuning problem or are there other issues. is the engine manual still available somewhere. thanks
sigsalamii is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
